Telescope Specific Forums >> Meade ACF/RCX / LX / GPS
ETXer
Reged: 09/03/09
Loc: Rockville, MD USA
Meade LX50 with Magellan I
      #3368411 - 10/03/09 12:49 PM
Hello! I'm new to the community and this is my first post with a question. I will obtain an LX50 shortly and I ran across a Magellan I system for sale. Will the Magellan I work ok with the LX50? I read the Magellan I manual online and it doesn't really specify, so any help would be appreciated. I know the Magellan II was advertised to work with the LX50, but no info on the Magellan I. Thanks in advance!
Allan
Celestron Celestar 8 Deluxe
Early 80's Celestron Orange Tube C8 w/ Byers Drive
Meade ETX 90EC
Reged: 07/06/07
Re: Meade LX50 with Magellan I new [Re: ETXer]
      #3368504 - 10/03/09 01:26 PM
It will work IF you have the proper encoder mounting hardware. It would not be plug and play like the Mag II AFAIK...
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
ETXer
Reged: 09/03/09
Re: Meade LX50 with Magellan I new [Re: rmollise]
      #3368648 - 10/03/09 02:29 PM
Thanks! I do believe the Magellan 1 I saw for sale comes with the required hardware. Cheers
Allan
Meade ETX 90EC
Matthew Ota
Reged: 04/30/05
Loc: New England
      #3369138 - 10/03/09 06:26 PM
IMHO you are taking a gamble. The Magellan II on the LX50 was not very good at accuracy, and it was designed from the get go for the LX50. I struggled with mine for years until I deforked the OTA and place it on an LX200GPS mount.
Matthew Ota
Meade LX250GPS 10 inch SCT (Frankenscope)
Orion ED 80
ETX-90 OTA
Coronado Helios 1 H-alpha
TheSky 6 Pro
Lynnblac
Reged: 04/06/09
      #3369255 - 10/03/09 07:29 PM
I upgraded my 8" LX-10 with a LX-50 fork mount. I was able to adapt the Magellan I to the LX-50 with some modifications. It is not a bolt up installation, more of a ATM project. I was even able to use one of the Magellan I plastic covers to protect the exposed dec gears on the LX-50. It all fit in the mounts castings, only exposed part is the wiring. Lynn
ETXer
Reged: 09/03/09
Re: Meade LX50 with Magellan I new [Re: Lynnblac]
      #3369511 - 10/03/09 09:50 PM
Thanks Matthew and Lynn! After that did it work OK? Was the accuracy reasonable? After reading the Magellan I manual, it would appear that it's compatible, but there were no installation instructions on the Meade website to be certain.
Allan
Meade ETX 90EC
GUNER
Reged: 07/19/04
Loc: Bedminster,NJ USA
      #3369766 - 10/04/09 12:35 AM
The LX-50 I bought came with the Mag 1 installed but I could never get it to work. I bought a Mag 2 from Meade & installed it. Unlike Matthew my works very well.
If you end up buying it I still have the Mag 1 parts so if your missing anything I might have it just let me know.
Thomas
17mm ETHOS NEAF Door Prize
THANK-YOU TELEVUE!!!!
12" SuperCharged LX-200 GPS
TAK SKY 90 on a Vixen Skypod
Stacked GOLD!PST/EXT-70AT/DSX-125
Infinity 2-1 CCD Camera with Lucam Recorder
Custom Scientific 1.25" LRGB filters
AV in CMH
Reged: 11/07/05
Loc: Columbus Ohio
      #3370225 - 10/04/09 09:04 AM
FWIW,
I have a M1 and have used it with various scopes over the years.
What I have found is that if the encoders are directly mounted to the scope versus using the " mount hardware gears" the accuracy is good and consistent.
By good I means that in a 6" F5 or 8"F5.6 with a 17mm TV the object ends up in the FOV on just about every search. When its not in the FOV is just barely outside of it. Considering the DB and ease of use I think the M1 is underated.
Before you give up on using the M1 give it try.
Anthony
Lynnblac
Reged: 04/06/09
Re: Meade LX50 with Magellan I new [Re: AV in CMH]
      #3370802 - 10/04/09 02:06 PM
Using the Magellan in the alt/az mode seems to increase it accuracy. Believe it or not this works when it is mounted on the fork mount and then mounted on the wedge at the proper latitude. When you set it up this way the Magellan is operating like it is setting at the pole. Lynn
Edited by Lynnblac (10/04/09 02:11 PM)
ETXer
Reged: 09/03/09
      #3371828 - 10/05/09 12:15 AM
Wow, thank you all for the great responses! Sounds like it's definitely doable. Now, just waiting for the scope to arrive...
Cheers, Allan
Allan
Meade ETX 90EC
Moderator:  Joad
