8buck
Reged: 02/12/09
Loc: Idaho
Registax tips? new
      #3354872 - 09/24/09 10:38 PM
are there any tips that i (newbie) might not know about while using Registax? I've been at it fo a few days now and im not impressing myself. for example, is there a way to keep it from stackin blurry frames and only use the good ones???
NexStar 1100 GPS (EPs Celestron 22mm - Celestron Plossl 32mm) SOUTHEASTERN IDAHO
senske
Reged: 01/10/09
Loc: Spokane, WA
Re: Registax tips? new [Re: 8buck]
      #3355006 - 09/24/09 11:50 PM
8buck, I've just starting dabbling in astrophotography so I don't have much RegiStax experience. But, the wavelet functions at the end of the process make a big difference. Have you tried using the wavelet sliders?
Andrew
Orion SkyQuest XT10 Intelliscope with Orion 9x50 and Telrad Finders
Orion WorldView 10x50 Binoculars
Celestron NexStar 8 SE with GSO 8x50 and Red Dot Finders
Galileoscope
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: Registax tips? new [Re: senske]
      #3355013 - 09/24/09 11:55 PM
With things where sharp detail is possible, I've found the wavelets invaluable. There's also a neat RGB align feature that can fix misaligned colors.
Just a newbie here as well, otherwise.
russ_watters
Reged: 11/24/04
Loc: Trappe, PA
Re: Registax tips? new [Re: Hrundi]
      #3356673 - 09/25/09 07:05 PM
I made a registax tutorial a while back. It is version 3, but the commands are about the same: http://www.russsscope.net/staxtutorial.htm
I've found the "human" quality ranking method is generally the best.
Equipment: Orion Atlas 11, ED80, DSI-C, DSI II Pro, Dell Inspiron Laptop.
www.russsscope.net
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
Re: Registax tips? [Re: russ_watters]
      #3356932 - 09/25/09 10:19 PM
Google "Mike Salway". He has an excellent tutorial on Registax V.4, but you can "read between the lines" and apply it to version 5.
Scopes: Meade SC-8AT w UHTC
Orion ST-80 Refractor (Autoguiding)
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Canon XSi 450D Unmodded
Palm TX PDA w Astromist and Bluetooth wireles control.
6 registered and 7 anonymous users are browsing this forum.
