Fuzz
Reged: 08/11/09
Loc: Silverthorne, Colorado
First attempt at DSO (M13) on 8" SCT (alt-az)
      #3359052 - 09/27/09 02:26 AM
Hooked up my Canon 40D to my 8" SCT (prime focus). Alt-az mount, hence could only do 5-sec subs. Captured and stacked using Nebulosity.
10 subs x 5 seconds, ISO1600 (plus 10 darks):
Without a wish, without a will, / I stood upon that silent hill / And stared into the sky until / My eyes were blind with stars and still / I stared into the sky. - Ralph Hodgson
Scope: Celestron NexStar 8SE + Telrad finderscope
EP: Plossl 32mm, 25mm, 15mm, 9mm, 4mm, 2x Barlow
Binos: Bushnell 7x35 binos
Imaging: Canon 40D + Canon 35mm f/1.4, Tamron 18-270mm, images
Scott Mitchell
Reged: 07/28/07
Loc: Atlanta-ish, GA
Re: First attempt at DSO (M13) on 8" SCT (alt-az) new [Re: Fuzz]
      #3359245 - 09/27/09 07:52 AM
Nice shot. Welcome to madness (and slippery slope) of astrophotography!
Fuzz
Reged: 08/11/09
Re: First attempt at DSO (M13) on 8" SCT (alt-az) new [Re: Scott Mitchell]
      #3359381 - 09/27/09 09:53 AM
Thanks.
So I took the same subs and stacked using DSS(default settings), and got this image:
This seems to show a bit more definition around the cluster itself, but there's also more noise. Is there a way to reduce the noise but keep the definition in DSS?
Fuzz
Reged: 08/11/09
      #3359386 - 09/27/09 09:55 AM
^^^ And this is AFTER I manually reduced the red noise pixels in Photoshop after stacking in DSS.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #3359429 - 09/27/09 10:39 AM
Very nice for a first shot!
I would try to push up those subs. When I was shooting in Alt-Az I was getting 15s easily. The difference in signal to noise will be considerable. As signal increases, it makes it easier to pull data out of your noisy shots.
Stick to this target for a little while, it's a good one, and there are a lot of stars there to pull out. And it will give you a bit of a control for your experimentation.
Adam
Celestron CPC 800, Celestron HD Wedge
Hyperion 17mm, Celestron 40mm Plossl, TMB 9mm
WO 66, SSAG
Modded Canon XS
Lackawanna Astronomical Society
My Gallery
Fuzz
Reged: 08/11/09
Re: First attempt at DSO (M13) on 8" SCT (alt-az) new [Re: Footbag]
      #3359534 - 09/27/09 11:46 AM
Thanks.
I'll try that. Maybe it didn't align very well last night, but there is definite translation movement in 3 subsequent subs (15 seconds). I honestly didn't even try more than 5 seconds just to be safe. Will try longer tonight.
Scott Mitchell
Reged: 07/28/07
      #3359595 - 09/27/09 12:24 PM Attachment (5 downloads)
There's actually a good bit more there than you are showing. You've clipped the black point, but just pulled the mid range up a bit and there quite a few stars hanging out in there. Also, next time you're out make sure you take 30 or 40 subs and then you can do a sigma clip stack in DSS which should help with the noise some.
Here's what it looked like after a slight tweak in PS:
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
      #3359833 - 09/27/09 02:22 PM
Yes, I get the same when I "manipulated" it in PaintShopPro.
You can really see the "Propeller" vein.
Scopes: Meade SC-8AT w UHTC
Orion ST-80 Refractor (Autoguiding)
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Canon XSi 450D Unmodded
Palm TX PDA w Astromist and Bluetooth wireles control.
Fuzz
Reged: 08/11/09
      #3359875 - 09/27/09 02:55 PM
Thanks, Scott.
I actually didn't do any post-processing other than sharpening what came out of Nebulosity.
I'll try to get more and longer subs tonight. Not sure if I'll get M13 again though, because I was planning on getting up early to catch the Pleiades and Orion. Might try it before going to bed early.
The other thing I need to do is really read the detailed instructions for both DSS and Nebulosity, so I know what settings to use to get the best out of each image. For this image of M13 I just used the default settings.
Fuzz
Reged: 08/11/09
      #3359896 - 09/27/09 03:07 PM
Any comments on the focus? Is the focus okay or could it be better? Since this is my first attempt at DSO imaging, I don't know if I got it right or not. I focused on Arcturus with Canon's EOS utility which allows LiveView on the computer screen -- basically focused until the star image was the smallest diameter.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #3359919 - 09/27/09 03:23 PM
Focus looks perfect.
I have always just used the recommended settings in DSS. Click recommended and it usually steers you in the right direction. Only change settings if you're looking for a specific result.
Adam
WO 66, SSAG
Modded Canon XS
My Gallery
10 registered and 11 anonymous users are browsing this forum.
