Observing >> Deep Sky Observing
Bill Barlow
Reged: 12/03/07
Loc: Overland Park KS
Cats eye nebula
      #3307921 - 09/01/09 10:35 AM
I was trying to star hop to the cats eye nebula last night when the moon was about 85% full. I couldn't find it with my SV 102ED refractor. Is this object too small/faint to see with this type of scope when the moon is this full? I observe at a slightly/somewhat light polluted suburb of KC.
Any help/advice apprecaited. Clear skies.
Bill
Meade 10" SCT ACF OTA on a UA UniStar Deluxe Super 8 altaz mount on a UA heavy duty surveyor tripod and a Manny Miles eyepiece tray.
SV 102ED doublet refractor on a UA UniStar Light mount on a UA light surveyor tripod with a Manny Miles eyepiece tray.
Garrett Optical 10x50 and 12x60 binoculars. Also Garrett Optical 30x100 binoculars mounted on a SLIK Pro 700DX AMT tripod.
Several TV Plossls and Naglers, plus a few very good Celestron Ultima wide TFOV eyepieces.
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
Re: Cats eye nebula new [Re: Bill Barlow]
      #3307940 - 09/01/09 10:46 AM
It's bright enough to see from my city in spite of a full moon, therefore it sounds like you were looking for it in the wrong place. The Cat's Eye is easy to spot even at low power due to the strong color and it's pretty large apparent size even in small telescopes.
Taras
15-inch F/4.5 Dob under construction
10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
A whole bunch of eyepieces, filters and other accessories....
Two curious cats
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: Cats eye nebula new [Re: Achernar]
      #3307980 - 09/01/09 11:11 AM
The color is a very personal thing. I don't see a lot of color at all in the the Cat's Eye. It's mostly grey even on good nights.
lightfever
Reged: 09/27/04
Loc: Macomb Michigan
      #3308829 - 09/01/09 05:36 PM
Was just looking at the Cats eye last night with my 8" and 12.5" scopes, it's one of my favorites and I see a lot of color.
I also live in a light polluted area but never tried to observe it with my 111. I'll check it out tonight.
Mark
Tasco 15-TE 76mm
Sky Watcher 80mm ED
AT-111 Triplet
XT8i (with Woden re-figured mirror)
Discovery 12.5" f/5 Premium DHQ (PDHQ Split-tube Dobsonian)
12.5" f/6.3 Dob (Underconstruction)
Celestron CG-5GT EQ Mount
Celestron C4 EQ Mount
"Life is not about waiting for the storm to pass, but learning to dance in the rain" unknown
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Re: Cats eye nebula new [Re: Hrundi]
      #3308879 - 09/01/09 06:03 PM Attachment (13 downloads)
Some people just don't have the color sensitivity to see the rather striking bluish-green coloration in some of the brighter planetaries. I find the color in NGC 6543 tends to fade somewhat at powers over 150xin my 9.25 inch SCT, although the object still shows interesting detail. Here is a sketch of it I did a number of years ago:
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
David Knisely
Reged: 04/19/04
      #3308927 - 09/01/09 06:27 PM Attachment (15 downloads)
I like to form a narrow "X" to find it using the stars I have circled below in red. They are around 5th magnitude, so you will have to be able to see that faint, but if I put the scope right in the middle of that "X", I am usually on the target. Another possibility is going just under halfway from Zeta Dra to Delta Dra. The Cat's Eye is about 8th magnitude, so it should be visible in a good pair of 10x50 binoculars. Here is the Megastar chart with the X stars circled:
David W. Knisely
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: Cats eye nebula new [Re: David Knisely]
      #3309212 - 09/01/09 08:43 PM
I wish I'd see anything like that, but I've long suspected my blue sensitivity is rather awful. My eyes also have trouble focusing on very blue lights and signs, so maybe it's a sign that I should stick with the red stars.
ursamajor
Reged: 07/24/07
      #3309463 - 09/01/09 10:47 PM
Funny. That's exactly what I do too.
Using a goto scope is like fishing with hand grenades...
candymancan
Reged: 07/10/09
Loc: Virginia
      #3309691 - 09/02/09 01:01 AM
So i assume this is a easy to find nebula ? Or see ? Would i be able to see it with my 10" Im on a nebula Hunt as you can see from my thread
Nikon 10x50 Action Binoculars
Zhumell Z10 10" Dobsonian
Tasco 60mm Refractor
David Knisely
Reged: 04/19/04
Re: Cats eye nebula new [Re: candymancan]
      #3309777 - 09/02/09 02:11 AM
It should be as long as you aren't trying to find it from a well-lit location. I have seen it in my 9x50 finderscope, so it isn't exactly difficult, although to see much detail (other than its overall shape and color) requires something a bit larger than six inches of aperture and a lot of power. It isn't exactly huge, so look at each of the stars carefully as you do your search at low power. Look for one which is a little bluish and fuzzy, then when you have it centered, kick up the power and observe it carefully, as the interior detail is very subtle. Good luck and clear skies to you.
