Observing >> Deep Sky Observing
HellsKitchen
Reged: 09/05/08
Loc: Melbourne Australia
BIG night of observing to the MAX!!
      #3238937 - 07/26/09 07:07 AM Attachment (17 downloads)
After a cold and cloudy Melbourne Saturday, I was stunned out of my jocks to see that all the Melbourne cloud was evaporating before my eyes as dusk fell.
Yes, it was actually happening, the first clear night in 150,000 years. Better take advantage of it! So all the gear was out the door faster than you can say "zOMG clear skiez in Melbs!!1!"
The night was windy, very windy. But that also meant there was no chance of dew. And seeing was actually quite decent, not perfect but certainly better than anything I've had in the last year (translation: last 5 sessions). I was using my 12" F/4.6 dob for this session.
Equipment: 12" F/4.6 dob
Time: 10:00pm-3:15am
Seeing: 5-6/10
Transparency: 3/5
M57
Kicked off the night with a look at the Ring Nebula. I was surprised by how well it showed, despite it's very low elevation in the murk hugging the northern horizon. I've never actually seen the Ring in the 12", and I was not dissapointed. At 176x, its not-quite-perfect donut shape was obvious, and the northern/southern sides of the ring were distinctly brighter than the ends. The OIII filter rendered the ring to be more uniformly bright, that is the brightness difference between the long axis and the ends was not as obvious. The interior was clearly brighter than the background sky.
Although I had planned to observe some PNe's, I was distracted by the cool stuff in Sagittarius. I never actually made an attempt to properly observe all the cool stuff there with the 12", so now was time.
M20 Trifid Nebula
At 83x, The dark lanes in the "pink" portion were visible, and easy to detect with averted vision. The "blue" part of the neb was fainter, but appeared to be unevenly bright with a darkening towards the centre, which is marked by a bright orange star. I then added the UHC filter, which greatly accentuated the "pink" part of the nebula, with the dust lanes now easily visible. The southernmost lobe is brighter than the rest of the structure. The "blue" bit remained virtually unchanged.
M8 Lagoon Nebula
At 83x with a UHC filter, the Lagoon was awesome!!! Bloody stunning! The cloud took up virtually 3/4 of the field, with the faint outer regions seen in photos clearly visible. Dark rifts break up the nebula into 4 distinct sections, with the two bright sections familiar to observers accompanied by a fainter elongated East-west filament to the north and even fainter haze to the west of the main complex.
M17 Swan Nebula
Again using the 83x EP with UHC filter.... absolutely fantastic. Very bright, and the distinct shape was as obvious as it is on long exposure photos. A fainter filament looping out from the swan's tail and around below the body was clearly visible, as was a bright knot just above the curve in the neck. Increasing power to 176x with the UHC revealed a superbly detailed body, which appears to be superimposed on a fainter background haze which follows the countours of the brighter nebulosity. Infact, the detail in the nebulosity was so complex that it would be a challenge to sketch. Almost a 3D experience. A fainter pool of nebulosity was visible to the north of the main body and adjoining it. In addition, two detached small faint knots of nebulosity were obvious along the extended centreline of the neck.
M16 Eagle Nebula
Faint at 176x without a filter, but the UHC helped alot. With the UHC in place, the nebulosity resembled a swept airplane wing viewed from above or below, oriented NE-SW. An L-shaped dark region was visible adjecent the SE edge of the associated open cluster, with a narrow finger oriented NW/SE pointing towards the centre of the cluster visible with averted vision.
NGC 6772
PNe in Aquila. Quite difficult to detect at 216x without a filter, but the addition of the OIII helped considerably. A large, rather faint oval or oblong shaped ring was visible, with the interior noticably brighter than the background sky.
At this point it was near midnight, and decided to take a look at Jupiter. Seeing was actually decent, but that being said, it was not perfect. With it still toward the east, the scope was broadside to the wind so was being heavily buffeted. At 176x, to my surprise, I could clearly see the Impact scar, neatly in mid-transit! It appeared as a tiny greyish smudge, visibly elongated E-W.
