Jonzky
Reged: 05/10/08
Loc: London
Hi Everyone,
I am so close to getting a LS60 B1200 (Hopefully) and have a few quick questions about it. What would be a good price to pay for it in the UK (£s)? Also, does it have problems with focusing with some EPs/Webcams? Also, it has a screw fitting for a standard tripod on the shell? so is a tripod suitable (Could it hold it steadily?) Finally, thanks to everyone who helped me make up my mind and who gave me advice in any of my other threads.
-------------------- My Scopes:
CPC 1100 WOW
130 SLT (Broken)
Brought to you from the light polluted London
Edited by Jonzky (09/29/09 05:51 PM)
swisswalter
Reged: 03/29/09
Loc: Eastern-Switzerland
hi john
i recommend the lunt 60 but not the double stack with the 50 mm filter
walter
-------------------- only dust in the wind, TAK on GM8, Lunt 60, DMK31,still greenhorn, but as a golfer used to be humble
Gene Baraff
Reged: 03/22/09
Loc: Berkeley Heights, N.J.
I recommend the lunt 60 but not the double stack with the 50 mm filter
walter
Can you explain why? Does the Double Stack in front of the main scope degrade the image?
If so, in what way? If not, is it that the improved view is not worth the extra cost?
Thanks.
Gene Baraff
swisswalter
Reged: 03/29/09
hi gene
yes we found that the 50 mm DS filter is blurring the image. we have checked that on the lunt 60, a TAK, a MAK and on the megrez with a B1200. some how it just does not work.
walter
stephenramsden
Reged: 08/17/07
Loc: Atlanta, GA--USA
how many DIFFERENT Lunt filter sets and B1200s did you try it with? What was the date of this result?
-------------------- Stephen W. Ramsden
Atlanta, GA--USA
NASA SOLAR SYSTEM AMBASSADOR
www.solarastrophotography.com
www.SolarScopeReviews.com
www.stephenramsden.com
swisswalter
Reged: 03/29/09
hi stephen
thank you for your answer and questions. i have just one lunt 60 and one 50 mm filter "matched" for DS and one B1200 blocking filter.
the tests where done during may, june, july, august and september of that year
walter
Evokal
Reged: 02/12/09
Loc: Manitou Springs, CO
Jon, Glad to hear you'll be getting a Lunt 60! I have been using a video camera tripod (that I had laying around) for my LS60 but would not recommend buying one for use with the scope. If you have one already use it until you can afford a more heavy duty astronomy tripod/mount. The LS60 is so much more heavy than I thought it was going to be, sort of scares me sitting on that dinky tripod. From what I hear the B1200 should be sufficent to handle cameras, binoviewers, and 'needy' eyepieces. Hope that helps! -Michael
-------------------- Michael Huwe
Lunt 60mm Doublestack w/ B1200 BF
"Might the sun be a metaphor of the compassion we can only reflect if we turn in that direction, revealing every flaw? I wonder this every time I see a full moon light up the night around me..." -Anonymous
2 registered and 3 anonymous users are browsing this forum.
Moderator: Don W, spaceydee
