Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
A replacement for Ebony Star Formica
      #3338205 - 09/16/09 09:27 PM
Today I was looking for some Ebony Star Formica for my 15-inch Dob that is being built right now. In fact, I mostly finished the mirror box and the altitude bearings. But I got a surprise when the salesman told me Wilson Art no longer makes the stuff. Has anyone here found another kind of Formica that works well or knows where I can find some Ebony Star? I need enough to cover two hollow arc 12-inches in radius and a rocker box that will be about 20-inches square.
Taras
15-inch F/4.5 Dob under construction
10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
A whole bunch of eyepieces, filters and other accessories....
Two curious cats
davidc
Reged: 11/24/05
Loc: Mesa, Arizona
Re: A replacement for Ebony Star Formica new [Re: Achernar]
      #3338284 - 09/16/09 10:11 PM
Teras,
I use Fiberglass Re-inforced Plastic for my altitude bearings, and I can move my ota up and down with 2 fingers. I was told that is what was popular before Ebony Star came around. I cemented them down with contact cement, and 2 c-clamps. Cut into strips with an electric jig saw with a fine blade. I bought mine from a gentleman in my club. Search Google for Fiberglass Re-inforced Plastic.
David
13.1 Inch-F/4.8 Royce Conical Homebuilt Dob
8 Inch-F/5 Orion Dob
4 Inch Celestron Reflector Camping Scope
25mm Meade W/A Ep
13mm Orion Stratus Ep
8mm Orion Stratus Ep
2X Meade Barlow
Meade Cheshire/Sight Tube
East Valley Astronomy Club
Searching For Rainbows In The Dark
timo4352
Reged: 04/16/07
Loc: Northeast Ohio
      #3338347 - 09/16/09 10:48 PM
Try Scopestuff or Meridian Telescopes
Orion 3.6CA Reflector
and 2 homebrew scopes --
8" Hubble Bubble ballscope
8" F/8 CHief - nearing completion
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #3338411 - 09/16/09 11:19 PM
My local cabinet shop had Ebony Star strips sufficient for altitude bearings, and I got them for $5. For the ground board I would have had to custom order a 4 x 8 sheet for about $130. So, Ebony Star can still be had.
Tempting as it was, I read about #45 Facet here on CN, so I got a piece for about $10. The scope should be operational in 2-3 weeks.
Jeff Morgan
Prescott, AZ
Wile E. Coyote School of Telescope Making
ausastronomer
Reged: 06/30/03
Loc: NSW Central Coast (Australia)
Re: A replacement for Ebony Star Formica new [Re: Jeff Morgan]
      #3343041 - 09/19/09 12:12 PM
Not for long. It is just the old stock sitting around that is available now and being bought up. Wilson Art haven't manufactured it for almost 2 years. It hasn't been available anywhere in Australia for almost a year.
John Bambury
AS of NSW
AS of Hunter Valley
18"/F4.5 Obsession fully loaded with OMI optics
14"/F4.5 SDM fully loaded with Zambuto Optics
10"/F5 Newtonian with Argo Navis
Lots of Pentax XW's. 12mm & 17mm Nagler T4's, 31mm Nagler T5 & 13mm ETHOS. TV Paracorr and 1.8X TV Barlow and 2.5X TV Powermate
Achernar
Reged: 02/25/06
      #3343148 - 09/19/09 01:16 PM
How close an equivalent is #45 Facet to Ebony Star?
Taras
Two curious cats
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #3344713 - 09/20/09 12:20 PM
Ross Sackett (sp?) has posted about it on CN back in the late spring, results favorable. Perhaps he will notice this thread and give us an update?
