Kenny2004
Reged: 08/17/04
Loc: Toronto, Canada
Difficulty of imaging near Zenith new
      #3355504 - 09/25/09 08:20 AM
Imaging an object near Zenith does result for me a degree of elongated stars. As the night proceeds on, this effect disappears as the objects starts to settle down in Declination. Do you all share the same observations? I have read papers stating that imaging near Zenith does have these problems and extremely critical to have good polar alignment, etc., However, even if one has the best possible equipment, alignment, etc, is this condition entirely avoidable?
Skywatcher Black Diamond 80ED /w HEQ5 Pro
Celestron 8" SCT /w XLT
Celestron CPC800XLT
Meade DSI-C on a homebrew guidescope
ATik 314L+
Philips SPC900NC Webcam
DaemonGPF
Reged: 03/22/08
Loc: New Mexico
Re: Difficulty of imaging near Zenith new [Re: Kenny2004]
      #3355557 - 09/25/09 09:06 AM
Sometimes I can be an effect of slack in the gears in the mount. When your scopes are pointed towards one side or the other, you generally have some weight on the gears to keep them tight. This situation is avoidable even with entry level gear. I seem to have obtained some of my best images near zenith with my GC5 and LXD75 mounts.
-Josh
http://cleardarksky.com/c/AlbuqNMkey.html
My AP Gallery
cdndob
Reged: 07/28/06
Loc: The Great White North
Re: Difficulty of imaging near Zenith new [Re: DaemonGPF]
      #3355631 - 09/25/09 09:53 AM
My best guess would be to check your balance near zenith, make sure its a little "east heavy". Next time imaging bring out a small weight you can attach to the east side once you see the elongated stars and see if the problem goes away.
If that doesn't fix it I'd look for a flexure issue next. Does this show up when imaging with your ED80 or only with one of your other scopes?
Steve
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Difficulty of imaging near Zenith new [Re: cdndob]
      #3355832 - 09/25/09 11:42 AM
Yep, that's what you get sometimes if you pass through a region where the ballance shifts from one side to another. Polar alignment becomes increasingly important the closer you get to the pole (imaging NGC188 can be real fun).
-John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Difficulty of imaging near Zenith new [Re: jgraham]
      #3355854 - 09/25/09 11:50 AM
With the CPC 800? I had noticed that I have poor sessions when I don't ensure that the knobs are tightened all of the way into the base of the scope.
When the weight is that high up, it's much more likely to shift.
Adam
Celestron CPC 800, Celestron HD Wedge
Hyperion 17mm, Celestron 40mm Plossl, TMB 9mm
WO 66, SSAG
Modded Canon XS
Lackawanna Astronomical Society
My Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #3355981 - 09/25/09 12:52 PM
Why haven't I thought of this!
Steve
LXD75 GEM
Orion Starblast 4.5" Imaging Reflector
William Optics Zenithstar 66 SD APO
Meade DSI II OSC
Meade DSI III OSC
Orion Starshoot Autoguider
Televue Powermate 2.5x
Discovery 6" Dobsonian
Nikon Action Extreme 10x50's
Gallery
russ_watters
Reged: 11/24/04
Loc: Trappe, PA
Re: Difficulty of imaging near Zenith [Re: yock1960]
      #3356671 - 09/25/09 07:04 PM
I have the same issue and it doesn't seem to have anything to do with my polar alignment (it is pretty consistent no matter how good my alignment is). For me, with my heavily loaded mount, I'm guessing flexure.
Equipment: Orion Atlas 11, ED80, DSI-C, DSI II Pro, Dell Inspiron Laptop.
www.russsscope.net
9 registered and 5 anonymous users are browsing this forum.
