Equipment Discussions >> Classic Telescopes
Steve310
newbie
Reged: 01/27/07
Zeiss Telementor Lens Cleaning new
      #3228016 - 07/20/09 09:10 AM
Does anyone know how to remove the lens cell of a Telementor 1(it has a helical focuser)? There are 2 screws in the tube by the cell so I imagine I would just loosen and the cell should slide out of the tube?
Thanks for any advise
RLTYSModerator
Reged: 12/18/04
Loc: New York (Long Island)
Re: Zeiss Telementor Lens Cleaning new [Re: Steve310]
      #3229744 - 07/21/09 06:05 AM
Steve
It might help if you could post a picture.
Rich (RLTYS)
10" F4.8 Refl.
4" F5 Refr. (Genesis)
3" F4 Celestron FirstScope
50mm F12 Refr. (Tasco #6TE-5)
12x63 and 10x50 Binoculars.
"I want to do more then just look."
clintwhitman
Caveman
Reged: 01/01/07
Loc: ValVerde CA(SoEasyaCavemanCanD...
Re: Zeiss Telementor Lens Cleaning [Re: RLTYS]
      #3230175 - 07/21/09 11:25 AM
Steve it is possible that pulling the cell from the tube may require colimating the lens once you stick it back in. In my experience if possible use a lens brush and air to clean your lenses, lightly dust and blow it off. Unless it is impossible to get it clean with this process. Then for the first time you clean it get help from a local old hand at working on telescopes. It is better to learn from the lenses he messed up then messing up yours!!
Where are you??? May be an old hand lurking in your area...
Clint&Debbie Whitman (aveman
1960s 6"F15 Jaegers-Unipons by John Pons on a Byers 812, 1947 4" F15 TINSLEY, 1965 10" F8 CAVE, 1950 5CM & 6.5CM Nippon Kogakus (the twins), 1960s UNITRONS a 152 restored a 160 numbered green lens original mint a 114 original 50s mint, 1950s UNITRON M100 100mm F15 OTA, WO 80mm Florite, ASTROPHYSICS 155 EDFS on LOSMANDY G11, a bunch of Tascos,Sears Mayflowers The list goes on Add infinitum.
15 registered and 5 anonymous users are browsing this forum.
Moderator:  RLTYS, Glassthrower, Clive Gibbons
