patrick77
Reged: 09/15/09
Loc: Memphis Tn area
I have an ETX 125ec with UHTC, I need to know how well the electronic focus units work!!! I know of 2 out there, can anyone help. Do they keep the motion out of the scope when you focus the unit!!!
-------------------- New to this hobby, really enjoy looking at the stars!!
Edited by patrick77 (09/16/09 07:12 PM)
Dangermouse
Reged: 02/13/08
Loc: 170.5E; -45.9S
Totally worth it; I wouldn't be without my Motofocus. It will help a lot with vibration (but not eliminate it completely).
Treehopper
Reged: 07/29/08
Loc: Upstate NY
I get by with a simple flex-cable focus extension, but wouldn't mind a servo-based focuser. I'm just not going to pay the extra clams for it (on account of I'm a cheap old guy! ) I've seen a number of DIY projects, and if I can get my hands on the parts, I might be inclined to give it a whirl.
-------------------- Tim
Champion of small aperture scopes everywhere!
Meade ETX-125PE
Meade ETX-80
Celestron FirstScope 76mm Mini-dob
Updated: 09/16/2009
patrick77
Reged: 09/15/09
Which focuser do you have and how much $$$ is it at what store????
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
I don't have one on my ETX-125 (yet), but I do have one on my LXD75 SN6 and it's really nice, particularly when using high magnifications. It relly cuts down the vibrations and makes it much easier to precisely set the focus.
-------------------- -John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
patrick77
Reged: 09/15/09
Which one do you have???
Edited by patrick77 (09/17/09 02:32 AM)
Bob Griffiths
Reged: 10/10/05
Loc: Frederick Maryland
I do not own an EXT....but I use one on my single arm 8i and I have to disagree with the others here...
IT DOES ELIMINATE ALL my vibrations... once I power the scope up I do not have to physically touch the scope the rest of the night ...just push a button on the control box...
BTW... I use the same unit on my larger SCT also as it only takes 2 seconds to remove it and put it on the other OTA...
After YEARS of using the Motofocus I've kind of become fond of it...I estimate the battery life of the unit to be about 1-2 years OF HARD USE...
Initially I never left home without a spare battery ...I still carry one in my eyepiece case under the foam but battery life has been a non issue..
Bob G
Edited...I forgot to mention I also use a Motofocus on my Meade AR-5 ... much for the same reasons as I have rock hard hands and have never been accused of having a gentle touch...
-------------------- CPC1100
Nexstar 8i + GPS & Rays Brackets
Denk S1 power switch
Orion 100 mm Refractor
Meade LXD 55 ...AR-5 127 mm Refractor
Exploradome Observatory S.I.E. (Smiling Irish Eyes)
Gerbring Heated Motorcycle clothing in the winter
39*21'03" N
77*28'12" W
The sky over my head....
Edited by Bob Griffiths (09/17/09 09:31 AM)
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
The focus drive on my LXD75 SN6 is a Meade #1240 that was originally designed for the DS-2000 scopes. I made a simple adapter to mount it on my SN6 and added a spur gear to one of the focus knobs. I'm going to try something similat on my SC8. The ETX-125 is a bit tougher as there's not a lot of room to work with. The MotoFocus looks like a good option.
patrick77
Reged: 09/15/09
Thanks Im looking for one!!
Dangermouse
Reged: 02/13/08
Loc: 170.5E; -45.9S
The Motofocus in the pic I posted is an older version of the JMI unit found here...
HTH,
- DM
TimD
Reged: 02/16/05
Loc: CA USA
Definitely worth it. Vastly reduces amount of cussing done at the eyepiece while trying to focus with gloves on in 30 degree weather...
-------------------- Takahashi TSC 225
WO Megrez 102
Meade ETX 90, ETX 125
Meade LX90
Classic Orange tube C14, C90, C5+
Etc,Etc,Etc!!
Treehopper
Reged: 07/29/08
Loc: Upstate NY
Pffft...30 degrees and gloves? Where I come from, 30 degrees is prime streakin' weather!
Meade ETX-125PE
Meade ETX-80
Updated: 09/16/2009
