wenjha
newbie
Reged: 09/24/08
can we estimate the PV. value from star test? new
      #3365381 - 09/30/09 05:00 AM
Hi, all
I did star test for my 4 telesecopes.those reflector mirrors are made by my friend Mr Wong.
Mr Wong test mirror using double-pass autocollimator null test,here is the equipment:
and here are the Foucault Images of Parabolic 150F9:
he estimated the PV surface error as below :
Parabolic 150F9: 1/20 PV surface error
Spherical 150F9: 1/10 PV surface error
Parabolic 150F5: 1/10 PV surface error
I did star test:
star test is the only test method for me . all pictures are taken using a 3x barlow lens, a extendtube added for 150F5.
the star test result of 150F9 is more beautiful than 150F5 for F9 is more easy to collimate than 150F5, I am sure that the astigmatism of 150F5 is because of the misalign of secondary.
here also some plantary images taken by Spherical 150F9:
Spherical 150F9 is very good for me now. but I still want to know the actual PV error of each mirror.
can we estimate the PV value from the star test result?
Edited by wenjha (09/30/09 09:59 AM)
WahHK
Reged: 02/24/06
Re: can we estimate the PV. value from star test? new [Re: wenjha]
      #3365440 - 09/30/09 06:44 AM
It seems that the 150F9 is nearly perfect symmetric, what is the max PV error for a mirror that can produce similar result?
http://wahwah.dyndns.org:8080/gallery/main.php
wh48gs
Reged: 03/02/07
      #3365672 - 09/30/09 09:46 AM
Misalignment in the Newtonian doesn't induce astigmatism.
It is produced by surface deformation, either from fabrication process or improper mounting.
Vla
wenjha
newbie
Reged: 09/24/08
Re: can we estimate the PV. value from star test? [Re: wh48gs]
      #3367339 - 09/30/09 11:12 PM
Vla
Hi I met astigmatism in 150F9 too, but I corrected it by aligning the secondary
what important is that can I estimate the mirror error from star test?
9 registered and 5 anonymous users are browsing this forum.
