Observing >> Deep Sky Observing
AndrewJ
Reged: 08/21/09
What beyond our Local Supercluster is brightest?
      #3286501 - 08/21/09 07:44 PM
Hallo, I am new to this board.
Which galaxies and clusters outside the Local Supercluster are brightest or most accessible to a Northern Hemisphere observer (53 degrees north)?
I have an 8 inch dobsonian and my club has 11-14 inch 'scopes (although neither my garden nor their observatory has completely dark skies).
I have read a lot about 3C 273 in Virgo and how that might be within 8 inch range. Also, I am wondering if NGC 1275 and the Perseus Cluster might be achievable as Perseus is in a good position for most of the Fall and Winter. Are these fair targets? Would be grateful for any other suggestions.
AlanK
Reged: 01/26/07
Loc: Auckland, New Zealand
Re: What beyond our Local Supercluster is brightest? new [Re: AndrewJ]
      #3286572 - 08/21/09 08:49 PM
Hi Andrew and welcome to Cloudy Nights!
There are a number of galaxy clusters you can try such as the Pegasus I cluster (centered on NGC 7619) as well as the Pisces cluster (NGC 507 brightest) and AGC 262 (NGC 708 brightest) and AGC 347.
In your 8 inch under those conditions most will appear very small and faint but are worth going for on a good night.
With the Perseus cluster, NGC 1275 should be detectable with a moderate to high power and if you are lucky a few more very faint galaxies will be visible. (I picked out about a dozen with my old 10 inch).
3C 273 should be fairly easy at 13th mag - you just need a finder chart to identify the right 'star'. Can post one if you like.
Clear skies!
18 inch f4.5 Obsession #1637
12 inch f5.4 reflector
Just another frozen astronomer
Kumeu Observatory
Auckland NZ
7,276 deep sky objects incl 4,670 ngcs
Who dares - observes!
AndrewJ
Reged: 08/21/09
Re: What beyond our Local Supercluster is brightest? new [Re: AlanK]
      #3286960 - 08/22/09 01:39 AM
Thanks for the encouraging suggestions, Alan. Pegasus I seems particularly promising: 2 mag 11.5 galaxies and an obvious star pattern nearby. I read on Atlas of the Universe that the Pegasus clusters constitute their own small supercluster separate from the Pisces-Perseus supercluster.
I would be grateful to see a finder map for 3C 273 if you (or anyone) had one handy, but no rush, it will be a few months before Virgo is visible at my lattitude at a reasonable hour.
Is Pegasus ever visible from NZ?
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
      #3287067 - 08/22/09 04:33 AM Attachment (10 downloads)
Here is an DSS image of 3C-273 processed to exclude really faint stars and yield a field of about one degree wide by 0.75 degree high centered on 3C-273. The faintest star shown is around 15th magnitude or so. Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
AlanK
Reged: 01/26/07
      #3287082 - 08/22/09 05:14 AM
You're welcome. All of Pegasus is still visible although upside down compared to the way you see it. On a very clear night M31 can be seen as a fuzz very low in the north. Observationwise for faint stuff, anything below Dec +30N is fine at my location.
Clear skies!
Kumeu Observatory
Auckland NZ
nytecam
Reged: 08/20/05
Loc: London UK
      #3287097 - 08/22/09 05:48 AM
Welcome to CN
I would be grateful to see a finder map for 3C 273 if you (or anyone) had one handy..
Try my quasar homepage via my 70mm Meade for wide/ scaled/ orientated fov
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+e-finder+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9+Lodestar CCDs/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-my videos
AndrewJ
Reged: 08/21/09
      #3288435 - 08/22/09 11:12 PM
David and nytecam, thanks for the maps.
So you can see M31, the LMC, SMC and presumably a high NGC 253? The southern hemisphere sounds great for galaxies.
AlanK
Reged: 01/26/07
      #3289595 - 08/23/09 04:50 PM
It certainly is and the milky way from a dark site is incredible. I do miss looking for objects in Ursa Major and Draco though - most of which never rise.
Clear skies!
Kumeu Observatory
Auckland NZ
1 registered and 2 anonymous users are browsing this forum.
Moderator:  Olivier Biot
