Telescope Specific Forums >> Meade ETX
Ziguy
Reged: 07/03/06
Slewing goes wild! new
      #3233326 - 07/22/09 10:53 PM
I wondering if anybody has experienced that. Sometime, when I try to slew my ETX-90PE at middle speed, instead of slewing in the direction of the arrow key that I press, it slews in diagonal or even perpendicular to the arrow key pressed. It's very annoying since most of the time I loose control and the object gets out of my FOV.
Treehopper
Reged: 07/29/08
Loc: Upstate NY
Re: Slewing goes wild! [Re: Ziguy]
      #3233366 - 07/22/09 11:20 PM
Found this on Mike Weasner's website:
Subject: Re: Meade AutoStar download
Sent: Sunday, July 22, 2007 15:01:39
From: Barbara & Tom Andrews (tombps@bigpond.com.au)
It's actually a bit embarrassing that I didn't read the Meade page
properly: a few more lines and I would have found the link I wanted
right there in the last paragraph. Once I got the program back on the
computer all was fine.
I was downloading 43Ea as I had been experiencing the worst
rubberbanding and alt/dec rocketing (only word to describe it, really)
with 43Ed. The gentlemen at Bintel in Sydney suggested using the earlier
one. I'm following the sequence in the Fine Tuning Tech Tips for
post-downloading, so I'll train it today and try it tonight. I have two
90s right now, so I'm comparing them to keep the better one and sell the
other.
Mike here: Anytime the AutoStar goes berserk, a CALIBRATE MOTOR and TRAIN DRIVES will usually solve it. If not, then a RESET, CALIBRATE MOTOR, and TRAIN DRIVES is in order. Reloading the ROM is a last resort but doesn't hurt; just remember to CALIBRATE MOTOR and TRAIN DRIVES following the load.
And:
Great that all is working okay so far. Rubber banding can be a problem
associated with some versions of firmware, but also can be attributable
to poor training; make sure that you train on a non-moving terrestrial
object far distant and that you use very high power or a reticle
eyepiece. Usually good training will clear this up.
Keep up posted!
Dr. Clay
Tim
Champion of small aperture scopes everywhere!
Meade ETX-125PE
Meade ETX-80
Celestron FirstScope 76mm Mini-dob
Updated: 09/16/2009
Moderator:  Shadowalker, oldsalt