Now, with the eye-candy picked off, it was time to hunt some galaxy clusters....but not before answering the call of nature. Upon entering the water closet, I almost made the fatal error of turning on the light (well, it's been an integral part of every potty excursion for the entire duraction of my life thus far...). After almost flushing my hard-earned night vision down the toilet, it was time for some hot chocolate and choc chip cookies. Ahhhh, a clear night, great DSO observing with some hot choc and cookies....can life get any better? That's right, it can't
Re-energised and relieved, I was set for some faint galaxies *yay*.
Abell S 805
A cluster of galaxies in Pavo. The group is easily located by dint of 4 mag 10-11 stars arranged on the western side of the GX cluster in a distorted trapezoid with the long axis oriented NW/SE. A 5th mag 12 star creates a triangle wit the two southernmost stars.
At 283x, the brightest galaxy, IC 4765, was relatively easy to see, as a small, slightly elongted (E-W) blob of light.
Just to the south of IC4765, and adjacent to the north of the star TYC 9073-467-1, is the small high SB elliptical PGC 62408. This GX was actually fairly easy to spot, owing to it's high SB, and was actually the second brightest of all cluster members observed. Also visible on the northern edge of PGC 62408 was the MAG 15.9 star USNAO2-0225-29565747!!!
To the SE of IC4765 is the elliptical GX PGC 62393. This galaxy is located on the northern edge of a small quadralateral of mag 12-14 stars. This GX was extremely faint, at the absolute limit of vision.
Located roughly midway between IC4765 and the mag 11 star TYC9703-1126-1 to the east is PGC 62391. Another very difficult object, virtually at the limit of detection, although it was slightly easier to spot than PGC62393.
To the northwest of IC4765 is the edge on spiral IC 4766. This GX was also extremely faint, but it's NW/SE elongation was visible in momentary glimpses. I'd rate it as difficult as the above PGC members despite its larger size, owing to it's low surface brightness.
The 4th confirmed hit was another edge on spiral, IC 4767, located SSE of IC 4765 on the outer SSE of the cluster. This galaxy appears to be the second-largest of the group on DSS images, but has an extremely low SB. It was incredibly difficult to spot, and when I did manage to see it, it was only in momentary glimpses. After several minutes of intent observation, it's NE/SW elongation was glimpsed. I'd rate this GX as the most difficult of the lot. To find it, I used an isoceles triangle of mag 14-15 stars for reference with the point aiming NE, with the galaxy just off southeast edge and in the same orientation.
About 2 high-power eyepiece fields north/northeast of this complex is a chain of 6 very faint galaxies, dominated by the spiral IC 4769. This GX was not particularly difficult, owing to its relatively high SB core. It was easy to find by using two mag 15+ stars (and a third 14.3 mag star) framing its southern end. The other 5 galaxies are extremely small, faint and escaped my grasp.
Abell S 912
Galaxy cluster in Microscopium. Initially I used a mag of 283x, and after much searching, finally found the main cluster member, the large elliptical NGC 7012. The galaxy is accompanied by a mag 12.1 star on its SSW edge, which provided a good waypoint. 7012 was relatively bright, and I do mean relatively! Simply appeared as a small hazy blob, with perhaps a slight E-W elongation visible.
Only one other cluster member was seen with certainty, and that is PGC 66118, located just to the SE of 7012. This GX appeared almost as bright as 7012, thanks to its compact high SB profile.
DSS images show 2 very small galaxies located in the small gap between 7012 and pgc66118, so I attempted to hunt these down. Increasing power to 353x, and upon careful scrutiny of the field, to my surprise I managed to catch glimpses of the tiny galaxy located in this gap. (Don't know what the catalogue number is). I've attached an image of this cluster with the GX in question arrowed.
To finish off the session I had one last look at Jupiter. I was surprised by how sharp it was, at 272x I could see festoons and swirls in the NEB and SEB, including a nice big rift in the NEB. The main belts were wonderfully detailed, infact haven't seen the planet so sharp and well resolved before! What a nice way to end a great session!