Jeff Morgan
Prescott, AZ
RossSackett
Reged: 08/17/07
Loc: Memphis, TN
      #3344772 - 09/20/09 01:00 PM
Hi Jeff and all,
I used 45 Facet on a 6" f/5 single pole travel telescope this summer. While the scope was quite light and thus perhaps not typical, both the horizontal and elevation motions were very smooth without objectionable stiction. Its performance was comparable to old Ebony Star in a similar light 8" travel telescope. Now I wouldn't necessarily describe its motion as "buttery", which I've only felt (with Ebony Star or something else) with heavier scopes starting with "sidewalk" sonotube 6" or 8"ers.
I did the expedient teflon-block test with the microtextured 45 Facet and the golfball dimpled Formica Sparkle finishes, and they come out about the same. Next scope will be Sparkle, just to see how that works.
However, I have come to think that a bearing dressing like SailKote makes more of a difference than laminate choice. It consistently reproduces the feeling that the scope is just *oozing* in the direction I want it to go that I remember from old Ebony Star.
But even more important than that are the observer's motor habits. If you use your scope enough you naturally and unconsciously will tend to compensate for mechanical issues like friction, stiction, and scope flexure; and even for optical aberrations like stig, coma, and curved fields. Making a date with your telescope out under the stars and getting to know one another's quirks is more important than choosing the right bearing surface or plywood.
Ross
"A craftsman relies on science when the state of knowledge allows it, tradition and experience when it does not, and makes art whenever he can."
12 scopes from 4.25 to 18" and a 24" in progress. 12 ATM awards. Webpage: http://stardazed.com/ Some more scope pix at http://www.flickr.com/photos/8315630@N04/
Anagrams: Amateur astronomer = A mature moon-starer; Dobsonian maker = Debonair as monk
Achernar
Reged: 02/25/06
Re: A replacement for Ebony Star Formica new [Re: RossSackett]
      #3345321 - 09/20/09 06:18 PM
The reason why I was asking this question, is that I have found it is possible to make a telescope move too easily, as though it has ball bearings on both axis and moves in the slightest breeze. I guess I'm going to bring a piece of Teflon and look like the crazy guy asking about Formica, LOL.
Taras
Two curious cats
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
      #3345349 - 09/20/09 06:29 PM
Ebony Star is a colour for a product from Wilsonart (and it's really the "Touchstone" finish you want, the colour doesn't matter).
Formica also has different textures, and apparently in Europe you want the -75 "quarry" finish and in he US the #42 "sparkle" finish.
400mm f/4.46 self made Dobsonian on Tom Osypowski equatorial platform
Orion Starblast (114mm f/4 reflector, Alt/Az)
kb4mxo
Reged: 07/17/06
      #3345577 - 09/20/09 08:58 PM
Working on a 8" dob and used Wilsonart HD and works just fine. I ordered it from a local dealer and can't see using anything else.
Good luck on your project.
Steve
Vincent Becker
Reged: 09/16/08
Loc: France
Re: A replacement for Ebony Star Formica new [Re: kb4mxo]
      #3346111 - 09/21/09 03:17 AM
On my 8" dob I used nylon strap for the altitude bearings. It works very well, is readily available and very cheap.
For the azimut motion, I used one teflon pad for stiction and two sets of roller bearings (used in rolleblades, very cheap too) on polyurethane-covered wood.
The movements are very smooth and allow to hand-track objects at 375x without difficulty.
It's hard to extrapolate if this setup will work as well on a 15". I'll give it a try on my 16" which is under construction
Vincent Becker
10" dobsonian on EQ platform (home-made by my father)
8" string newtonian as travelscope (home-made by myself )
Orion 80ED and GSO 200/1000 on Atlas EQ-G for astro-imaging
sec_1951
Reged: 01/26/06
Loc: Phoenix, Arizona
      #3351202 - 09/23/09 10:03 AM
I just came across a Wilsonart laminate called Ebony Fusion 1799-7. I have been using the 45 Facet and replaced it with the Fusion. After a quick test in an alt-az for an 80 mm refractor, I think I can recommend it for further investigation by other DIYers.
