Observing >> Deep Sky Observing
AndrewJ
Reged: 08/21/09
Do globulars all look the same?
      #3340693 - 09/18/09 01:07 AM
I have seen M2, 13, 15, 22 and 56 (faint) with our 8 inch. Frankly, they all look the same to me (although I think M15 is the most impressive). Is there something I am missing? Are there any unusual looking globulars?
I still think they are beautiful and like to reflect that their stars are as old as the Universe.
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Re: Do globulars all look the same? new [Re: AndrewJ]
      #3340710 - 09/18/09 01:18 AM
Their overall form is somewhat similar, but there are definite differences between one globular and the next. Some are highly concentrated at the center, while others have a more mild and broad central concentration. Some are quite bright and easy, while others are poor and faint, becoming challenge objects in modest sized amateur telescopes. An example of one with a distinct feature is M5. It has a small dense almost star-like core embedded in its brighter central region. That almost nuclear core at really high power (400x and up) is made up of three or four very closely spaced stars in a sort of triangle, but it takes really high power and excellent seeing to resolve it. Another example is M22, which is larger and rich but is somewhat oval in overall shape, and does not have an extremely concentrated core region. M4 has the famous central 'bar' of stars running across its core, while NGC 6712 is the "weird" globular, with an almost triangular shape or a slightly off-center core region when viewed in modest apertures. Each globular has its own charm which is best realized by viewing as many of them as you can (and in as large an aperture as you have access to). Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
Man in a Tub
Not Retired!, But a little cranky!!!
Reged: 10/28/08
Loc: San Francisco, CA
      #3340747 - 09/18/09 02:06 AM
Just as there is the widely-accepted Trumpler classification of open clusters, there is also the Shapley/Sawyer classification of globular clusters.
In addition to Dave's excellent, observational descriptions, this link should help:
Globular cluster classification
Although I only use binoculars, I detect differences in my unresolved views of globular clusters.
Best Regards,
Todd
Brunton Eterna 15x51 ° Garrett Optical Signature Series 15x70
Nikon Action EX 12x50 ° Oberwerk 15x60 and 20x80 Standard
Orion Paragon Plus Mount and Paragon XHD Tripod
Garrett Optical Series 2000 Grip-Action Monopod
scopethis
Reged: 05/30/08
Loc: Kingman, Ks
Re: Do globulars all look the same? new [Re: Man in a Tub]
      #3340995 - 09/18/09 08:57 AM
NGC 6342 in Oph is a globular that is elongated, pretty unique viewing.
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: Do globulars all look the same? new [Re: scopethis]
      #3341034 - 09/18/09 09:32 AM
In my opinion, the bright globs, while they all have their merits, are not that distinct. Of the messier globs, I'd say worth noting are M15 and M71, and M13 for the rather obvious star strands.
The real prize globs, however, are the dimmer ones. The ones where you can just resolve a bit, or where you're actually working for the detail, as opposed to just staring and nodding. And the very dim ones, of course, are like galaxies, so all is good here as well
Of the NGC globs, I'd say ngc 7006 is worth taking a look out. NGC 5466 is great, especially if you contrast it with M3. And my favorite NGC glob is NGC 6712. Take a gander at m11 to see an 'almost glob' as well.
Takman
Reged: 02/25/09
Loc: Maple, ON - Canada
Re: Do globulars all look the same? new [Re: Hrundi]
      #3341109 - 09/18/09 10:28 AM
I've found that each globular has its own distinct characteristics. Initially, when I first started astronomy, I thought all globulars looked the same. Just a blob of stars. Now, I find each one has unique characteristics. For example, if you look closely at M13, there's a dark 3 bladed propellor shape that is visible but illusive.
Takahashi TOA-130F
Celestron C-11/C-8 with FASTAR
William Optics Zenithstar 66 SD/ED Petzval
Astro-Physics Mach1 GTO/Celestron AS-GT
TeleVue Naglers 26mm, 13mm, 7mm and 3.5mm
AndrewJ
Reged: 08/21/09
      #3341420 - 09/18/09 01:29 PM
Sounds as if I have been somewhat dismissive of globulars.
