Telescope Specific Forums >> Meade ACF/RCX / LX / GPS
Rayh
Reged: 08/22/05
Loc: Gilbert, AZ, USA
LX200GPS PEC new
      #3344581 - 09/20/09 10:41 AM
I did a periodic error correction on my 12" LX200 GPS using PhD guiding to supply the training commands. The training sessions were stable in both DEC and RA. However, when I turn on PEC for RA afterwards the scope drifts in RA several arc-minutes per minute. If I turn off PEC or use the factory installed PEC, the scope tracks fine. The DEC works fine.
I have repeated the process several times with no luck.
Your help would be much appreciated.
Ray
Ray Heinle
Gilbert, Arizona, USA
7" LX 200GPS MAK, 12" LX200 GPS, Celestron 80ED
QHY8
Orion SSDSI, Meade LPI
Nikon D40x, SBIG ST-6
chicot
Reged: 09/30/08
Loc: Liverpool, UK
Re: LX200GPS PEC new [Re: Rayh]
      #3345563 - 09/20/09 08:48 PM
Download the free trial version (30 day) of Pempro and use that instead. I think that should be more effective than using PHD guiding. At a guess, I would expect that to get rid of the RA drift problem.
Meade 10-inch LX200 classic
Williams Optics ZII80
Starlight Xpress SXV-H9
Starlight Xpress Lodestar autoguider
Meade DSI III
Rayh
Reged: 08/22/05
Re: LX200GPS PEC new [Re: chicot]
      #3347274 - 09/21/09 04:46 PM
I will give Pempro a try when I return home in a couple of weeks. The description looks good but $150 is more than I would normally spend for any software product. I might be able to fix my problem in 30 days.
Thanks for the advice.
Ray
Ray Heinle
QHY8
quantumac
Reged: 12/17/07
Re: LX200GPS PEC [Re: Rayh]
      #3369743 - 10/04/09 12:18 AM
In my permanently mounted 10" LX200R situation, I use PHD. My scope is equatorial mounted, drift-aligned, PEC trained, and dynamically balanced using weights on both sides of the OTA. I also use an OAG instead of a guide-scope, because OAGs are not susceptible to differential flexture. All these things improved my DSO imaging efforts. I rarely perform DEC adjustments, but when I do, they are quite small and I perform them manually.
Astrophotography is not necessarily a game for the wealthy, but it is a game for the patient.
Scope: Meade 10" LX200R
Guide/Planetary Camera: Imaging Source DBK41AF02.AS
DSO Camera: QHY8
Guide Hardware: Celestron OAG, Shoestring Astronomy GPUSB
Software: Mac OS X, Starry Night Pro, Nebulosity, PHD Guiding, PixInsight, Astro IIDC. No Windows anything.
Edited by quantumac (10/04/09 12:21 AM)
1 registered and 3 anonymous users are browsing this forum.
Moderator:  Joad
