mblack
Throw me a bone here
Reged: 10/31/05
Loc: Naples, Florida
CG5 owners south of 30° latitude? new
      #3370359 - 10/04/09 10:26 AM
Hi-
I was considering the CG5-GT and was reading Celestrons two workarounds that enable the mount to operate south of 30° latitude.
(read them here)
The workarounds seem like they wouldn't degrade the stability of the mount, but that's why I'm asking.
So, anybody south of 30° using these two workarounds on their CG5?
Dave B.
"Those are my principles, and if you don't like them... well, I have others." Groucho Marx
Eddgie
Reged: 02/01/06
Re: CG5 owners south of 30° latitude? new [Re: mblack]
      #3370432 - 10/04/09 11:04 AM
Pay particular attention to the caution about the mount tipping over.
This is more likely if the mount is used with the legs in their lowest configuration and with no OTA on the mount (like when setting up or taking down).
Had this happen once. Pulled of a C9.25, turned, bumped into the mount, and it toppoled over. No serious damage but it was unsettling to say the least.
With a light scope and only a small amount of counterweight, or when the legs are fully extended, this is not a concern at all. More of a concern with heavy counterweight/low height configuration (Big SCT).
Otherwise, mount is just as solid in either configuration.
Celestron C14, CGE (Big Al)
Astro-Physics 6" f/8 (Buffy)
Televue 101 (No name, but I call it my Widescreen HD Space TV)
The night sky is my mistress. She seduces me away from all other lovers.
mblack
Reged: 10/31/05
Re: CG5 owners south of 30° latitude? new [Re: Eddgie]
      #3370455 - 10/04/09 11:24 AM
Ed- Thanks for the advice.
I found a good deal on this mount (new) so I'm gonna pick one up and try the workarounds.
Dave B.
Reged: 07/06/07
      #3370633 - 10/04/09 12:49 PM
Hi-
(read them here)
Even though I am "only" at 30 degrees N, I had to do both these things (remove front bolt, place peg so counterweight is between two legs).
After nearly four years of use neither operation has caused any sort of problem.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
mblack
Reged: 10/31/05
Re: CG5 owners south of 30° latitude? [Re: rmollise]
      #3370691 - 10/04/09 01:15 PM
That's what I was hoping to hear. Thnks.
Dave B.
8 registered and 9 anonymous users are browsing this forum.