S 38º 00' E 145º20'
Custom 12" F/4.6 dob
10" GSO dob
Intes M500 Mak
4.5" Meade Newtonian
Set of Vixen LVWs + TV barlows + powermates
Astronomik 0III, UHC, H-beta filters
Edited by HellsKitchen (07/26/09 07:08 AM)
AlanK
Reged: 01/26/07
Loc: Auckland, New Zealand
Re: BIG night of observing to the MAX!! new [Re: HellsKitchen]
      #3238941 - 07/26/09 07:18 AM
Thanks for the great report!
That clear sky thing must be really catching as the last couple of nights in Auckland were clear all the way through til dawn and were the most transparent for quite some time - not bad for July
Clear skies!
18 inch f4.5 Obsession #1637
12 inch f5.4 reflector
Just another frozen astronomer
Kumeu Observatory
Auckland NZ
7,276 deep sky objects incl 4,670 ngcs
Who dares - observes!
Patricko
Reged: 01/30/07
Loc: SE New Mexico USA
      #3239112 - 07/26/09 10:06 AM
WOW! That is one amazing night! Catching the impact scar on Jupiter must have been awesome! Your report was very well written and thorough too! Thanks for sharing!
Clear skies,
Patrick
INTERNATIONAL DARK SKY ASSOCIATION
60MM TELESCOPE CLUB!
"You can always have better, but will you ever be happy with what you have?" - Me, myself, and I
Edited by Patricko (07/27/09 12:41 PM)
Jeff Young
Reged: 08/04/05
Loc: Ireland
Re: BIG night of observing to the MAX!! new [Re: Patricko]
      #3239425 - 07/26/09 01:31 PM
Nice report!
Goodness though, over 5 hours. I'm usually chilled to the bone by 3.
-- Jeff.
Nikon 18x70s / UA Millennium                                       Colorado:
Solarscope SF70 / TV Pronto / AP400QMD                       Coronado SolarMax40 DS / Bogen 055+3130
APM MC1610 / Tak FC-100 / AP1200GTO                        Tak Mewlon 250 / AP600EGTO
kroum
Reged: 08/28/08
Loc: Santa Clara, CA
Re: BIG night of observing to the MAX!! new [Re: Jeff Young]
      #3239833 - 07/26/09 05:06 PM
Great report, it sounds just like the night I had last night
I saw the same stuff in sagttarius with my 10 inch and made pretty much the same observations, especially the lagoon and the swan, sound almost the same. I did not go galaxy hunting though I only found m51, and it was pretty disappointing due to some sky glow in that area of the sky. I did see it through a 15inch scope that was there, and that was enough to show the overal spiral structure if you just relaxed your eye and not tried to "see" anything.
I also nabbed the impact site on Jupiter, though I couldn't see it through the 10 inch, I had to go to my 100mm achromat, as it was less disturbed by the seeing conditions than the larger dob. The people I was observing with knew exacly when the best time to see it was, and indeed, it was smack dab in the middle of the planet right when they said it would (right around midnight pacific time). It was almost like a shadow transit in my achromat, I was expecting it to be a bit more diffuse. I am still amazed I managed to see it before it dissippated.
Luckily here in CA, there are no chills in the summer. I spent the whole night in my Doors T-shirt
10in Hardin Optical Dob
100mm f6 Orion Achromat
6in Orion Short Tube Reflector
15X70 Barska Binoculars
32mm Astrola (Boo!)
25mm, 12.5mm Sterling Plossls
20mm Orion Expanse
9mm Hardin (GSO) Plossl
7.5mm Orion Ultrascopic
Ultima 2X shorty barlow
Turn on, tune in, and look through the eyepiece.
AlanK
Reged: 01/26/07
      #3239867 - 07/26/09 05:28 PM
Nice report!
-- Jeff.
It was a double whammy for me over the weekend - a non stop 8 hour stretch on Friday night / Saturday morning and then another non stop 9 hour stretch on Saturday night / Sunday morning! Both nights were damn cold.
My longest ever session was around 13 hours
Clear skies!
