headinsky
Reged: 12/01/06
Hi all, after finally completeing my polar alignment useing the drift methord i brought up the calibrate sensor menu in the autostar II HANDBOX,but when i press enter the HBx just tells me that the mount is not Alz E1,can anyone explain the meaning of this message?. The only thing i can think of is that after selecting polar as my mount, the autostar will not use calibrate sensors. Also after going in to the train drive (Ra), when i push mode to exit does this automatically save the training session?,or do i have to select update after pressing the mode button.
regards ian
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
The LNT sensors are applicable only to using the fork mount "level" i.e. in alt az mode. Calibration is used for getting the LNT module to recognise north & level more accurately. If your scope is on a wedge, sensor calibration is not needed, in fact you might as well remove the LNT module.
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Calibrating sensors adjusts the LNT module for YOUR SITE'S magnetic deviation in alt az mode.
-------------------- LX90 8" LNT, SV Nighthawk & TelePOD, ETX 90, Orion XT10i, SV 80/9d, 20x80 binoculars www.texasastro.org
"The secret to creativity is knowing how to hide your sources." - Albert Einstein
headinsky
Reged: 12/01/06
THANKYOU Brian & Joe for clearing the lnt up for me,
i have had time to goe through appendix 1 page's 68/69 OF THE USER MANUAL which helped me clarify somewhat the updateing steps.
Many thanks fella's for taking the timeout to reply.
regards
Ian
Edited by headinsky (09/15/09 06:41 PM)
0 registered and 2 anonymous users are browsing this forum.
Moderator: Joad
