Privacy Policy |
Please read our Terms
of Service | Signup and
nickmx50
Reged: 06/25/09
My friend and I are in search of M51. We have been unable to find it our last 3 times out. We have been using his 10" X-Class Dob. His eyepieces include a 30mm 2" GSO, 15mm GSO, and 8mm Stratus. The conditions were good, completely clear, 4/5 seeing, and very good transparency, according to clear dark sky. That night I was able to see andromeda with my 4.5" relfector very well. We bring a laptop top running starry night to help us find objects. Both of us have centered the scope on Alkaid then hopped down and over from there with no luck. We have been using mainly the 30mm for searching. Any help would be appreciated. Thanks
-------------------- Orion 4.5" Skyview reflector
Tele Vue 9mm/T6
Meade 4000 14mm UWA
Bill Weir
Reged: 06/01/04
Loc: Metchosin (Victoria), Canada
Look at this map from Uranometria and notice the little triange of equal brightness stars that M51 is just to the SW of. http://astrosurf.com/jwisn/m51-map.jpg Using the finder scope or even binoculars track down that. They are reasonably bright stars in a finder and the triange is quite noticable. If your sky is reasonably dark you should also notice M51.
Good luck, but I suggest waiting until the Moon is gone.
Bill
-------------------- 6'' Orion SkyQuest
12.5'' f/5 Custom Truss Dob
William Optics 80mm ZenithStar ED II
f/5 25" newtonian on a giant GEM, any time I want
Observing sessions grand total for 2008, 121.
So far in 2009, 92
jack45
Reged: 07/07/03
Loc: Lacey WA
Here's the one web site I use the most. Read the bottom caption and go from there.
http://www.astrosurf.com/jwisn/cvenatici.htm
Clear Skies!
-------------------- 16"f/4.5 Discovery Split Tube/TV Paracorr
12.5"f/5 Discovery PDHQ
Orion f/4.9 XT12"Intelliscope
BV's/Bugress Model 24/Stellarvue Model BV3A
TV Smooth Side Plossls,7.4mm,10.5mm,17mm,21mm,26mm
Nagler EPs 9mm T/2,13mm T/1,16mm T/2,20mm T/2,26mm T/5
Axiom EPs 23mm,31mm LX,22mm Panoptic
UO EPs 5MM,6MM,7MM,12.5MM
Baader Hyp 8mm-24mm Zoom
nickmx50
Reged: 06/25/09
Should we be able to see it with the 30mm? About 40x mag? 2 of 3 times we looked there was a pretty decent sized moon, but we waited for it to go below the horizon. We really seem to looking in the right area according to your charts and our starry night.
Tele Vue 9mm/T6
Meade 4000 14mm UWA
jack45
Reged: 07/07/03
Loc: Lacey WA
I used my 12" scope and is was a little hard to find (26mm TV smooth side plossl). Is the Moon for sure that's killing your chance of seeing it. Still I do think you can view but you just have to find it first. Try a little more mag, around a 20mm or so should help. Your 15mm should do it!
Clear Skies!
Edited by jack45 (08/02/09 06:54 PM)
AlanK
Reged: 01/26/07
Loc: Auckland, New Zealand
Yes although it would be rather small - Both M51 and its companions nuclei would be visible as fuzzy nearly stellar spots surrounded by a larger, fainter round glow. Under dark skies there may be a hint of spiral structure within the outer glow.
-------------------- Clear skies!
18 inch f4.5 Obsession #1637
12 inch f5.4 reflector
Just another frozen astronomer
Kumeu Observatory
Auckland NZ
7,276 deep sky objects incl 4,670 ngcs
Who dares - observes!
Ray4852
Reged: 09/30/08
Loc: Arcade, NY
If you can afford an Argo Navis or sky commander, pick one up. M51 can be a tough galaxy to spot if you don't have dark skies.
-------------------- Home Built 18 dobsonian
Panoptic 27mm
Tele vue 16mm 9mm naglers
Tele vue big barlow
Telrad and DSC
deepsky and skytools software
Bill Weir
Reged: 06/01/04
Your CSC is for Portland so this leads me to the question of how far into the light pollution are you? This is a difficult galaxy pair under light pollution. Like I said, from a reasonably dark location (with no Moon)it is an easy object with even 10X50 binoculars.
Bill
So far in 2009, 92
scopethis
Reged: 05/30/08
Loc: Kingman, Ks
From my dark country observing site, M51 in Ursa Major is visible in an 80mm finder. Using a 10" SCT and very low power (45x), the galaxy appears as a fairly large round cloud that brightens at center with an adjacent small irregular shape dim cloud. Thus said, your equipment is capable, but what about your seeing (darkness) conditions?
nickmx50
Reged: 06/25/09
Bill
Our viewing site is about 24 miles from portland and is used by our local astronomy club. At the star parties I've seen a lot of nice DSO's from other telescopes. Some pretty faint nebulas that are supposed to be harder to see than M51. I think I'll wait till the new moon and try again.
