Alex Gorstan
Reged: 05/26/09
Loc: Owings Mills, MD
What is causing these streaks / poor tracking?
      #3350209 - 09/22/09 09:57 PM
Hello All,
This was my first serious attempt at astrophotography. The clouds and humidity weren't cooperating at all so I only had time to shoot my light frames. However, I was getting very inconsistent results with tracking. I could shoot some 90 second exposure's with nice round stars, and then other times, I couldn't even shoot 30 seconds without trails. I'm worried a gear may be slipping or something else might be wrong with my CGEM. But then again, i'm a n00b so maybe this is par for the course.
Mount: CGEM
Scope: C925
Alignment: "2 star" with 3 calibration stars and then a "Polar Align"
Here are some zoomed out shots of my results:
30 Second Exposures:
60 Second Exposures:
90 Second Exposures:
120 second exposure:
Thanks in advance, wise forum gurus!
-Alex
CGEM 925
2" EP Kit
12x50 Nikon ActionMaster
s58y
Reged: 12/12/04
Loc: Eastern NY
Re: What is causing these streaks / poor tracking? new [Re: Alex Gorstan]
      #3350948 - 09/23/09 07:56 AM
Are you autoguiding?
At least some of your subs look like they're coming out good, though.
Hutech 30D, SBIG ST-402 autoguider
SV80S, TV102iis
Old camera lenses: 800mm f/5.6, 180mm f/3.4
AP900, Barndoor tracker
http://www.pbase.com/s58y
QueueCT
Reged: 06/25/08
Re: What is causing these streaks / poor tracking? new [Re: s58y]
      #3351008 - 09/23/09 08:36 AM
Alex--
I experienced the same thing with a CGEM during my first attempts. I found that I either had to limit my exposure times and throw out about half my subs or autoguide. I went for autoguiding and haven't had a problem since.
John
Alex Gorstan
Reged: 05/26/09
Re: What is causing these streaks / poor tracking? new [Re: QueueCT]
      #3351101 - 09/23/09 09:26 AM
Thanks Guys,
Yeah, I'm not autoguiding. Sounds like I may have to deal with this until I can get an autoguiding setup.
I'm going to give it one more effort soon and make sure everything is balanced as best as I can get it to see if that makes a difference.
I'm especially curious since this isn't in every frame, about 50% of the time. Any idea what causes this? Is this periodic error?
CGEM 925
2" EP Kit
s58y
Reged: 12/12/04
Loc: Eastern NY
      #3351680 - 09/23/09 01:40 PM
How long is the worm period for your mount? It may be that there are 90-second periods during the worm cycle where the periodic error is pretty flat, and other 30-second periods where the error changes rapidly.
SV80S, TV102iis
Alex Gorstan
Reged: 05/26/09
      #3351752 - 09/23/09 02:09 PM
The manual says it takes 8 minutes for the worm gear to make one revolution.
The scope also has periodic error correction. I could try setting that up, although i think it requires that I buy a reticle eyepiece to configure it.. could be cheaper and more painless to get an off-axis guider and cheap ccd for guiding.
CGEM 925
2" EP Kit
John Miele
Reged: 05/29/05
Loc: North Alabama
      #3352281 - 09/23/09 06:51 PM
I noticed your streaks are not uniform. They have a bright spot at the start and end with a dimmer trail in between. Almost like you are tracking correctly, then jumping a bit and then tracking correctly again...not sure what that means though. Have you tried balancing the mount so it is East heavy?
C11/Atlas Mount/Denk II BV
SV102ED/AT Voyager
DSI IIc, DSI II Pro
ST-80, Mallincam Hyper Plus B/W Video Camera
Edited by John Miele (09/23/09 06:53 PM)
drksky
Reged: 09/01/09
Re: What is causing these streaks / poor tracking? new [Re: John Miele]
      #3352431 - 09/23/09 08:04 PM
I was going to say something right off about the dotted streaks. It looks like something that I experience with my CG-5 when it's not balanced so the worm is pushing against the spur. Essentially, it bounces, which looks like what's happening with the OP.
Considering the choice of targets, M-57, which is directly overhead this time of year, could be the mount is being balanced prior to M-57 crossing the meridian, and the mount isn't being flipped right away.
I'm new, though, so I could be totally BSing...
Tony C
AT8RC
C6-R
CG-5 ASGT
ST80 w/StarShoot Autoguider
Canon EOS 450D (Stock)
The Drinking Bird
s58y
Reged: 12/12/04
Loc: Eastern NY
Re: What is causing these streaks / poor tracking? new [Re: drksky]
      #3352542 - 09/23/09 08:55 PM
Perhaps the easiest way to set the PEC correction is with software like PEMPro. I don't know if PEMPro supports the CGEM. Also, you'd need to get an autoguider and software that PEMPro supports.
There may be other software packages that help set up PEC.
SV80S, TV102iis
KevinUK
Vendor (DSLR-AstroMod)
Reged: 08/22/07
Loc: N 51'53 W 00'25
      #3353137 - 09/24/09 02:48 AM
If you are using EQMOD ( and we all should be doing that! ) it has a module called PECPrep which can read input from numerous of other packages (MaximDL, K3CCDTools ) but also PHD + Guidemaster which are both free. I have used it with PHD output to analyse my PEC.
It then generates a VS-PEC (variable speed) out put file which is loaded into EQMOD and can be used to correct the recorded PEC accurately on the fly synchronised with the worm gear positions.
DSLR AstroMod
DSLR filter removal and replacement packages
http://www.dslrastromod.co.uk
Tapio
Reged: 09/24/06
Loc: Tampere, Finland
Re: What is causing these streaks / poor tracking? new [Re: KevinUK]
      #3353191 - 09/24/09 03:41 AM
60 or 90s exposures are not so bad on this mount if it has periodic error about 20" to 60".
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3190921/Main/3184054
Tapio
8 registered and 3 anonymous users are browsing this forum.
