grendel
Reged: 04/12/09
Loc: Canterbury, Kent, UK
Well I have ordered a Carton 60mm x1000mm f/l lens, and am going to make up the refractor in some cardboard tubing from where I work, this has got me to thinking - I have 2 sizes of tube available, 85mm OD -76mm ID tube and 58mmOD - 50mm ID tube, this has me thinking 2" crayford focuser, with a very long draw tube, so I can space the bearings out further for better precision, over the next few weeks I will be looking at this and seeing how practical a solution I can come up with for this cardboard crayford, on a refractor. Grendel
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
WOW! I am interested on how you make out on that one. Let's have details.
grendel
Reged: 04/12/09
I am looking at using some sliding mirror wheels as the bearings, they will be mounted to the outer tube and spaced quite well apart to allow for good alignment of the drawtube, I have calculated that a 2" ID drawtube can be 750mm long before it even starts getting into the light path. Basically the outer part of the focuser will be the main tube of the scope and the f16.7 focal ratio should give great views of the moon and planets, I have had good reports of the performance of scopes with these carton objectives. once I recieve the objective I can start building at the moment I am working on it in CAD. Grendel
neo
Reged: 02/12/08
Loc: Iasi, Romania
Hi Grendel,
Sounds very interesting...I've never heard making a cardbord focuser before . One concern would be if the draw tube is strong enough when pressure is applied. I was thinking to treat it with some epoxy just to be sure.
Good luck with your project and ...lots of pictures
Alex
-------------------- Russian 15x50 binos
Home made 8" f/5 Newton on eq mount
Home made 70mm f/6 (Rodenstock Rotelar lens) Apo refractor
www.astronomy.ro
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Try using 2 inch diameter, or thereabouts plastic tubing for rain gutter down pipes, available at your friendly hardware or DIY store.
grendel
Reged: 04/12/09
Well thats something I will find out I guess, I already have the cardboard tube (its a waste product from the drawing office I run) and in my experience its a lot stiffer than the equivalent sized pvc tube. I was planning to use car spray paint as I have in the past, a couple of good coats of primer and a few white topcoats seals the tube from water, and some matt black down the inside seals that and raises some fluff on the side walls.
I have tested my 2" to 1 1/4" adaptor and its a good tight fit in the end of the 2" tube, so that sorts out the eyepiece end of the drawtube. The plans are coming on apace , I have the wheels in place and the bearing pivot axis is just outside the tube which makes things easier to construct mounting blocks to fit on the outside of the tube
Edited by grendel (10/04/09 04:47 AM)
grendel
Reged: 04/12/09
another viewpoint, I still have to cut the holes in the tube for the wheels to run. 3D drawing and rendering is a real brain twister as you have to be able to think three dimensionally and thenyou have to remember the right tools to create the effect you want.
Grendel
Edited by grendel (10/04/09 05:06 AM)
grendel
Reged: 04/12/09
virtual progress:- Grendel
grendel
Reged: 04/12/09
the focuser will have 2 sections one fixed, and the other sprung loaded to push the axle against the drawtube. Grendel
timo4352
Reged: 04/16/07
Loc: Northeast Ohio
I love the ingenuity. And I love building stuff too - especially with free materials. Have you thought about some type of seal at the focuser end?
Tim
-------------------- Orion 3.6CA Reflector
and 2 homebrew scopes --
8" Hubble Bubble ballscope
8" F/8 CHief - nearing completion
grendel
Reged: 04/12/09
Not yet, maybe some bit of plumbing fitting? I'll have a dig round my scrap box, maybe just a cut out wooden donut to fit in the middle. Grendel
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Very ingenious, I look forward to seeing the finished product.
grendel
Reged: 04/12/09
well mark one focusing block was made today, it highlighted 2 problems,
1. I need an 85mm hole saw, not an 83mm one
and
2. I need to go get my pillar drill from my mother in laws (or go there to use it) to drill the holes for the long tension adjusting screws (the holes are a fraction off alignment as I just hand drilled by eye on this mark one version.
This version is binding a bit and too tight on the tube, but thats not a problem really as I was only trying it as concept at this stage.
Grendel
Edited by grendel (10/08/09 06:01 PM)
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Looks good.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
Hi Pete, may be easier to mount the wheels on a 90 deg V ?
-------------------- Jc
ATM 10" F6.1, 1/25th wave spec (max wavefront error +/- 1/12.6 in zone 4 of 6, sodium light )
6" F7 spec
127mm F9.4 Refractor
10 x 50 bin
ETX80 (finder)
Canon 20D
PST
DSI 1
and a curious mind
grendel
Reged: 04/12/09
John C I may use a similar segment of a block like I have for the focuser. Grendel
