Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
1st time under dark(er) skies = 3rd sketch - M8 new
      #3292125 - 08/24/09 10:01 PM Attachment (17 downloads)
I had the opportunity to spend last Saturday night under the darkest skies I've seen since I got my TV-85. I live in a white/red zone, and was able to observe from a bluff overlooking the Mississippi river into Minnesota.
I'm still a beginning observer and I spent a number of hours looking at what I _can't_ see back home - DSOs. So I got to see a number of items for the first time - M8, M22, M23, M25... Nothing was like what I imagined from reading or looking at photos.
So I took an hour and made my 3rd ever sketch. It's M8. I used a TV-85 with a 13mm Ethos eyepiece giving a 47x magnification. North is up and West is to the left. I estimated NELM at 6.5 and the skies were a bit hazy (all my maps and sketch paper was damp within 2 hours).
I'm keeping in mind that eventually I'll get better.
Televue TV85 APO on a Half-Hitch alt-az mount
Reged: 06/13/06
Loc: Illinois
Re: 1st time under dark(er) skies = 3rd sketch - M8 new [Re: Ragaisis]
      #3292829 - 08/25/09 09:33 AM
Chris,
It is quite a sight to see M8 in a telescope from a dark site. You have nicely captured the star field and nebulosity of this fine object. Sketching it really makes you look at it with a new eye.
Thanks for posting.
Frank
my gallery
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Re: 1st time under dark(er) skies = 3rd sketch - M8 new [Re: frank5817]
      #3292945 - 08/25/09 10:41 AM
Chris, that looks very good to me. Welcome to the addictive world of sketching the beautiful heavens. Look forward to more of what you do.
Roland
Sketches in members galleries: rolandlinda3
Inspirational stories/sketches at:
www.christworksministries.org
Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
Re: 1st time under dark(er) skies = 3rd sketch - M8 new [Re: rolandlinda3]
      #3292961 - 08/25/09 10:48 AM
I'm rapidly learning things... I have to rework my set up. Sketching while balancing the pad on my lap, pen in one hand, and red flashlight in the other needs to be rethought.
I need some way to attach the light to the pad, and I need some way to dim the light. I'm holding fingers over the lens and spreading them to brighten/dim the thing. My red light is a converted mag lite (addition of red LEDs).
I might have to invest in a dimmable red light and then I saw a reference here to using a lamp gooseneck from Office Depot to attach that to the sketch pad. I'll have to find one of those.
I also need to work on drawing "rounder" stars. They looked just fine at night, but during the day my circles are pathetic. ;-)
Finally, I need to learn how to digitize better. I'm supposed to have a high tone scanner, but it didn't really capture well what I drew. The drawing is much better than the scan indicated. And I'd also like to be able to clean up the digital copy a bit. I don't currently have any tools for that on my Mac. But my wife has Photoshop. I might have to install that...
Chris
Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
      #3292968 - 08/25/09 10:50 AM
BTW, it IS addictive. I want to do more right away.
But I found when I was observing that it's only one sketch a night for me. With each of the 3 that I did I took almost an hour. After that, I saw things that I _wanted_ to sketch, but I just didn't have the intestinal fortitude to go at it.
At this rate, though, if I can make myself do one each time I observe I'll consider that a victory.
rolandlinda3
Reged: 01/24/06
      #3292998 - 08/25/09 11:04 AM
All those procedural things will work out. Lighting has so many options you just have to find one that works best for you. I use 2 or three methods...depending on how big the sketch surface is. Round star marks just takes practice...and not starting too small on your paper. Also, larger paper permits you to take some leeway to make the stars relatively sized to reflect magnitude. Some folks on the forum encouraged me to start with larger paper, which it took some getting used to, but having done it, it has advantages. Also, when you scan and reduce size, some of the "bloopers" sort of disappear. Time on the scope varies dramatically but, as you found out, it can get pretty intense. On a larger target with a complex field, it can take more than one sitting, but normally for me 45 or 50 minutes is about all I can do with a significant break. Also, try short sketching (say 15 minutes) which is an excellent way of practicing quick laydown of an object and star field.
Enjoy.
