HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
Re: Observatories and Lightning.... new [Re: Mike I. Jones]
      #3198675 - 07/04/09 12:57 PM
OK - so install a separate earth ground copper rod at the observatory but only attach all the grounds, boxes, etc. to it and leave the neutrals on a separate non-grounded bus bar in the observatory - right? The neutrals would be tied to the ground bus bar at the main breaker box but not at the observatory?
I wouldn't, Mike.
There is still the possibility of differing ground potentials and the havoc that they can cause.
You realize, of course, that having a ground rod at the observatory offers virtually no protection from a lightning strike. You could spend hundreds of thousands of dollars on a Faraday cage linked to huge, buried copper plates and still lose your equipment to a lightning strike.
I believe that you would be better off wiring your observatory according to code and following the easy, practical suggestions: unplugging equipment, using UPS, etc. Most important would be making sure that you're covered by insurance.
This is a case where Mother Nature can trump any of Man's efforts to thwart her.
dan
Galaxyhunter
Reged: 01/02/06
Re: Observatories and Lightning.... [Re: HunterofPhotons]
      #3199313 - 07/04/09 07:53 PM
I wouldn't, Mike.
There is still the possibility of differing ground potentials and the havoc that they can cause. ---- I believe that you would be better off wiring your observatory according to code
The best bet is to check the code for your location. Here in the county I live in, the grounding rod is requiered for an outbuilding that has electrical service to it.
Carl
My lousy skies at Hawkeye Observatory
Luigi
Reged: 07/03/07
Loc: MA
Re: Observatories and Lightning.... new [Re: Galaxyhunter]
      #3199926 - 07/05/09 08:41 AM
Check out these articles. http://www.polyphaser.com/technical_notes.aspx
17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
Moderator:  Chris Schroeder, csa/montana
