waldi
Reged: 07/14/06
RA-88 or Refractor 120mm , F-5? new
      #3332822 - 09/14/09 07:04 AM
what will be better for DS?
Edited by waldi (09/14/09 07:05 AM)
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: RA-88 or Refractor 120mm , F-5? new [Re: waldi]
      #3333977 - 09/14/09 07:42 PM
Considering that the RA88 works at a real aperture closer to 77-78mm due to light cone clipping by the prisms, I'd probably lean more toward the 120mm short tube. And this is coming from a dyed-in-the-wool, foaming-at-the-mouth zealot when it comes to two-eyed viewing!
Another limitation I just can't abide re. the RA88; it's largest field can never get above about 2.5 degrees, no matter what eyepiece you could slap on the back end. That's because of the small-ish prism rear aperture, which moreover the focal surface lies *very* close to, thus limiting eyepiece choices.
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
charen
Reged: 05/28/05
Loc: New Zealand
Re: RA-88 or Refractor 120mm , F-5? new [Re: GlennLeDrew]
      #3334083 - 09/14/09 08:55 PM
It is difficult to compare one eyed viewing to two eyed viewing. I use my Binoviewer with my ED120 almost 90 % of the time and mainly for planetary use. I also use my Oberwerk 100-45 B.T. for most of my dark sky use. I can go from 20x -80 x and I can get really jaw dropping images esp. on low power, wide field, dark sky, Milky Way viewing. With 2x eyes I 'see more' as it is so much more relaxing and 2x eyes I can view for hours without eyestrain. Hovewever if you have to choose from the 2x you mentioned above the 120 mm S/T may be superior for the reasons Glenn said - but it is still one eyed viewing. If however if was between a 100-45 B.T and a 120 S/T I would certainly go for the 100-45 B.T.
Chris
35 binos.
80mm Cat.
WO66ED
SV NH 80mm / EQ3
Meade 8in.LX90
Skywatcher Equinox ED120 / Goto HEQ5.
waldi
Reged: 07/14/06
Re: RA-88 or Refractor 120mm , F-5? new [Re: charen]
      #3335210 - 09/15/09 12:53 PM
you wrote "real aperture closer to 77-78mm" Ok I agree but if we will count like this:
78 x 1.4 = 109 aperature!! and more comfortable observation
am I think right?
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: RA-88 or Refractor 120mm , F-5? [Re: waldi]
      #3335259 - 09/15/09 01:20 PM
am I think right?
Sorry, not correct
Pi r squared x 1.4 then take square root = effective aperture = 92
compared to the 120ST with a binoviewer
area sqrd / 2 x 1.4 = 100
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
11 registered and 2 anonymous users are browsing this forum.
Moderator:  EdZ