Roland
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
      #3293037 - 08/25/09 11:23 AM Attachment (9 downloads)
Hello Ragaisis
It's a lot of fun to observe (and to draw) from a dark sky. I live in a suburban region with a lot of lightpollution (NELM 4,5). This sketch was made this summer in the south of France (much darker and the Messierobjects are higher in the sky than in my hometown). At home I observe with a 30 cm Dobson, but on holidays I take a 7 cm refractor (Meade ETX-70). Some people say that a UHC-filter doesn't work with small telescopes. But I had a nice result. Magnification x50.
Clear skies, Jef De Wit
7x50 bino, Meade ETX-70 & Orion Optics UK 12" Dobson
"Bright skies aren't empty skies" (James Mallaney)
Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
Re: 1st time under dark(er) skies = 3rd sketch - M8 new [Re: Jef De Wit]
      #3293300 - 08/25/09 01:36 PM
Jef,
I think that your drawing looks like what I was TRYING to do. ;-)
Thanks for the comparison!
Chris
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
      #3293610 - 08/25/09 04:31 PM
Chris
I didn't posted my drawing to correct yours! My sketch isn't perfect neither. For instance: the placement of the brightest nebula is much to far east... When I make a sketch at the eyepiece it looks like your sketch. At home I do some "make-up". If you make for instance your stars a little bit rounder it will look much nicer. And inverse the colours to white stars and black background. It looks "real".
Have more lots of fun drawing the nightsky!
Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
Re: 1st time under dark(er) skies = 3rd sketch - M new [Re: Jef De Wit]
      #3293902 - 08/25/09 07:06 PM
Let's both try again in a year. It's be interesting to see how far we come.
Chris
kraterkid
Reged: 03/07/05
Loc: Jacumba, California
Re: 1st time under dark(er) skies = 3rd sketch - M new [Re: Ragaisis]
      #3294494 - 08/25/09 11:33 PM
Chris and Jef,
I very much enjoyed your views of M8. They are both beautifully rendered. Don't worry, every sketch you do will bring you closer to your ideal sketch. Just keep doing it!
Rich
My CN Gallery
JayinUT
I'm not Sleepy
Reged: 09/19/08
Loc: Utah
      #3294636 - 08/26/09 01:32 AM
Chris,
I really enjoy your sketch of M8. Please keep posting your sketches as they remind me of the thrill of sketching at the eyepiece. One of the things I like about sketching is the fact that it really improves the amount of detail one is seeing at the EP.
In terms of lighting here is one solution from Jeremy Perez's site: Lighting Solution. I tried to do something similar but couldn't find the necessary resources. So at Walmart one day I found an LED lamp that has a clip on the bottom and where the light cover came off. I bought it for $10.00 LED Clip Light I have modified it (taken out the LED and replaced with red LED, put a red cap on it then a clamp to hold a light) and with the modifications it works with the clipboard I use to sketch on. If I get time this week I'll take pictures and post them up.
Jay in Utah
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
— Ptolemy, c.150 AD
My Blog
starquake
Reged: 02/02/08
Loc: Nádasdladány
      #3294708 - 08/26/09 02:42 AM
We have made some comparison of filters on the Lagoon with some of my astro-friends last month. With a Baader UHC-S filter the nebula was more or less the same as without no filter at all. With a Lumicon UHC filter however, the changes in details were dramatic!
So even the filters designed for the same purpose are different, but Lumicon's UHC filter definitely helps on this nebula.
"At night astronomers agree." /Matthew Prior/
"Astronomers, like burglars and jazz musicians, operate best at night." /Miles Kington/
10x50, 114x900, 300x1500
My astronomical sketches: Graphite Galaxy
Don't take my words too seriously, I might be wrong. And sorry for my English.
TenthEnemy
Reged: 01/21/08
Loc: Maryland
      #3294740 - 08/26/09 03:18 AM
If you stick with it for a year your sketches will improve dramatically, I've even got proof. Here's my own sketches of M8 from last year and this year.
The way you can make stars round is by simply placing the tip of the pencil on the page and rotating it.
Orion XT10
70mm refractor
12x50 binoculars
Ragaisis
Reged: 05/16/08
Loc: Milwaukee, WI
Re: 1st time under dark(er) skies = 3rd sketch - M [Re: kraterkid]
      #3295086 - 08/26/09 09:42 AM
Thanks to everybody for the encouraging words and the great suggestions. I'll keep sketching. I can already tell that it is improving my observing skills, challenging my patience, and giving me something physical to show for my time.
All in all, not a bad thing.
Chris
5 registered and 1 anonymous users are browsing this forum.
Moderator:  Charlie Hein, cildarith
