Observing >> Deep Sky Observing
ph2
Reged: 11/28/05
Loc: Aalborg, Denmark
Re: Ultra low-power observing new [Re: Astrojensen]
      #3286221 - 08/21/09 04:24 PM
Here is a picture of some of my low-power and wide-field optics :
  • 2x monocular made from a 50mm Camera lens.
  • Bushnell Xtra-Wide 4x21 Binocular.
  • 2.3x40 Binocular.
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Re: Ultra low-power observing new [Re: ph2]
      #3286448 - 08/21/09 07:04 PM
Ah, I've also experimented making low-power scopes from camera lenses of various focal lengths. Worked pretty well, but I really missed the stereo view offered by binoculars. The stars were far, far sharper in the camera lens scopes than in my current 3x21, though. I did consider making a binocular from two camera lenses, though, but never got around to do it.
I am very interested in your opinion on the 2.3x40's, please tell us how they perform.
Clear skies!
Thomas, Denmark
ph2
Reged: 11/28/05
      #3287700 - 08/22/09 02:03 PM
That's a longer story
In 2006, I visited Yellowstone National Park in the USA. The Milky Way in dark skies at 7700 feet altitude is breathtaking beautiful with numerous star-clouds, dark rifts and knots visible to the naked eye. In a 10x50 binocular a lot of new details could be seen with dark lanes cutting through a luminous background in Ophiuchus and Sagittarius.
But I did have a (small) problem. The naked eye view and the view through 10x50 binocular were like looking at two different skies. Some large objects visible naked eye was not visible or (more correctly) recognizable as such in the binoculars. The 10x50 did not enhance them.
The gain in limiting magnitude from using the naked eyes (a 1x7 binocular!) to a 7x50 or 10x50 binocular is 4.2-4.6 magnitudes. What I needed was something that could bridge the gap. A hypothetical binocular with a gain of 2.1 to 2.3 magnitudes and an exit pupil of 5-7mm should be capable to do just that.
Binoculars with those specifications are rare, but I have managed to obtain two.
This is fixed-focus binocular with a very wide field for watching sport events. It uses (so I’m told) internal mirrors or a combination of mirrors and prisms for erect-image views. I have measured the magnification as 3.5x (6mm exit pupil) and the true field of view as 18 degrees. It should (in theory) give a 2.6 magnitude gain in limiting magnitude.
In daylight, it is actually a quite nice binocular. I like it. The entire surrounding context is there and the connection to the naked eye view is not broken like in a 10x50 binocular.
At night, though, several problems begin to emerge. The fix-focus makes it impossible to make adjustments. Faint star in the binocular do (with my eyes) need something akin to a slight twist on a focuser to make then pinpoint. But that can’t be done resulting in a loss in limiting magnitude.
Furthermore Milky Way star clouds do not get much easier to observe compared to the naked eye. They are bigger but surprisingly dull or dark. The light-transmission through the mirror system does not appear to be very high.
Despite the problems, I am using this binocular as a ‘pre’-finder making good use of the 18 degree wide field. It is a good match to the Pocket Sky Atlas.
2.3x40 Binocular.
The optics is of this binocular is of the Galilean type. It doesn’t need any prisms or mirrors for getting an erect image. Each barrel has only 4 multicoated lenses, resulting in maximum light transmission. The two eyepieces can be focused individually. The magnification is 2.3x (8mm exit-like-pupil). I get up to a 24 degree true field, if I press the eye close enough to the eyepiece. The gain in limiting magnitude, compared to the naked eye, is in theory 1.8 magnitudes.
On paper this binocular would be ideal to bridge to gap between the naked eye and the binocular view, despite the slightly lower gain than my requirement of 2.1 to 2.3 magnitudes.
I tried to get one in Russia, but was told that it no longer was in production. Later I got a Chinese version (clone?) from a dealer in Japan.
I must say, it has not disappointed me. The stars are sharp and Milky Way star clouds (or ordinary clouds lit by the city lights) are not only larger but conspicuously brighter than the naked eye. I know it is impossible for the surface brightness to increase, but subjectively it appears to do so.
Looking through the binocular is in essence like a slightly larger and boosted naked eye view with a 2 magnitude increase in star brightness. If only I had this binocular at Yellowstone ...
Camera lenses.
I have also experimented with using Camera lenses as mini-telescopes. But they are not really the solution to this particular problem. You lose the context in the sky because the image is upside-down - and looking with one eye only does the opposite than enhancing the view.
Astrojensen
Reged: 10/05/08
      #3287773 - 08/22/09 02:51 PM
Hi again
Thanks for your mini-review of the 2.3x40. They sound like something I've been looking for. I think I must save up and get a pair.
Like you, I have found the same thing about camera lenses as mini-telescopes. Still, they offer the potential to make a very unique little binocular, if you are willing to accept the inverted view. I find it not too bothersome or confusing, if the field is large enough.
I have just played with one such lens again, an old 50mm f/1.7, this time coupled to a 17mm plössl. The daytime performance looks good, but it is a bit mushy off-axis, due to the astigmatism in the eyepiece, as f/1.7 is merciless. I wonder how it could perform with a Nagler?
Clear skies!
Thomas, Denmark
PS. Ser lige, at du er fra Ålborg! Der er ikke så mange danskere her på deep-sky foraet.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Ultra low-power observing [Re: Astrojensen]
      #3288049 - 08/22/09 06:03 PM
Thomas,
I have a pair of the 2.3x40 'Owl Eyes', purchased back in the early- to mid-nineties. They were made in Russia, and perform well. But I had to remove the rear 'rings' at the eye end which hold the focusing rings in place. As you know, in order to maximize the FOV of a Galilean optic, the eye must be placed as close as possible to the eye lens. Before removal, the maximum FOV I could obtain was 18-20 degrees. After removal, I can now get the stated 28 degrees. As the math suggests, the apparent FOV is near to 65 degrees--nice!
My next project will probably be a right-angle 4x21 having 17 deg. FOV, using the objectives and eyepieces taken from a Bushnell Xtra-Wide. The 21mm clear aperture Amici prisms will have to have baffles installed near their rear apertures in order to clean up off-axis imagery (some light loss is not objectionable to me).
By the way, I've posted photos of my just-completed Mk II RA bino in my Gallery. For some details, visit the Binocular forum to view the thread I've got going...
Keep experimenting!
Glenn
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
3 registered and 1 anonymous users are browsing this forum.
Moderator:  Olivier Biot