M22 was the first I went looking for before Sagittarius disappeared from my lattitude. Perhaps I might have noted its distinctness had I then had anything to compare it with.
This sounds interesting, out in intergalactic space, and Delphinus is such a cute and conveniently located constellation.
Hrundi
Reged: 02/06/08
Loc: Estonia
      #3341452 - 09/18/09 01:52 PM
It's (NGC 7006) not going to resolve, but it's the mindset that counts with that one.
Another one worth a glance is M80 in scorpius. Even being as low as it is for me (not above 7 degrees) it was interesting due to its size.
David Knisely
Reged: 04/19/04
      #3341968 - 09/18/09 07:21 PM
If you want one that is *really* way out there, check out G1, a small faint globular that is part of M31's big group of globulars:
G1: R.A. 0h 32m 46.3" Dec. +39 deg. 34' 31" (mag. 13.7).
In my 10 inch, it is a rather tiny but fairly easily seen faint fuzzy spot. At around 2.4 million light years away, it ranks as one of the most distant globulars clusters visible in many modest amateur telescopes (it has been seen in a good six inch on occasion). Clear skies to you.
David W. Knisely
rocco13
Got Milk?
Reged: 07/29/06
Loc: Phoenix, Arizona
Re: Do globulars all look the same? new [Re: David Knisely]
      #3342044 - 09/18/09 08:10 PM
Observed 7006 a few nights ago, but was more impressed by 6934, which is in the same part of the sky, just south of Delphinus.
5466, 5053, and even M56, are couple of fainter, yet interesting globs that are relatively easy to find.
Rocco
Zhumell Z12
Super C8 (1984 vintage)
Celestron 102 f/5
and a cheap pair of binoculars
AndrewJ
Reged: 08/21/09
      #3342520 - 09/19/09 03:28 AM
I have just had a look at 7006, a pleasant hop in the finder and recognisably a globular. Its long, lonely orbit made me think of it as like a Pluto of globulars.
Well, M32 looks like a globular to me although my yard isn't dark enough to get the halo.
Jim Curry
Reged: 10/29/07
Loc: Maine
      #3342694 - 09/19/09 07:58 AM
>I have just had a look at 7006, a pleasant hop in the finder and recognisably a globular. Its long, lonely orbit made me think of it as like a Pluto of globulars.<
Don't compare it to Pluto. Some convention of globular experts will want to downgrade it to a dwarf globular.
Vixen 140 refractor
azure1961p
Reged: 01/17/09
      #3343452 - 09/19/09 03:58 PM
They all generally are roundish, highly concentrated, glitter well and have chains eminating from the core.
Try M4 for a different kind of globular. Has an unusual chain of stars across the middle. Some clusters are ovalish, others are super faint and defy resolution in all but the greatest sized dobs. Concentrations vary too.
Are they the same - well yes they all have that round , high concentration trait. You'll never see one for example that is halh globular while the opposite half is morphing into an open cluster.
I'm glad you like 15. One of my favs. M92 is actually nicer than 13 in some respects. M56 is a reality check that all globulars arent equally bright. M22 is a beauty but lower than i like to go.
You know whats a hell of an open cluster that approaches globular intensity that is triangular instead of circular?
M37 in Auriga.
WOW.
At 70x its just this dense dense stellar powder with a beautiful red star in the center.
My all time fav open cluster in the heavens [that i can see]. I'll proudly stack against a lot of globulars.
Inicidentally, dont bother googling pix of it. The visual is an experience unto itself and any pic ive ever seen totally destroys the super fine texture this terrific object has.
Try it out. In terms of satisfaction you may be putting it up there next to your fav globs.
Pete
Edited by azure1961p (09/19/09 04:00 PM)
AndrewJ
Reged: 08/21/09
Re: Do globulars all look the same? new [Re: Jim Curry]
      #3343517 - 09/19/09 04:56 PM
M37 in Auriga.
WOW. My all time fav open cluster in the heavens [that i can see].
I like the sound of M37's location. Also, I don't think I have ever knowingly looked at an object in the galactic disk outside of the Orion Arm. I shall add it to my list.
