CESDewar
GorillAstronomer
Reged: 01/16/05
Loc: Morganton, GA, USA
It was humid, but given all the rain here in the SE in the past couple of weeks, finding a night that was clear seemed like Nirvana! I was looking at Jupiter in my NP-127 and noticed a moon on either side, not that interesting... but then suddenly noticed a little 'pimple' on one side as a moon (Callisto) just exited after transiting Jupiter. That prompted me to look at SN to see if anything else was going on and that's when I realized that a treat was in store.
First, about 40 minutes later, I could see Europa's shadow on the surface of Jupiter - a tiny, sharp black dot entering from the other side. After a while, during steady seeing I was also able to catch Europa itself just before it concluded its transit across Jupiter. It was a bit tougher because it was between the two main belts and so did not have as much contrast as would otherwise be the case.
At that point, the humidity was climbing fast - already at 88% and rising - and being a Sunday night, my observing friends had to leave around 11pm and we packed up everything. But the real treat was still ahead.
After they left, I took my 70mm ED Scope out with a 2.5T5 Nagler (168x) and 2-4mm Nagler (210x at 2mm) to look again at Jupiter and watch the wonderful transit of Europa across Ganymede. RH was already 91%, so I was expecting it to start fogging over shortly, but it stayed clear for the next hour.
First I was quite surprised to see that I could catch Europa's shadow in my 70mm scope - a nice tiny black dot - not bad considering that Europa (by my rough calculation is no more than around 0.9 arc seconds(). Not as easy as seeing it in the NP127, but neither did it take any averted imagination!
But the real treat was watching Europa head for that transit across Ganymede. I was able to see it elongated down to within 2 minutes of the central point of the transit which took place right around 11:40pm EST. At that moment, there was just one "moon" visible. The elongation started to reappear just 2 minutes after that - so it only took about 4 minutes for Europa to cross over Ganymede. As it was exiting, the instant the elongation stretched into 2 separate moons, I rushed back to see what SN was saying about the separation at that moment - listed it at 1.5 arc-seconds. It's the first time I've ever seen a moon transiting another moon like that. And even in the 70mm scope, the difference in size between Europa and the much larger Ganymede was very obvious. That little SV70mm ED Scope never fails to surprise me with the quality of its views.
By 12:30am, I looked out and there was not a star in the sky and the RH was about 94%. All in all a fine show by Jupiter this past Sunday night!
Jim Rosenstock
Reged: 07/14/05
Loc: MD, south of the DC Nebula
Excellent report! It pretty much captures my experience as well. A very, very cool event!
Interestingly, this Europa/Ganymede transit (or mutual occultation, take your pick ) will repeat on a weekly basis for the rest of the year! Each week's event will occur about 3 hours later, though, so most won't be observable from North America.
Here's a link to a comprehensive listing of this year's mutual satellite events:
http://asa.usno.navy.mil/SecF/Jupiter.html
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
CESD,
Thanks for posting this interesting report. We've been under the same cloud cover here (without the deluge) and it hasn't gone away yet. I was sorry to miss seeing this, but I hope to catch the event on Oct. 4th/5th--thank you Centaur and Jim for the heads up and links.
...After a while, during steady seeing I was also able to catch Europa itself just before it concluded its transit across Jupiter. It was a bit tougher because it was between the two main belts and so did not have as much contrast as would otherwise be the case.
Although Europa (and Io) can be quite difficult to see against the Jovian disk, they are usually visible when near the limb, showing up well against the limb darkening.
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
Chopin
Canis Insanus
Reged: 02/03/05
Loc: In the doghouse.
Awesome report, CES! Very enthusiastic. I could practically see the whole event through your writeup.
-------------------- JasonŽ
Starstuff
birdsbyjason
12" Hardin DSH-12│4˝" Custom newt│Garrett 15x85 HD WP│Pentax 8x40 PCF WP II│24Pan│13T6│3-6NZ│Faworski Abbes
3 registered and 1 anonymous users are browsing this forum.
Moderator: Shadowalker, RLTYS