David W. Knisely
scopethis
Reged: 05/30/08
Loc: Kingman, Ks
      #3309907 - 09/02/09 06:04 AM
Per my notes (dark site location) NGC 6543 in Draco is easily seen w/10" SCT. At 62x it is a pretty bright fuzzy star. Higher power reveals a bluish oblong disk. It is also visible in 80mm finder, being that one oddball in FOV that just won't focus.
lightfever
Reged: 09/27/04
      #3310002 - 09/02/09 07:56 AM
In my 8" it appears pretty much like David's drawing both in color and detail.
The 12.5" reveals more detail. I notice a more pronounced border with some striations that fade away toward the center.
Mark
Tasco 15-TE 76mm
Sky Watcher 80mm ED
AT-111 Triplet
Bill Barlow
Reged: 12/03/07
      #3310175 - 09/02/09 09:45 AM
David...
Thanks for the helpful information regarding the cat's eye nebula. When I tried to find it a few nights ago, I located the polygon shape of four stars that make up the head of Draco..then I panned northward about 10 degrees along a line parrell to the imaginary line that the stars Eltanin and Grumium make. I then tried to located the four stars you mentioned to make an "X", but must have been off a bit. I now have a very good idea on where it is and should be able to find it next time. Thanks again and clear skies.
Bill
Achernar
Reged: 02/25/06
      #3310239 - 09/02/09 10:22 AM
The ability to see colors in deep sky objects is highly variable from person to person. It also has to do with your health and how much yellowing there is in the lenses in the eyes too. That is why one person can see a greenish color in a planetary nebula, while another sees it as a blue object. The Cat's Eye has always shown a bluish or blue-green color to me, especially at lower magnifications.
Taras
Two curious cats
dpwoos
Reged: 10/18/06
      #3313691 - 09/03/09 08:26 PM
I use an averted vision scan to help me locate it. Even at low power, when I look directly at it the central star pops out very strongly, but when I look away the nebulosity dominates. So when I scan around in the field using averted vision I notice it as a fuzzy patch, and when I look directly at it the star pops out. Then I know, and can up the magnification.
lymorkiew45
Reged: 12/30/07
Loc: In the dark, and way out there...
Re: Cats eye nebula new [Re: dpwoos]
      #3313709 - 09/03/09 08:36 PM
What aperture are you using for these observations?...clear skies...
Jorgen
Starfinder 16 dob: Zambuto Optics!
DS-10
Orion XT12i: The optics are special!
Z12
All the Lanthanum superwides!
Orion ultrablock filter
9mm Nagler type 6
15mm, 25mm, 35mm Ultrascopics
Orion Shorty Plus barlow
Orion Lazer Collimator
40" Webster: Under Construction
http://cleardarksky.com/c/SanJoseCAkey.html?1
20 years in Southern Dragon Kung Fu, or dragon style embellished in magical arms.
dpwoos
Reged: 10/18/06
Re: Cats eye nebula new [Re: lymorkiew45]
      #3313766 - 09/03/09 09:16 PM
10" f/6 dob. In our 6" f/8 dob I have found that looking directly at the central star nearly kills the nebulosity, like the Blinking Planetary. However, in the 10" the nebulosity doesn't diminish as much as in the 6", but is still very significantly fainter than with even slightly averted vision. It is interesting that not everybody immediately notices that they can kill the nebulosity by concentrating on the central star, but when I prompt them to really stare at it they usually report that they do see the effect.
dpwoos
Reged: 10/18/06
      #3313777 - 09/03/09 09:28 PM
That is a great sketch (as are your others) - it looks exactly like what I see through the eyepiece of my 10" f/6. Maybe the central star could be a bit brighter, but it is very possible that my memory is flawed. This is one of the best targets that I can't point our scopes at with certainty (the other is the Helix), and I frequently have to look around a bit. I am going to try the x pattern the next time I observe it.
Hrundi
Reged: 02/06/08
Loc: Estonia
      #3313783 - 09/03/09 09:36 PM
The stuff I've been hearing in this thread is odd for me. I've heard it said before many times, and yet I can't apply it to myself.
In my 12", the central star of the cat's eye is hard to pick out from the nebulosity, and the blinking planetary doesn't blink. Is this some eye oddity, or a fairly common experience?
For example, with the blinking planetary, even in direct vision the nebulosity nearly overpowers the central star at x120.
dpwoos
Reged: 10/18/06
      #3313814 - 09/03/09 09:50 PM
As I said in my post above, not everybody I have observed with can readily/easily get the nebulosity to dim/disappear and the star to POP. I encourage them to stare at the star, and I don't remember anybody who finally was unable to see the effect, though maybe they are humoring me?! If I were you I would give it another go, as it is a pretty cool thing to see. STARE at it, and I bet it will blink for you. One final thing - I have only observed this stuff from rural-ish Vermont with mag. 5.5-5.9 skies. I don't know what I would see in a more light polluted environment, though I do assume that the effect would show even better with darker skies.
4 registered and 4 anonymous users are browsing this forum.
Moderator:  Olivier Biot