My impression was that it was very smooth but with more friction than the 45. That is to say that while the movement was smoother it took more effort to make the movement. Stiction was seemingly non-existent and the small amount of backlash I had with the 45 disappeared. The increase in friction was a little problematical as you could notice the difference but the overall improvement in the motion more than made up for it.
I use 2 teflon bearings on both the alt and az surfaces and would also recommend trying that out. (ie the layout is as follows: laminate / teflon / teflon /laminate -- hope that makes sense.)
As a side note I have tried using the nylon strap as suggested by Vincent Becker and found it to be very good also. If they made that stuff in sheets it'd probably be on everyone's list.
Steve C.
Achernar
Reged: 02/25/06
Re: A replacement for Ebony Star Formica new [Re: sixela]
      #3364916 - 09/29/09 10:15 PM
I got some good news on the Formica front. I was able to find some with the sparkle finish, and with a small piece of Teflon and Ebony Star I found it seems to work exactly the same. So I bought a large scrap piece from a local cabinet supplier and already put it on the altitude bearings. Thanks for the advice everyone, it saved me a lot of trouble.
Taras
Two curious cats
ndelo
Reged: 08/02/06
Loc: Light-polluted New Jersey
Re: A replacement for Ebony Star Formica new [Re: davidc]
      #3365803 - 09/30/09 10:51 AM
Teras,
David
I know you already found your soultion, but I have to add that the white Fiberglass Re-inforced Plastic with the bubbly surface (found in large, inexpensive sheets in Lowes or Home Depot) works great. I used it on the azimuth bearing for a homebuilt 18' dob and, after a two coats of Turtle wax, my dob has extremely buttery movements and can be pushed about with mere fingertips.
Anyone struggling to find Ebony Star can sleep well knowing that this stuff makes a fine replacement and is readily availible.
imhotep
Reged: 02/14/07
Loc: Tampa, FL
Re: A replacement for Ebony Star Formica new [Re: ndelo]
      #3365843 - 09/30/09 11:10 AM
FYI for anyone interested, ScopeStuff has stock on every single item listed on their website under the heading of Ebony Star.
I recently made the same discovery about Ebony Star being discontinued after placing an order with Meridian. They've several items on their website that aren't being stocked by them anymore, including kydex and teflon (their words, not mine).
Curt
8" F5 Newtonian Astrograph
Orion 80ED CUSTOM
Edmund Optics 4.25" 'Palomar' Newtonian, 1968 vintage
Achernar
Reged: 02/25/06
      #3365918 - 09/30/09 11:51 AM
I did find FRP at the local Lowe's but I wasn't going to be using anywhere near a whole sheet of the stuff. At more than 30 dollars a sheet, it wasn't the bargain that a three by four foot piece of Formica was at five bucks. I now have enough for two, even three telescopes. Finding Formica with a Touchstone or Sparkle finish isn't easy anymore, therefore as you've pointed out FRP is a viable alternative. I would have just as soon used FRP if I could have bought a scrap piece large enough for the job.
Taras
Two curious cats
arpruss
Reged: 05/23/08
Loc: Waco, TX
      #3366057 - 09/30/09 12:58 PM
For azimuth bearings, if the pads fit within a 12" circle, one can just drop in a vinyl record. Those can be had on ebay for no more than $2 shipped (I got one for $0.01 shipped and another for $2). I use one in my 13" and in my 8" travel scope, and Teflon on the record works great. There are also 16" radio transcription records, but they are a bit more expensive and I haven't tried them.
This won't work for alt bearings, of course, nor for larger az bearings.
Coulter Odyssey 13.1" split-tube
Coulter Odyssey 8"
Home-made 7.8" F/4 dobsonian travel scope
Home-made 68mm F/5.3 achro (typically used as finder on 13.1")
Skymaster 15x70
BPTs4 8x30
32mm Plossl, 30mm Rini, 27mm Kellner, 13mm Hyperion, 6mm TMB/BO Planetary, Owl 2X Barlow
Palm TX with AstroInfo and RescoViewer
9 registered and 7 anonymous users are browsing this forum.