Kumeu Observatory
Auckland NZ
John rombi
Reged: 08/14/05
Loc: Sydney, Australia
Re: BIG night of observing to the MAX!! new [Re: AlanK]
      #3239915 - 07/26/09 05:48 PM
Great report, You made me feel like I was there!!
After a rotten year here in Sydney (cloud, cloud, cloud) we have had a couple of weeks of beautiful clear steady skies.
But..........at the beginning of each observing night (the last two Saturdays)just on dusk the clouds roll in and stay until the early hours of Monday morning!!!
There goes another New Moon observing session.
Think I'll take up knitting.
Meade Lightbridge 12" Deluxe (Modified)SiebertOptics
Unitron 4" Alt-Az
Unitron 2.4" Alt-Az
www.macastro.org.au "A New Eye On the Sky"
Edited by John rombi (07/26/09 05:49 PM)
Jim Curry
Reged: 10/29/07
Loc: Maine
Re: BIG night of observing to the MAX!! new [Re: John rombi]
      #3240005 - 07/26/09 06:38 PM
Good for you! I too mobilized my gear for what is turning out to be the cloudiest summer in memory in New ENgland. I got about 3/4 hour in when the fog rolled in from the south.
Vixen 140 refractor
Dain
Reged: 03/24/05
Loc: N.Y. Adirondack Mnts. NGC 4565...
Re: BIG night of observing to the MAX!! new [Re: Jim Curry]
      #3240542 - 07/27/09 12:26 AM
Great report! I'm hoping to get one in here shortly. I'm getting very anxious to get the gear back out again! I love staying out observing all night, especially if the conditions are great. Thanks again for the great read.
Clear skies to All!
Best,
Dain
Adirondack Mountains (my true dark sky site)
@ Cedar River Flow
Local Site
Clear Skies?
Cygnus_x1
Sketcher Extraordinaire
Reged: 11/17/04
Loc: 50N - too far north!
      #3241398 - 07/27/09 03:12 PM
Tell me about it. I was in Australia recently (late April and May) and the weather was atrocious! Clouds and rain all the way from Melbourne to Cairns to Sydney. Fortunately I was there for birding and other things rather than astronomy in particular.
Back in the UK and...it's the same useless rubbish here - as ever. We are having yet another grotty(er than usual) summer.
Visual Deep Sky Observing - being rebuilt
Observing blog
My astronomy event photos on Flickr
12 inch Dob
8 inch Celestron C8 Newtonian
4 inch Meade SCT
8x42 Leica binoculars
Various TeleVue eyepieces
HellsKitchen
Reged: 09/05/08
Re: BIG night of observing to the MAX!! new [Re: Cygnus_x1]
      #3245659 - 07/29/09 09:30 PM
Thanks on commenting on my observation guys!
this clear sky phenomenon certainly hasnt caught on here, it's been cold and cloudy constantly. Stupid sub-arctic maritme climate
This year, the weather has been garbage, but then again in Melbourne that is typical. This was the FIRST clear night this month and was the last for the forseeable future it seems
ahhh, living in a sub-arctic maritime climate, al 'a Iceland, the Shetlands, the Svalbards etc is painfull at best.
S 38º 00' E 145º20'
10" GSO dob
Intes M500 Mak
HellsKitchen
Reged: 09/05/08
      #3245892 - 07/29/09 11:37 PM
Well I've downloaded CartesDu Ciel and the mags of the galaxies are. Not sure if these are visual or photograhic mags, but here they are:
ABELL S805
IC 4765: Mag 12.34
PGC62408: Mag 13.78
PGC62393: Mag 15.12
PGC62391: Mag 14.02
IC 4766: Mag 14.98
IC 4767: Mag 14.36
IC 4769: Mag 14.10
ABELL S912
NGC 7012: Mag 13.80
PGC 66118: Mag 14.00
Still can't get that other small galaxy, doesn't seem to be in any of the databases.
S 38º 00' E 145º20'
10" GSO dob
Intes M500 Mak
Edited by HellsKitchen (07/30/09 01:22 AM)
0 registered and 0 anonymous users are browsing this forum.
Moderator:  Olivier Biot
