droid
rocketman
Reged: 08/29/04
Loc: ohio
basic info new
      #3359309 - 09/27/09 09:11 AM
Ok I know that my mirror will be 13 inches in diameter.
I also know it will be rouhgly F/5
Question #1) If I got with a solid tube ,what inside diameter????
Question #2) What size secondary? strictly visual use.
12 inch Truss Reflector "John"
102mm Celestron C102HD
Tasco 7TE5 60mm Classic
Tasco 9TE5 60mm Classic
Celestron Ultima 2000 SCT
Remains of an 8 inch dob
Celestron Comet catcher(orange tube)
1960 Edscorp Space Conquerer 6inch f/8
10x50 Bushnell Binoculars.
11T 4.5 inch Tasco reflector Lunograsso?
60mm Telescope Club
Luigi
Reged: 07/03/07
Loc: MA
Re: basic info new [Re: droid]
      #3359341 - 09/27/09 09:32 AM
Newt answers all.
17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
droid
rocketman
Reged: 08/29/04
Loc: ohio
Re: basic info new [Re: Luigi]
      #3359398 - 09/27/09 10:08 AM
ok, focuser height , racked in or racked out??
60mm Telescope Club
HiggsBoson
Reged: 02/21/07
Loc: Kal-li-fornia
      #3360403 - 09/27/09 08:10 PM
racked in.
Michael
ATM: 6" F/9 Newtonian Travel Scope
ATM: 12.5" F/4.5 Real Soon Now...
droid
rocketman
Reged: 08/29/04
Loc: ohio
Re: basic info new [Re: HiggsBoson]
      #3360714 - 09/27/09 11:02 PM
OK got it all done......how do I save it?
60mm Telescope Club
astro744
Reged: 09/22/07
      #3361159 - 09/28/09 06:13 AM
Also look at http://www.bbastrodesigns.com/diagonal.htm
Likely 2.6" or 2.14" diagonal but many factors come in to play.
A 2.6" will give you 20% contrast obstruction and a nice large fully illumunated field of view should you wish to use low power eyepieces with large field stop diameters. However, exit pupil will be large at f5 so your largest eyepiece is likely to be a 31mm Nagler which has a field stop diameter of 42mm (R=21mm or 0.83"). Note a brighter larger field is needed for variable star observing so as not to have a magnitude drop at the edge of field. Contrast is less important if designing for variable star observing and a larger than usual diagonal is needed.
The idea of Mel Bartels program is to match the off-axis radius with the field stop diameter/2 of your lowest power (or most used lowest power) eyepiece.
eg. 31mm Nagler has field stop diameter of 42mm (R=21mm or 0.83"). You want the 70% illumination to be at the 21mm off-axis mark.
If your lowest power eyepiece is say a 27mm Panoptic with field stop diameter of 30.5mm (R=15.05mm) then aim for 70% illumination at the 15mm off-axis mark or 100% illumination at the 15mm off-axis mark if you observe variable stars.
The size of the diagonal and distance to focal plane are the two parameters you can tweak so you need to consider what type of focuser you will be getting. The program NEWT mentioned in another post also looks at vignetting.
I find too many people size their diagonal too small and do not have sufficient off-axis illumination in their low power eyepieces and this can have considerable impact when observing galaxy clusters (eg Virgo, Fornax) where the galaxies are all over the field and not just in the middle and a 0.5mag drop toward the edge can mean the difference between seeing a faint fuzzie and not seeing one.
As long as your contrast ratio is 20% or under you are fine for good planetary observing too.
droid
rocketman
Reged: 08/29/04
Loc: ohio
Re: basic info [Re: astro744]
      #3361240 - 09/28/09 07:54 AM
Actually 2.3 inches
heres what I got so far:
diagonal offset- .1150
100% illumination diameter - .4966
75% illumination diameter - 1.4343
Front aperature diameter - 14.494 ???
mirror face to focuser hole - 55.625 inches, Im assuming thats to the center of the hole to allow me to measure where to cut out the hole???
focuser to front of tube - bit of a mystery as Newt seems to think Im going ot buy a tub 6 feet 3.5 inches long.Mine will be 6 feet even.
13 imch mirror F/5 (65.0 inches focal length)
tube inside diameter 14.5 inches
focuser height racked in 2.0 inches /2 inch diameter
60mm Telescope Club
1 registered and 8 anonymous users are browsing this forum.
