EdZ
Professor EdZ
Reged: 02/15/02
Links to Resources and Information
      #3367870 - 10/01/09 06:57 AM
Links to some of relevant infomation about Binocular Viewing
EdZ
Professor EdZ
Reged: 02/15/02
Intro to prisms and beam-splitters new [Re: EdZ]
      #3367871 - 10/01/09 06:59 AM
http://www.microscopy.fsu.edu/primer/lightandcolor/prismsandbeamsplitters.html
EdZ
Professor EdZ
Reged: 02/15/02
Vision Information Articles new [Re: EdZ]
      #3367873 - 10/01/09 07:00 AM
The Joy of Visual Perception
Webvision - The Organization of the Retina and Visual System
Vision Science III - Binocular Vision Module
Northeastern State University College of Optometry, Tahlequah, OK
Vision Science course module by Thomas O. Salmon, OD, PhD
Vision Science Home
EdZ
Professor EdZ
Reged: 02/15/02
Binocular Vision Summation new [Re: EdZ]
      #3367878 - 10/01/09 07:03 AM
A comprehensive explanation of Binocular Summation, how binoculars, telescopes and telescope/Binoviewers all compare and the benefits that can be derived from each.
A compilation of writings on Binocular Summation. Includes several noteworthy posts of imporant information on vision.
Beamsplitter Transmission Variances Affect Binocular Vision Summation
read the entire thread for a great info
Do you have issues merging images? Read this.
"Training" your eyes to merge images is simply training your eyes to accept eye strain.
Edited by EdZ (02/13/10 08:08 AM)
EdZ
Professor EdZ
Reged: 02/15/02
Binoviewers - Binocular/Monocular Equivalents new [Re: EdZ]
      #3367880 - 10/01/09 07:04 AM
Calculations are presented for several examples of Binoviewer/Scope , Monocular Scope and Binocular to help users compare Equivalents of Monocular and Binocular Aperture.
Also
Data collected from three different models binoviewers shows how binoviewer clear aperture restricts field of view. Field of View is compared for Binoviewer/Scope, Monocular Scope and Binoculars. A summary is given for lowest power acceptable (non-orthoscopic fov) field of view for binoviewers and then that is also give as a binocular equivalent.
Binoviewers and Binoculars (equivalents)
Edited by EdZ (02/11/10 06:05 AM)
EdZ
Professor EdZ
Reged: 02/15/02
Binoviewers, Focal Lngth, Power and Clear Aperture new [Re: EdZ]
      #3367884 - 10/01/09 07:05 AM
Binoviewers and Clear Aperture
If selecting one of the 20mm CA binoviewers on the market, not only is there a light loss at the outer edges of the field stops, but also the Maximum True Field of View that you can get will be restricted to eyepieces with field stops about 22-23mm max.
Which binoviewers are actually the same?
Here's a series of measurements some that are the same
Which are the same? Which are different? Where are they made?
Keep in mind, these are actually the same binoviewer. The "BODY" of the Burgess C and the Stellervue BV3 are exactly the same. In fact both of these are exactly the same as the WO binoviewer and the Orion binoviewer and the older Moonfish BV. They appear to be the same as the Celestron and the Antares binoviewers. At various points in the past some of these older binoviewers had only 18mm clear aperture. The Stellervue, Orion, WO and BurgessC all have 20mm clear aperture. The only thing different about these binoviewers is the eyepiece holders. So, if one happens to have a brighter side than the other, that may be just luck of the draw.
Binoviewers that are not the same as those listed above include Baader Maxbright, BW-Optic, Lumicon, Televue, Seibert and Denkmeier.
edz
Here's the same binoviewer seen commercially available from a half dozen different dealers. It's shown here with options for every available configuration I've seen from any American dealer (1 screw, 3 screw and twist lock collets) .
United Optics - Kunming
Eyepiece FS Diameters for Binoviewers
Is there a scope that's best for binoviewing?
This post in the Binoviewer forum starts out " A few things you should know about binoviewers and scopes". This post explains not only how clear aperture affects the field of view, but also how the various attachments to the binoviewer nose change from the specified magnification factor when used in different scope/diagonal configurations. It is my experience, some people that are using binoviewers with an SCT scope have no clear idea what magnification they are using or what they are getting for true field of view. This post helps explain some of the above.
The Focal Length of an SCT scope
It is almost always NOT what is stated by the manufacturer. That is nominal focal length of an SCT. The calculations are complex, but the concept is relatively easy to understand. If you want to find the actual focal length of your SCT, read the next link about Drift Timing Eyepieces.
You cannot trust the manufacturer stated power factors for binoviewers. There are just too many pieces in the light path that have an affect on the operating focal length. this is especially significant for SCT scopes, where many people are not even aware that the operating focal length is longer than the nominal stated, and that SCT focal length varies with every little turn of the focuser knob. You can determine YOUR operating power factors with your binoviewers. Here's how.
Drift Timing Eyepieces to Determine True Operating Magnification
In this respect, a Mak operates exactly like the SCT. In essence, every bit of length you add to the the light path at the back end of any SCT or Mak scope changes the focal length. A typical f/10 5" or 6" SCT with a diagonal and standard binoviewer may be operating closer to f/13 or f/14. The typical f/15 Mak may be operating near f/18.
Determining the Operating Focal Length of any Moveable Mirror Scope
EdZ
Professor EdZ
Reged: 02/15/02
Miscollimation Allowable Error new [Re: EdZ]
      #3367886 - 10/01/09 07:06 AM
If the images are not merged, tollerance for that miscollimation is entirely dependant on the magnification in use. Generally, everyone can tollerate some small misalignment and the eyes will merge the images. Tthe higher you go in power to more stringent the requirements
Miscollimation Allowable Errors
You can measure miscollimation by observing a double star. You need to know the separation of the double. An even double works best. When you observe the pair and watch for the merging of the images, compare the mis-match of each star (or the amount it does not merge), to the separation of the double. I've used this method to measure collimation down to about 10 arcseconds.
For reference 1 inch at 100 yards is just slightly less than 1 arcminute, and this is about 3x to 4x worse than the least problematic allowable error.
edz
rick rian
Seeker of Truth(s)
Reged: 08/03/04
Loc: Upper Mid West
Re:DIY Televue Binovue Alignment Process new [Re: EdZ]
      #5375386 - 08/19/12 12:24 AM
Link
1 registered and 3 anonymous users are browsing this forum.
Moderator:  TG, Geo557
