Privacy Policy |
Please read our Terms
of Service | Signup and
peregrineflier
Reged: 09/14/08
Loc: Lost wages, Nevada (las Vegas...
Hi, I have an Orion 80ED guidescope and a DSI one mono as a guide camera. Can I use a barlow while guiding?
Thanks, Tom
-------------------- Thanks, Tom
Aka as "james" my first name.
It's a good day, my proctologist called today with good news, he found my head!
Meade 8in SCT
Orion 80ED
Orion hypertuned EQ-G
Orion Starshoot DS one
Meade DSI mono
Galaxyhunter
Reged: 01/02/06
Technically yes you can. But as the Star light passes through more glass, it is harder to get the nice crisp clean focus.
-------------------- Carl
My lousy skies at Hawkeye Observatory
John Wunderlin
Reged: 10/01/04
Loc: Mineral Point, Wi
As a practical matter, I'm not sure it helps much. PHD gives sub-pixel guiding accuracy. I regularly image with my 2500mm 10" LX50 while guiding with my ED80 (not barlowed) - works quite well. Also, I find it hard enough to find guide stars as it is without reducing the field of view by 1/2!
-------------------- John Wunderlin
Vendor - Spike-a Bahtinov Focusing Mask
Empire Ranch Observatory
Iowa County Astronomers
peregrineflier
Reged: 09/14/08
Really, I just need a temp fix until I can come up with a extention tube so I can reach focus with my dsi, I was stuck in the field and had to use a diag to get focused, my 2in TV big barlow is just long enough but was not sure if it would work.
Meade 8in SCT
Orion 80ED
Meade DSI mono
Footbag
Reged: 04/13/09
Loc: Scranton, PA
I tried this as well as a fix to needing a bit of extention, but couldn't get focus.
That said, as well as halving the field, it also increases the focal ratio. Add flexure into the mix and I don't think it's worth it.
-------------------- Adam
Celestron CPC 800, Celestron HD Wedge
Hyperion 17mm, Celestron 40mm Plossl, TMB 9mm
WO 66, SSAG
Modded Canon XS
Lackawanna Astronomical Society
My Gallery
AlanT
Reged: 08/20/07
Loc: 122º36' W, 47º37' N, WA USA
I use a modified 50mm finder with a DSI Pro as a guide scope. Because the native FL is only about 170mm and the pixels in the DSI are kinda biggish, I've been using a 2x barlow. The focus is soft, but it seems to work well.
al
-------------------- al
Meade 80mm APO
Celestron 6" SCT
CGE, GM-8, & CG-5 GT
ST-2000xcm, DSI Pro II, DSI Pro
( www.alberts-astro.com/astro )
John Wunderlin
Reged: 10/01/04
I had a cheap barlow that I used as an extension tube for a bit. I took out the lens and didn't slide the tube all the way in the focuser. It did the job, but you really need a proper extension tube.
7 registered and 2 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
