Privacy Policy |
Please read our Terms
of Service | Signup and
Phillip Creed
Idiot Seeking Village
Reged: 07/25/06
Loc: Canton, OH
I was at this year's Black Forest Star Party and as transparent as the skies were, I had problems with dew. Specifically, my 120ST was a real problem child, even with the dewcap that's included with the scope.
I got to thinking (dangerous as it may be; it happens)...what would happen if I just bought one of those reflective Mylar "emergency blankets" you see in sporting goods stores like Gander Mountain and cut out a layer and wrap it around the scope? Has anyone tried this?
Clear Skies, Phil
-------------------- "The hopeful depend on a world without end, whatever the hopeless may say"--Rush, "Manhattan Project"
Wilderness Center Astronomy Club member since 1995
ICQ Comet Observer Code: CRE01
(1) 12" f/4.9 Skywatcher Collapsible Dobsonian
(2) Celestron 150mm f/5 Omni Refractor
(3) Oberwerk 15x70 Binoculars
(4) Minimalist Eyepiece Set:
"23"-mm Axiom LX (~24mm; long story...)
13mm Nagler Type 6
9mm Nagler Type 6
7mm Nagler Type 6
1.75X Siebert Barlow
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
If you ensure that there is an airspace between 'scope and 'blanket', you should expect to retard the rate of cooling of whatever's being shielded. If the blanket is in contact with the tube, etc., I'd think its efficincy as an insulator will be compromized.
Even so, unless an extension is added to your dewcap, the IR flux radiating from the objective into the cold night sky will be as great as ever, and hence dew formation *may* be delayed for a bit. The best bet, in lieu of active heating, is to extend your dewcap by about double its current length.
Instead of a mylar blanket, how about a thin layer of some foam-based material. This is easier to work with in that it's perfectly OK to have it in contact with the 'scope. And it will probably better hinder dew formation on the objective than would mylar, whether with or without a dewcap extension.
-------------------- Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery (mostly DIY stuff)
Simple minds discuss people. Good minds discuss events. Great minds discuss ideas. - Hyman Rickover
PitchHitter
Reged: 09/23/09
Loc: Southern Sierras
The thin mylar depends on reflecting back the thermal energy from a body.While it may slow some heat transfer from your scope, what I used was a mylar water heater blanked. It is double mylar with an insolation or air pocket sandwiched between. In extremes a dew heater is needed. Here are plans for the most efficient one you can find: http://www.intergate.com/~rocketmaker/dewheater.htm
-------------------- About 20 telescopes from a 200mmAPO up
Fav is Meade 10" f:4.5 using my 3" 40mm 96°AFOV
BUT! In Progress:
14.5" f:5 grab n' go with DSCs will offer 2.4 degrees at 45 power and 8mm exit pupil (Light Bridge Buster)
16.25" f:7.5 to refigure
(20th wave ruined in a fire at the coaters)
22" f5: New mount almost done
(old all aluminum mount was stolen)
16" Varian Vapor Deposition Coater.
Looking for larger chamber.
davidpitre
Reged: 05/10/05
Loc: Central Texas
Following with Glen's suggestion, I've found that integrating foam insulation surrounding the circumference of the objective with the dewshield can delay dew formation.
-------------------- David
StarStuff1
Reged: 04/01/07
Quite a few years ago when i was a "sophomore" amateur astronomer I attended a star party in the NC mountains. It was very humid and, of course, I had brought along batteries and a hair dryer to fight dew. A few feet away a guy set up a brand new AP refractor and wrapped a couple of layers of bubble wrap around the dew shield. It looked kinda odd but the guy said it would keeep the objective dry for over an hour. I asked him what would he do then? His answer was that he had plenty more bubble wrap dry and warm in his car. Dang if it didn't work.
-------------------- Tools that make objects very far away appear much closer than they actually are.
jayscheuerle
Reged: 01/16/06
Loc: S. Philadelphia, PA
You can buy dark-room mylar (black on one side, reflective on another) on ebay. I'm planning on using it for a shroud. - j
-------------------- Fight indignorance!
120ED, 12" f/5 Green Goblin, 6" f/5 Eero2, 4.5" f/8 PortaBowl, 8" f/5 Big Red Ed.
The PortaBowl-a $100 4.5" f/8 ball-scope YOU can build!
G Smith
Reged: 11/22/07
Loc: Central Ohio, USA
Slow down a bit folks and consider the problem of Dew. There are mixed ideas in the above posts. Dew forms on a surface because it is COLDER than the air. There is a problem with scopes because they are in Radiation communication with the clear sky. It is beastly cold up there. The ground is warm, and so is the underside of trees. Consider the air neutral.
So, you do not need nor want Insulation, nor do you want to prevent Radiation to the ground. What you do want is to prevent Radiation from the Top Side of your scope to the cold sky, and you do want Radiation from the warm ground to your scope underside. So, just cover the top half of your scope with Mylar film, which is readily available on the internet. I believe mine was intended for indoor gardening. The prevention of radiation is very efficient.
I have a steel tube reflector, so a few small magnets keep it in place. For a non-magnetic tube perhaps a rubber band on each end and a cord wrap in between would do fine. Or you could epoxy a magnet inside at certain spots to attract an outside magnet.
Please get a Radio Shack non-contact thermometer that senses Infra-Red. You will be amazed at the indicated temperature difference when you point at a cloud, the clear sky, the ground, and the underside of foliage. It has endless other uses in finding weak insulation in the house wall, frozen spot of a water pipe, a hot semiconductor on a circuit board, proper pancake skillet temperature, etc. You will want to cover any highly reflective surface with dark masking tape, or whatever to get a good reading. Otherwise you will only get the temperature of a reflected object. Good Luck, Gene
9 registered and 6 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
