Privacy Policy |
Please read our Terms
of Service | Signup and
arpruss
Reged: 05/23/08
Loc: Waco, TX
Here is a naive question. Let's say I bought an F/4 or F/3 200mm uncoated PCX condenser lens (about $80-84) from Anchor Optics, stuck it in a tube, and used it with, say, an O-III filter and a wide long FL eyepiece. Would this make a nice wide-field nebula scope, or would things look horrible? I am guessing the latter--or is it worth doing the experiment?
-------------------- Coulter Odyssey 13.1" split-tube
Coulter Odyssey 8"
Home-made 7.8" F/4 dobsonian travel scope
Home-made 68mm F/5.3 achro (typically used as finder on 13.1")
Skymaster 15x70
BPTs4 8x30
32mm Plossl, 30mm Rini, 27mm Kellner, 13mm Hyperion, 6mm TMB/BO Planetary, Owl 2X Barlow
Palm TX with AstroInfo and RescoViewer
walt r
Reged: 02/13/07
Loc: Doylestown, PA
The OIII filter would probably reduce the CA (chromatic aberration) to reasonable limits. But simple PCX lens also have additional aberrations like SA (spherical aberration) especially at small focal ratios. Check here for more info.
If you have an OIII filter and a simple lens give it a try.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
3 registered and 2 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