And so they should! We must keep changing our definitions to keep the true globulars within single figures. Also, we must define globular by what it orbits and not by what it is so that any globular slungshot into intergalactic space through galactic interactions immediately changes in nature.
David Knisely
Reged: 04/19/04
      #3344211 - 09/20/09 01:43 AM
M37 in Auriga.
Globular clusters are generally defined by their overall form (roughly spherical with some central concentration), their numerical populations (from around 100,000 to several million component stars), and their "metalicity" (globular cluster stars tend to have fewer heavier elements than stars in most open clusters and tend to be older). M37 is clearly not a globular cluster, as it is more triangular in shape and has no distinct denser central core of stars. It has only about 150 stars brighter than magnitude 12.5 (at most, its total population is probably less than 500 stars). Its stars are considerably younger than those in most typical globular clusters. It is clearly a Population I object rather than being Population II as most globular clusters are. M37 is a great open star cluster well worth a good long look, but I'm afraid that it isn't even close to what a true globular is like physically. Clear skies to you.
David W. Knisely
David Knisely
Reged: 04/19/04
      #3344255 - 09/20/09 02:42 AM
M32 has a fairly bright almost star-like core, which differs from the form of some globulars, so don't be afraid to kick up the power a little. Indeed, in a 12 inch scope on a good dark night, there are even a few globular clusters close to M32 (G156 is the brightest one near M32 at magnitude 15.6). Clear skies to you.
David W. Knisely
Crossen
Reged: 07/14/08
Loc: Vienna
      #3344459 - 09/20/09 09:02 AM
Me too. There's lots of differences among globulars visible in giant and supergiant binocs.
To start with, some have higher surface brightness than others. As Hrundi suggests, contrast the dim, hazy Class XII NGC 5466 in Boötes with the more concentrated and brighter M3 4° to its west. Another good surface brightness contrast (though they're a bit far apart) is between the very loose Class XI M55 in Sagittarius and the dense Class I M75 to its east.
David Knisely mentions the stellar core of M15 in Pegasus, which is distinctly star-like even in, say, 15x50 binocs. This is one of the "core-collapse" globulars: clusters in which most of the brightest stars, because they are among the cluster's heaviest, have literally sunk into its center. M30 in Capricornus, M62 in Scorpius, and M70 in Sagittarius are other core-collapse globulars. Though best seen with binocs from the southern hemisphere, all three exhibit their stellar core with giant binocs from dark-sky sites.
azure1961p
Reged: 01/17/09
      #3344680 - 09/20/09 11:51 AM
M37 in Auriga.
My apologies if it seemed as though i were morphing 37 into a globular. Its intensity however seemed like it might be of interest to someone whom ha seen a few globulars and was looking for something a little different. They are VERY different by definition as you point out, but in terms of visual stellar impressions, M37 is quite the rich treat.
I think its an excellent variation on a visual theme.
Pete
auriga
Reged: 03/02/06
Re: Do globulars all look the same? new [Re: Crossen]
      #3345246 - 09/20/09 05:45 PM
Craig,
Good to see you posting here.
I have enjoyed your book with Gerald Rhemann, "Sky Vistas: Astronomy for Binoculars and Richest-Field Telescopes." Rich with detail and insight. Nifty photos by Rhemann, too. Your Introduction to Keppel and Sanner's Night Sky Observer's Guide is also excellent.
But you have an unfair advantage over most authors: you can write.
Bill
propelller fan
Reged: 08/08/09
Loc: PNW...the wet side
      #3345656 - 09/20/09 09:50 PM
When viewing M-13 under dark skies, try to find the galaxy NGC-6207 which is in the same low power FOV
Meade 5.25" ETX-125
Meade 8" LX200
Meade 10" LX200
Meade 6" LXD55 Refractor
Orion 10" classic DOB
Meade 16" Lightbridge
Nagler 5mm, 7mm, 13mm, 16mm and 17mm
Ethos 10mm and 17mm
Custom built DEW prevention system
5.6 magnitude backyard skies
3 registered and 1 anonymous users are browsing this forum.
Moderator:  Olivier Biot
