gb_astro
Reged: 01/01/08
Loc: Sydney, Australia
Oberwerk's 100/45 clear aperture?
      #3344316 - 09/20/09 04:55 AM
Anyone advise the maximum eyepiece field stop I would want to use with Oberwerk's 100/45 deg binos?
I am just assuming that there is no point using a field stop larger than the clear aperture of the binos.
Would this be correct?
Thanks in advance,
gb.
charen
Reged: 05/28/05
Loc: New Zealand
Re: Oberwerk's 100/45 clear aperture? new [Re: gb_astro]
      #3346074 - 09/21/09 02:23 AM
If you see the above forum thread 'True Aperture' in relation to this reply.
I measured the Oberwerk 100-45 degree B.T.s with the standard 25mm EPs at 91 mm clear aperture.
Chris
35 binos.
80mm Cat.
WO66ED
SV NH 80mm / EQ3
Meade 8in.LX90
Skywatcher Equinox ED120 / Goto HEQ5.
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Oberwerk's 100/45 clear aperture? new [Re: charen]
      #3346194 - 09/21/09 06:54 AM
However, these two uses of the term clear aperture have nothing in common. The 91mm may be the effective aperture. the clear aperture that would be used to determine maximum eyepiece field stop would most likely be the clear opening directly in front of the eyepiece field stop.
FWIW, (although this may be different in the 45° version), the clear aperture in the straight thru BT100 is larger than the widest possible 1.25" eyepiece field stop.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
gb_astro
Reged: 01/01/08
Re: Oberwerk's 100/45 clear aperture? new [Re: EdZ]
      #3346200 - 09/21/09 07:06 AM
Chris, edz thanks for the replies.
Yes I was thinking more of "the clear opening directly in front of the eyepiece field stop"
but only because of reading about clear aperture in binoviewers.
gb.
Edited by gb_astro (09/21/09 07:48 AM)
charen
Reged: 05/28/05
Loc: New Zealand
      #3348238 - 09/22/09 02:38 AM
Sorry I replied incorrectly via my misunderstanding.
Chris
35 binos.
80mm Cat.
WO66ED
SV NH 80mm / EQ3
Meade 8in.LX90
12 registered and 19 anonymous users are browsing this forum.
Moderator:  EdZ
