Privacy Policy |
Please read our Terms
of Service | Signup and
EdZ
Professor EdZ
Reged: 02/15/02
Excellent observing successes Glenn. In my years of observing, I have not seen most of those nebula, not for lack of trying. And the few I have seen were only a fraction of the total object. It is truly dark skies which enables the obserever.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
orlandog
Reged: 01/10/08
Loc: wilmington, north carolina
Thank You Glenn for so eloquently presenting your projects. It was a joy to read of your construction and superb outcome. I reckon that many more will be on the way. Please continue to share. Best Regards, Howard
OpalescentNebula
Reged: 01/11/07
Loc: Calgary, Alberta, Observing so...
You have done a great job in your dark sky observing. I also like observing in lower power. I have looked where you have detected objects but alas with my inexperience I haven’t been able to see them. Sometimes with adverted vision I think its there, but I’m never sure.Your keen eyes see dark nebula, where I only see no stars. When I look up without binoculars I can see the Milky Way & dark nebula regions. When I look through binoculars, the dark regions usually have some stars. You, Edz & others on this forum have sent in excellent observing reports. After reading your reports I spend weeks trying to find the same things. I’m slowly climbing the learning stairs and thoroughly enjoying the experience. Thanks Glen.
-------------------- Yours truly,
Bill
"Good friends are like stars...you don't always see them, but you know that they are always there" - unknown
Binos : various binos, Zeiss 10x42 FL, Garrett Optical 20x110
telescope: WO Megrez 110 ED
Eyepieces: 13mm Ethos, 5mm Pentax XO, 28mm WO & 2x Powermate
KBK
Reged: 08/05/09
One of my tricks has been to wear, even in the winter, very high grade sunglasses at all times during the day. This, since I was 21. I'm 45 now. I've been wearing Serengeti photo sensitive sunglasses since the first day they came to market, specifically due to their overall quality and that they work through the windshield of a car. I don't have a television, either. All this to try and protect my eyes. My father was a welder and the best in his trade. World class. At the time there was no quick dimming shields - and the job cost him his vision. He needs a 100w bulb to read a map.
-------------------- It is the image of the ungraspable phantom of life; and this...is the key
to it all.
Wes James
Reged: 04/12/06
Ouch.... I'm sorry... Welding is a dangerous trade over the long term. Fumes are a major toll-taker... I lost a good friend who was a shipyard welder to lung cancer at the age of 49. Between the fumes- and being a heavy smoker, pretty much a forgone conclusion... Wes
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Thanks for the kind words, gentlemen! I've been an avid skygazer since I was 13, and I guess after more than 30 years of this I've trained the ol' peepers and visual cortex to eak out those subtle signals.
I've uploaded a photo of the bino in the 7X50 configuration, with the new handles attached. Currently I'm using standard 1.25-to-2 inch adapters in order to mount the Tasco eyepieces. I hope to soon make plastic adapters, perhaps with the heaters built right in.
-------------------- Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
KBK
Reged: 08/05/09
Give it a name. Call it 'Levi' --As in 'superwide' (bellbottoms). *rimshot*
to it all.
GlennLeDrew
Reged: 06/18/08
Har har! But on a more serious note... You'll bever find names given by me to my instruments, such as is done by a well-known author of whom your suggested moniker reminds one.
My Gallery
GlennLeDrew
Reged: 06/18/08
I finally got around to some dark sky observing in the 13X50 mode (using the 13mm Ethos eyepieces.) For the entire session I had the bino tripod-mounted.
Last night was nicely clear and reasonably dry, but not as nice as a week ago (when I was in 7X50 mode.) The SQM read 21.2, which is 10% brighter than the more common 21.3 found at the observatory. (This leads me to suspect that last Friday's sky surely would have been 21.4, if not a tad better.) In any case, the Gegenschien was easily seen, however averted imagination would have been required to see the fainter zodiacal band extending eastward toward the Pleiades.
Early on I'd installed the Orion Ultrablock filters and visited lots of emission nebulae. Some highlights:
- The Pelican revealed the dark feature which separates the 'bill' from the 'body'.
- The fainter southern portion of the generally circular form which includes the N. America/Pelican complex was also seen. I forget the catalog designations, but I seem to recall that one of the three objects in this sizeable arc is IC 5068 (??).
- In the Veil nebula, the eastern section (NGC 6992) revealed structure, especially the hooked bifurcation at the southern end. The sharp, scimitar-like north end of the western section (NGC 6960) was not too difficult to make out, and Pickering's Wisp was not difficult either.
- The small, circular Sh2-112, just to the west of Deneb was faint but certain.
- The Crescent nebula, NGC 6888, a shell surrounding a Wolf-Rayet star, was even visible *without* filtration. But even with the filters installed it was a shapeless blob, the magnification being too low to resolve the rather narrow width of the arc.
Later I removed the filters in order to ferret out some reflection nebulae:
- In the SW part of Perseus OB2 complex is located the small, circular nebula NGC1333. I had first found this one a couple of years ago with my 26x100, and was more than a bit surprised to catch it with half the aperture *and* magnification, and not remembering exactly where to look.
- The Flaming Star nebula, surrounding the runaway star AE Aurigae, was even more definite than it appeared last Friday at 7X, mainly because of the higher magnification, which more than compensated for the approx. 0.2 magnitude brighter sky.
- The Merope nebula, in the Pleiades, was quite definite.
As to penetrating power, I did an 'after action' analysis to get an idea of the achievable magnitude limit. Some datum points:
- The illuminating star of NGC 1333 is mag. 10.6. It was quite easily seen directly.
- The rich open cluster NGC 7789 was partially resolved. Checking some of its several brightest stars indicated that I was seeing to 11.0 pretty certainly, and possibly 11.2.
- Open cluster M37 was also partly resolved, and suggests a similar magnitude limit as for NGC 7789.
On balance, I'm sure that I was seeing 11.0m stars, and possibly to 11.2m.
My Gallery
Man in a Tub
Not Retired!, But a little cranky!!!
Reged: 10/28/08
Loc: San Francisco, CA
This is one fascinating report, Glenn.
Notable in particular for me:
I didn't know NGC1333 is visible in binoculars. So, I checked out the observing reports that are in the help file of Hallo Northern Sky. One which I had not read until a few minutes ago reports this intriguing, very young DSO as visible in 14x70s on a dark night.
WOW!
-------------------- Todd
Brunton Eterna 15x51 ° Garrett Optical Signature Series 15x70
Nikon Action EX 12x50 ° Oberwerk 15x60 and 20x80 Standard
Orion Paragon Plus Mount and Paragon XHD Tripod
Garrett Optical Series 2000 Grip-Action Monopod
4 registered and 13 anonymous users are browsing this forum.
Moderator: EdZ