Tele Vue 9mm/T6
Meade 4000 14mm UWA
star drop
Guilty as Charged
Reged: 02/02/08
Loc: Snow Plop, WNY
Wait for the moon to get out of the way.
-------------------- Ted
jack45
Reged: 07/07/03
Loc: Lacey WA
I agree with the above, wait until the Moon goes away.
Clear Skies!
kroum
Reged: 08/28/08
Loc: Santa Clara, CA
Definitely wait for the moon to go away, also and I think this is a bigger deal than you realize, don't use a laptop, it will ruin your night vision, even with the "night vision mode" in starry night, the screen backlight still throws out white light, and it messes up your night vision enough to make galaxies not worth looking at with a 10 inch.
Lastly: It is probably much smaller than your realize. If you are used to looking at andromeda, it will seem like the ring compared to it, aka MUCH smaller. It should be visible in the 30mm eyepiece, but it will be very small. I would use the 15mm GSO after you get close with the 30mm. It will look like two small fuzzies next to each other, one is about twice the size of the other.
With my 10 inch I observed it 2 weeks ago at an orange site (though there were low clouds over the light polluted area), and I observed like I said, two roughly circular spots next to each other, with faint whisps around the larger one, and a brightening between the two. The whisps didn't show the spiral structure of the galaxy, but if you just let your eye relax and not try to look at anything in particular, you do get an impression of it being spiral in nature. Of course the moment you decide to look at the spiral structure, it goes back to being faint whisps.
-------------------- 10in Hardin Optical Dob
100mm f6 Orion Achromat
6in Orion Short Tube Reflector
15X70 Barska Binoculars
32mm Astrola (Boo!)
25mm, 12.5mm Sterling Plossls
20mm Orion Expanse
9mm Hardin (GSO) Plossl
7.5mm Orion Ultrascopic
Ultima 2X shorty barlow
Turn on, tune in, and look through the eyepiece.
candymancan
Reged: 07/10/09
Loc: Virginia
double post sorry
-------------------- Nikon 10x50 Action Binoculars
Zhumell Z10 10" Dobsonian
Tasco 60mm Refractor
Edited by candymancan (08/04/09 09:37 PM)
candymancan
Reged: 07/10/09
Loc: Virginia
I could barely, and let me say this again barely see M51 with my 10" altho i have in red sky's i dont know what you are in. Also the moon will 100% ruin it for you . Unfortunatly at least in my time zone. The moon is up until like 3AM and by that time m51 and the big dipper are gone. So the best time to look for M51 right now is between 8 and 10pm on the East Coast. The moon isnt up in the sky at that time
Its really easy to find the spot where its suppose to be, just find alkaid when is the easy part like you did, then move the scope down and you should see another bright star which is called 24 CVN. Now the important part, move the scope to the left a little and move it down. You should be able to 3 bright stars forming a triangle called Hip 66004/ Hip 65768 and HIP 66116.
Once you find those 3 stars M51 will be directly under HIP 66004 which should be the star on the left of the triangle. If you see that star and look under it and all you see is empty space then that is where M51 is. You can also move to the left and down a little under that 3rd star in the triangle and you should see a red star. If you see that then you are in the right spot M51 is to the right of the red star
You might have to keep the scope and your eye on that spot for 10 minutes. Try moving the scope a tiny fraction in diff directions. Basicly making it wiggle almost, i found when you wiggle it your eye's can catch the faint objects you didnt know were there. Once you see you'll know what to look for from then on.
For me i saw both of the brigh centers for m51 and the other galaxy (is it a galaxy ? next to m51) however i couldnt make out anything else. All i saw was the center's of those 2 objects and they were very very faint looking almost unseeable.
I hope this helps.. also you cant compare this to andromeda. Adromeda is really bright when i first saw it iwas like wow.. M51 is really hard to see compared to m51. Its like looking at a bird on a branch during the day, then trying to find that bird again at night.
Edited by candymancan (08/04/09 09:41 PM)
JayinUT
I'm not Sleepy
Reged: 09/19/08
Loc: Utah
Also, look at what time in the night your going for this. The lower it drops to the horizon, the more muck your going to look through and that will impact seeing M51. Wait for the new moon and probably earlier in the night when M51 is a little bit higher in the sky.
