Telescope Specific Forums >> Meade ETX
Jacob M
newbie
Reged: 09/28/09
ETX Issues new
      #3364598 - 09/29/09 07:29 PM
Hi all! I just recieved a Meade ETX 90mm telescope. As far as I can tell its from the mid-to late '90s. It does not have the AutoStar tracking package, however it does have the built in tracker; this is what I can't seem to figure out. I also have the field tripod manufactured by Meade for their telescopes. I followed the directions with included with the tripod to polar align it. I set the latitude, aligned the leg due north, and turned on the tracker. So far, it doesn't track anything in the sky. I checked the tracker inside, and the telescope rotates around the base as it should. It does not move vertically, should it? I opened up the casing and discovered that there was no gear drive to even move it vertically. To me, this doesn't make sense.
To accurately track an object, shouldn't the telescope move both vertically and horizontally on its on? Both the RA and DEC controls were locked as the instructions say. What should I do? Are there any obvious problems here? Thanks!
-Jacob
oldsaltModerator
Astro Philosopher
Reged: 02/12/05
Loc: Pa - between starparties
Re: ETX Issues new [Re: Jacob M]
      #3364627 - 09/29/09 07:42 PM
You must have the ETX90-EC, which has an electronic controler with up/dwn l/r buttons on it. I'd suggest downloading the manual on it.
There are no winners in war, only bigger losers.
Fish
Reged: 10/13/07
Loc: Norridgewock, ME
Re: ETX Issues [Re: Jacob M]
      #3364724 - 09/29/09 08:35 PM
Jacob,
You have a bunch of questions there but let's sort through them.
Based on your description you most likely have an original ETX, later known as the ETX-90RA. You also most likely have the Deluxe Field Tripod which allowed for polar mounting.
Assuming this, here is an acceptable polar alignment procedure that will be sufficiently precise for visual observing.
--> Set the angle of the mounting plate on the tripod to your approximate latitude using the scale on the side. The angle of the plate to the horizontal should then be (90-latitude) degrees.
--> Set the north tripod leg to true north. This may not be easy in the daytime but with a compass and the magnetic declination of your location it can be done.
--> Mount the scope onto the plate using the proper bolts. Be sure the bolts are not overly long and do not tighten excessively. The base of this ETX model is plastic and could crack with excessive force.
--> Loosen the lever in the center of the scope base. Rotate the telescope counterclockwise until you hit the hard stop. Then, rotate clockwise 1/4 turn and tighten the lever. Again, a firm feel is sufficient.
--> Loosen the top knob on the right fork (as seen from the back) and rotate the tube - not the base! - such that the objective points directly away from the base. Tighten the knob to keep the tube in that position.
You are now at the "home" position. The tube is pointing to the north celestial pole, close to but not directly at Polaris. Now when you loosen both axes, point to an object in the sky and re-tighten the locks, the tracking motor will move the scope to keep the object in the field of view.
Now, a few other notes about this ETX model. The tracking in this ETX is Right Ascension (RA) only. there is no motorized correction for Declination (DEC) in this scope; adjustments are made by either round knob on the lower half of the forks. However, if any telescope is reasonably well polar aligned there will be minimal if any necessity to change the DEC. This is the primary reason for polar aligning a scope; it allows for tracking adjusting only one axis (the RA). If a telescope is altitude/azimuth aligned - such as setting the ETX on a table - then both axes would need to be adjusted to compensate for the Earth's motion.
I would suggest you try it on the Moon first; it's easy to find and would allow for quicker verification of the tracking.
Good luck and have fun. And don't forget to enjoy the views which, after all, is why we obtain telescopes!
Regards, Marc
Goseck Observatory
Kunming 152 f/5.9 & Baader Wedge
Orion ED80 & LS75FHa2/B1200
Meade 102ED & LS18CaKMDd2
4 registered and 0 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
