Equipment Discussions >> Celestron SkyScout and Meade mySky
pmesquita
Reged: 04/04/09
Loc: Lisbon, Portugal
Do MySky and Sky Scout accept data introduction? new
      #3276088 - 08/16/09 04:16 PM
With My Sky or Sky Scout can I input a Messier or NGC object first and then the gizmo takes me there? Or do they just tell me what I'm pointing at? Also do they have a decent number of galaxies and nebulas on their database. On the homepages it seems to be almost stars and planets.
A clear soul is the only thing better than a clear sky - Paulo Mesquita
"Jaws" - XX12 Orion Intelliscope Truss Dob
SW Pro 180mm Maksutov + Giro Mount
31mm T5 Nagler - 22mm T4 Nagler - 13mm Ethos - 7mm Pentax XW
TV Paracorr
2" 1.6 Antares Barlow
2" Astronomik OIII - 2" NPB UHC - 2" Lumicon H-Beta - 2" Baader Moon&SkyGlow
Rigel Red Dot Finder
- 1.25/2" Glatter with Blug
10x50 Bak 4 Binocs
Asus eeePC 1000HE
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
Re: Do MySky and Sky Scout accept data introduction? new [Re: pmesquita]
      #3276455 - 08/16/09 08:09 PM
They both have an impressive catalog. BUT keep in mind that these gadgets are made for approximate location (with in a degree) and will most likely not give you a pinpoint location fine enough to get a small galaxy or nebula into your EP. If you are liking the idea of having one to show you where things are at but want the accuracy to go with it, you are better served in buying a GoTo scope. If however, you would like a gadget to point out where objects are and tell you a little about them while you are star hoping to them with your regular scope, then they are great.
I can hook my MySky up to my scope and it acts as a point and shoot GoTo system (I have an LX200R). Celestron owners can have similar success.
My suggestion is to get a Telrad for your scope and have your mySky/SkyScout as a learning tool and not as a finder.
Adam
12" LX200R, AT80LE
Lunt 60mm Ha & CaK solar scopes
DMK41.AS, DSI Pro, DSI-C, LPI
Denver Astronomical Society
Brighton Astronomical Group
pmesquita
Reged: 04/04/09
Re: Do MySky and Sky Scout accept data introduction? new [Re: snowdragonusa]
      #3276518 - 08/16/09 08:35 PM
I already have a push-to orion 12" inteliscope Dob. and 2 Rigel red dot finders. This idea of My sky would be to apply it to my 180mm/7" SW Pro Mak on the Giro mount.
TV Paracorr
10x50 Bak 4 Binocs
Asus eeePC 1000HE
markan
Reged: 07/13/09
      #3287343 - 08/22/09 09:55 AM
Does the SkyScount or mySky provide the lat/lon when it locates an object? Are they good devices for a Grab & Go setup using an Alt-Az mount and a good red dot finder?
Sky-Watcher 100mm ED f/9 refractor
Sky-Watcher 200mm f/5 reflector
EQ5 mount, Orion SkyView AZ
Reged: 07/06/07
Re: Do MySky and Sky Scout accept data introduction? [Re: markan]
      #3297235 - 08/27/09 08:12 AM
Not quite sure what you mean by and objects "lat/lon"... RA/Dec? Altitude/Azimuth?
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
Moderator:  lineman_16735, Olivier Biot
