CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
I was able to make sectional sketch of the Southern hemisphere of Jupiter extending from the South Tropical Zone (STrZ) to the South Polar Region (SPR) on August 23, 2009 (03:40 U.T.) using my 9-inch (23-cm) F/13.5 Maksutov-Cassegrain at 310x. I was able to detect a good amount of detail over the South Temperate Belt (STB, 3/10) over which I noted multiple white ovals of various sizes. The South Tropical Zone (STrZ) appeared bright (7/10) with a dark (3/10) condensation towards the preceding limb as well as a thin, dark (3/10) projection extending from the northern border of the NEB. The South Temperate Zone (STZ) appeared thin and shaded to bright (6-7/10). The South South Temperate Belt (SSTB) appeared dark to shaded (3-4/10), thin and irregular. The South South Temperate Zone (SSTZ) appeared thin and shaded (6/10). The South South South Temperate Belt (SSSTB) appeared broad and dusky (4/10). The South South South Temperate Zone (SSSTZ) appeared thin and shaded (6/10). The South Polar Region (SPR) appeared dark to dusky (3-4/10) and mottled.
A digital image produced using Photoshop CS3.
Carlos
JayinUT
I'm not Sleepy
Reged: 09/19/08
Loc: Utah
Carlos,
I love your rendering of the South Polar Region and the white ovals. I love your capture and sketch of thin dark projection. Well done!!!!
-------------------- Jay in Utah
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
— Ptolemy, c.150 AD
My Blog
Tommy5
Reged: 03/28/04
Loc: Chicagoland
Very nice sharp detailed sketch, maybe micheal's sectional sketch has started a new trend, you must have had quite a view to get all of that small detail, thanks for posting.
kraterkid
Reged: 03/07/05
Loc: Jacumba, California
Carlos, amazingly detailed view of the South Polar Region of Jupiter. Beautiful color, an awesome observation!
-------------------- Rich
My CN Gallery
Sol Robbins
Reged: 12/01/03
Great detailed sketched observation.
The details you present are amongst the more difficult ones to suss out unless you dig deep.
These are the kind of details that most folks overlook or can't be sure of. It takes a bit of time to not only realize that these details are there, but also a very quick response time to quickly render and visually understand what has been seen. This is just on a simple visual and relatively non-intellectual level.
See and sketch first...., think later.
Great Photoshop CS3 sketch Carlos! They just keep getting better and better.
-------------------- S.R.
Shannon s
Reged: 06/21/09
Loc: Bartow FL.
Carlos, that is unbelievable. I need to get some higher power Eps or something. That is unreal, my highest is 6mm even barlowed I can't see that. Steady skies over here on the west or should I say central FL would be nice. Hell I would be happy with clear skies, anyway - stunning job.
-------------------- 4.5" & 12" Reflectors
5" Maksutov
Astroview mount
Orion SSDSI
7x50 Binos
A box of Eps
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
Carlos,
A most excellent sketch from you and your trusty Mak-Cas. As Sol mentioned, those high latitude details are very difficult to detect and render--I'm going to have to try harder.
You are El Supremo.
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
Reged: 06/13/06
Loc: Illinois
Carlos,
That level of detail is beyond awesome. Jupiter would need to reach much higher into my sky to see white ovals that small on a near perfect night. Seeing it would only be step one rendering the details viewed would be the high hurdle. Stunning work Carlos.
Frank
-------------------- my gallery
Aldebaran
Reged: 09/30/06
Loc: Turku, Finland
Carlos,
Very accurate and detailed sketch! Very impressive work!
-------------------- Juha
Instruments:
10'' Newton
3'' Lens (RFT)
7x18 Binos
http://juhansivut.pp.fi/Deepsky (my deep sky pages)
Taivaanpallo (my amateur astronomy blog in finnish)
CarlosEH
Reged: 01/19/05
Thank you all very much for the kind compliments on my Jupiter South Polar Region (SPR) sectional sketch. It was fun being able to see so much detail over this region of Jupiter. An observer of Jupiter may at times note a bright oval or dark condensation over the polar regions (except of course for comets (WCIS) slamming into this part of Jupiter!) so when such detail is visible it is a pleasure. The best of luck in your own observations of Jupiter.
Carlos
idp
journeyman
Reged: 08/21/09
Loc: New Haven, CT
Absolutely awesome. What technique did you use to get such a realistic rendering of hues and colors? This amazes me even more that the amount of details.
IDP
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Very nice. I am sure it was a pleasure with that planet-killer scope to catch a good night. The sketch shows you must have enjoyed the concentrated observing time.
-------------------- Roland
Sketches in members galleries: rolandlinda3
Inspirational stories/sketches at:
www.christworksministries.org
CarlosEH
Reged: 01/19/05
IDP and Roland,
Thank you both for the compliments on my sectional sketch of Jupiter's South Polar Region (SPR). It was exciting seeing so much detail over this region.
I used my Wacom digital tablet and Photoshop (CS3) to create the rendering above. I first created a larger Jupiter disk than cropped the polar region in order to focus on that. The outlines of the detail were lightly placed then using the airbrush function I added the colors visible until agreeing with what I was observing.
Carlos
