cildarith
Reged: 08/26/04
Loc: San Diego, CA
I have always been awestruck by the incredible lunar sketches produced by Harold Hill, Andrew Johnson, Nigel Longshaw, and Roy Bridge. Their works are, IMO, the very pinnacle of lunar sketching. Each of these gentlemen use a technique known as stippling wherein the image is built up by the accumulation of innumerable minute dots.
Here is my first feeble attempt at this rather challenging technique. For a target I opted for something fairly simple, a bit away from the harsh shadows of the terminator, the 64 km crater Macrobius and its environs. This crater has an unremarkable central peak and is noted for its terraced walls. It is near the northwestern shore of Mare Crisium.
Stippling is hard. Sketching without a pencil or other erasable media is also somewhat unnerving.
To improve on what I've done, I probably should have a proper stippling pen (as opposed to a Zebra Jimnie Gel Rollerball ), and/or work at a larger scale than a 3-inch quarter-panel. Any other suggestions from those who have had success with this technique are most welcome!
-------------------- Eric
6" f/6 Parks Newtonian
10x50 Bushnell Binocs
CN Sketch Gallery||MinDat Mineral Gallery
Big Wall
Reged: 12/07/08
Loc: Denver
Wow! Excellent job!
-------------------- Orion XT8I
Celestron C102-HD
Celestron Upclose 10X50 binoculars
mathteacher
Reged: 05/13/07
Loc: SF Bay Area
Excellent!
-------------------- Regards, Mr. Wang . . . . . . . My gallery . . . . . . . I'm a refractor guy!
CR 150-HD - The Hammer, Vixen ED100sf - The Skipper, Orion ST80 - The Pug, Orion 7x50 Scenix
Meade DSI Color, Vixen Porta Mount, Vixen Super Polaris, 2" pipe mount
Please join the International Dark Sky Association
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
Eric,
An outstanding observation of Macrobius and Tisserand using the stippling technique. I believe that you have done an excellent job with the placement of the dots to create realistic shadows and terrain. I think we all "get the point" from this rendering (Ha! Ha!). Thank you for sharing it with us all.
Carlos
Jeremy Perez
Reged: 08/12/04
Loc: Flagstaff, Arizona, USA
That is awesome! So it sounds like you did all the stippling at the eyepiece, instead of drawing contours & stippling later? Congratulations on getting such an excellent result.
Orion SVP 6LT (6" f/8 Newt) || Orion XT8 (8" f/5.9 Dob) || 15x70 Oberwerk Binoculars || Coronado PST
The Belt Of Venus || Sketch Gallery || Sketching Resources || Astro-Photo Gallery
Reged: 06/13/06
Loc: Illinois
Eric, You should not call that feeble, it is a wonderful sketch. I have done some sketching this way in the distant past but nothing astronomical. It looks great I would be proud of a sketch like yours but then all your sketches look great.
Frank
-------------------- my gallery
kraterkid
Reged: 03/07/05
Loc: Jacumba, California
Eric your sketch is beautifully done! I concur about the difficulties of working with this medium though. Did you do this at the eyepiece? I've done some sketches, but always after doing the undersketch in pencil and indicating the albedo values by number for later work inside. Wonderful rendition!
-------------------- Rich
My CN Gallery
cildarith
Reged: 08/26/04
Loc: San Diego, CA
Thanks for the comments, everyone!
I will try the contours-albedo-value-thingy next time. Hopefully that will improve the results, and I won't feel quite so rushed to capture the scene with the moon diving toward the rooftops.
For this attempt I started by inking in the black shadowed areas and worked from dark to progressively lighter areas - which helped speed things along toward the end (fewer dots).
Shannon s
Reged: 06/21/09
Loc: Bartow FL.
Great job, Eric. I haven't looked for a long time. I think they are still sold. Rapidiograph technical pens, are great for stippling - the tips vary in size and they are refillable. Cold press illustration board takes the ink well jus' be careful of hand smears. The only drawback is the constant pounding of the pen tip on the board and will eventually take its toll on the pen tip so watch for drips. Once again great stippling.
-------------------- 4.5" & 12" Reflectors
5" Maksutov
Astroview mount
Orion SSDSI
7x50 Binos
A box of Eps
cildarith
Reged: 08/26/04
Loc: San Diego, CA
Thanks Shannon. As a southpaw, hand smears are one of the banes of my existence...
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
Eric,
Great drawing--one of your better lunar drawings, I think. Thanks for sharing the ups and downs of this technique. Iirc, Harold Hill has some tips about using stippling in the introduction to his book. I believe he uses number values in the rough draft as mentioned above.
This is just a personal preference, but I think you can dispense with the circle template for lunar drawings to some advantage.
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
vennard
Reged: 12/29/08
Loc: Montana
Eric, An excellent drawing. Stippling is what seems to suite me best so I have done a bit over time. The smaller pen point the finer the shading and picture look. I have found a 3x rapidograph works well. When I draw I seem to 'lock' my hand to a spot and as a result create patterns with dot making. The answer to this is to rotate the drawing and work from different angles. If you are doing a drawing near the terminator plan on the view changing after about 30-40 minutes of work, so if you are doing detail, shadows move as the lighting changes and new detail becomes obvious. I do a quick, light pencil sketch and number the values on a 1-5 scale on an overlay to help keep the drawing a bit more precise. If you check out Hill's book you will notice that he had/s a tendency to concentrate on a few details in a particular area featuring the structure he wanted to emphasise, in other words dont take on to big an area or worry to much about all the minutia around the subject, something I have yet to understand compleatly. This style realy does not lend itself to 'studys' but rather a more in depth work. If you continue drawing in this style use a larger pen point (a rapidiograph #1 or 2) while limiting yourself to a single limited subject area I think you will do just fine, and produce excellent drawings.
It seems I have one picture posted in the member gallery under vennard, not one of my best (and a practice at that) from a photo done during last winter snows. It was done with a #3x and a brush for the larger black areas, which ruin the effect, on an illustration board. The initial drawing was 30 min (as if at the telescope)and then put away, with probably a couple of hours finishing it off... Mike
vennard
Reged: 12/29/08
Loc: Montana
PS- I am left handed also... mike
Dee
Reged: 03/12/06
Loc: Ireland
Fantastic wonderful, admirable. !!! I appreciate the intensity of dot making in achieving this sketch.
I have not used a rapidograph for hmmmmmmmmmmmmmmm ??? 30 years , used to love them a lot.
At the moment I am and have been for months producing a reproduction of Galileo’s sketches and am well familiar with thousands of dots.
This method reminds me of pointalism , a drawing craze in the late 1800’s in Europe.
The best thing I like about the method is the creation of the negative space by being very positive about the positive spaces. A super sketch, great technique, and patience.
Dee
cildarith
Reged: 08/26/04
Loc: San Diego, CA
Thanks Mike and Dee!
My second try turned out better, thanks to the excellent suggestions posted here.
Dee
Reged: 03/12/06
Loc: Ireland
Awesome sketch , love that method, well executed
Dee
