Telescope Specific Forums >> Meade ETX
considerthestars
Reged: 08/09/06
Loc: Annapolis, MD
497 controller for ETX-80 new
      #3295947 - 08/26/09 04:25 PM
Will the Meade 497 controller work with my ETX-80? I have an opportunity to pick up a new one cheap!!
thanks
Gordon Leidner
Zhumell 10 inch Dob
Nextar 8SE
Meade ETX80 AT
Orion 8x56 Mini Giant Binocs
Hyperion 24mm, 17mm, 13mm, 8mm, 5mm
Meade LPI
caheaton
Reged: 05/26/09
Loc: SW Ohio
Re: 497 controller for ETX-80 new [Re: considerthestars]
      #3295962 - 08/26/09 04:30 PM
I haven't tried it, but from what I've read here and on other sites it works fine. If the ETX isn't listed as one of the scopes during set up, just pick ETX70 and away you go...
Craig
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: 497 controller for ETX-80 new [Re: caheaton]
      #3295991 - 08/26/09 04:40 PM
It should work fine, I use a #497 controller on my ETX-60BB and if I recall right the ETX-80 is on the list. If not you may have to download the latest updater and firmware from Meade. I just updated all of my #497's and it went pretty smoothly.
-John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
Treehopper
Reged: 07/29/08
Loc: Upstate NY
      #3295997 - 08/26/09 04:43 PM
Yes, the 497 will work with the ETX-80. There's an option I believe under Utils that allows you to select which scope you're using, and there's a pre-programmed setting for the ETX-80. You may have to run the train and calibrate routines again to account for the 80's different gear ratios.
Nice find, one of these days I might do the same. I have both the #497 and #494 now, but the controller only "remembers" one scope at a time, hence the need to re-train and calibrate each time you migrate a controller.
Tim
Champion of small aperture scopes everywhere!
Meade ETX-125PE
Meade ETX-80
Celestron FirstScope 76mm Mini-dob
Updated: 09/16/2009
considerthestars
Reged: 08/09/06
Loc: Annapolis, MD
Re: 497 controller for ETX-80 [Re: Treehopper]
      #3296291 - 08/26/09 07:13 PM
Thanks for the answers.
I found this on a Ritz Camera store bargain bin for $13. So you might keep your eyes open at Ritz.
Gordon Leidner
Zhumell 10 inch Dob
Nextar 8SE
Meade ETX80 AT
Meade LPI
4 registered and 5 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