Also, I know in Starry Night Pro (not sure on the other versions) you can print out a specific chart for a specific time and location. Do that and keep your eyes dark adapted as mentioned. Also adjust the map to meet what your seeing in the EP. Good luck, you'll get it.
-------------------- Jay in Utah
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
— Ptolemy, c.150 AD
My Blog
droid
rocketman
Reged: 08/29/04
Loc: ohio
a year or so ago, I posted a similiar post , M51 was impossible to find.....then a freind from a another group suggested I get my mind around what I was really looking for not what I imagined I would see, I know not very technical, but once I stopped looking for a galaxy and began looking for an almost non existant somthing I was amazed that I could find it in my 50mm finder, granted it isnt much , justa a fuzzy something, using your 30mm 2 inch should help too, and as mentioned above wait till the moon is out of the sky.And you have a really clear night, and....well you get the idea,lol. Best of luck to you.
-------------------- 12 inch Truss Reflector "John"
102mm Celestron C102HD
Tasco 7TE5 60mm Classic
Tasco 9TE5 60mm Classic
Celestron Ultima 2000 SCT
Remains of an 8 inch dob
Celestron Comet catcher(orange tube)
1960 Edscorp Space Conquerer 6inch f/8
10x50 Bushnell Binoculars.
11T 4.5 inch Tasco reflector Lunograsso?
60mm Telescope Club
arpruss
Reged: 05/23/08
Loc: Waco, TX
A hint that might work for you since you're using an alt-az mounted scope: if you choose the right time (use Stellarium), M51 will be almost directly down from Alkaid. Around Eugene (I couldn't find Portland in Stellarium), this time will be around 1 am right now. So point the scope to Alkaid at that time, and then very slowly move down from it. You will ideally count off the number of your fields of view that cover the 3.5 degree distance from Alkaid to M51 as you move. Or you may want to follow along on a star chart, noting distinctive star patterns along the way.
If the sky is dark and you have a magnifying finder, you might easily find M51 in the finder: just put Alkaid in the very top of the finder's field of view (assuming it's an upright image finder--otherwise, reverse this), and then M51 should be near the middle or bottom (depending on the finder's field of view).
But as people said, wait a couple of days for the moon to go away.
If 1 am is too late for you, you just need to nudge the scope a bit left before moving it down to M51. I think that's what I did when I was (successfully) looking for M51 in my 68mm finder/travelscope a couple of days ago. (Conditions: green skies; almost full moon but hidden behind mountain; location: BC Canada.)
-------------------- Coulter Odyssey 13.1" split-tube
Coulter Odyssey 8"
Home-made 7.8" F/4 dobsonian travel scope
Home-made 68mm F/5.3 achro (typically used as finder on 13.1")
Skymaster 15x70
BPTs4 8x30
32mm Plossl, 30mm Rini, 27mm Kellner, 13mm Hyperion, 6mm TMB/BO Planetary, Owl 2X Barlow
Palm TX with AstroInfo and RescoViewer
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
Bill
Is your observing site on THIS LIST ?
It looks like most the sites around 20-30 miles from Portland are in the yellow on the LP map. From my experience, galaxies are extremely hard hit by light pollution, even a yellow area might be hard to spot M51. M51 is pretty obvious from a blue site, but I never seen it at my local yellow site. I am sure I could spot it NOW from a yellow site because I know what to look for, but I would imagine it would be very faint. I find M51 to be one of the fainter/softer/puffy galaxies, and the core seems dimmer that most other popular galaxies like M81, M82, M31, etc, which I think makes it harder to spot. As everyone else has stated, forget about it with the moon out. M51 really looked amazing at Nebraska Star Party through my 8 inch newt, I could make out the spiral arms pretty easy.
Good Luck!
Ken
-------------------- Telescopes:
Celestron C6 SCT on CG4 mount
Skywatcher 8 inch F/5 Newt on a GEM
Celestron 8 inch Starhopper Dob
Celestron Oynx 80ED
Celestron C130 Mak
Celestron C102HD
Binoculars:
Nikon 7x35 Action
Nikon 7x50 Action
Zen Ray Summit 10x42
Celestron 10x42 Noble
Orion 10x50 Scenix
Celestron 10x50 Noble
Pentax 12x50 PCF WP II
Celestron 15x70 Skymaster
Oberwerk 20x60
Zhumell 20x80
Locoman
Reged: 03/09/09
Loc: Abilene,Kansas
I've viewed it several times from my yellow zone with no street lights in view and it is barely visible. I can make out the core but faintly and I have tried to find it without my degree circles and it is very difficult to find in my yellow zone but like the droid say's don't look for a galaxy but look for something almost non existant!
-------------------- Zhumell Z10
2 registered and 2 anonymous users are browsing this forum.
Moderator: Olivier Biot
