nik hodges
Reged: 04/20/07
Loc: UK
Re: Takahashi Mounts new [Re: Rusty]
      #3361837 - 09/28/09 02:10 PM
Spend the extra money - I've only known two owners of AP900s, and both wished they'd gotten the 1200
i can kind of see what you are saying but i don't regret my choice.
I have no plans/desires for a 16inch RC or some such and for any optical tube i am ever likely to consider owning the AP900 suits me perfectly. With PE of +/-1.5 out of the box uncorrected whats not to like.
If i did ever want a bigger mount id be looking at the El Capitan and doing it in style!!!
AP900gto3
Flurostar 110/TAK TOA 0.75 reducer
Megrez 80mm triplet apo/moonlight focuser
8" LX200R/AP CCDT67 reducer/moonlight focuser
StarlightXpress SXVF-H16 camera/trutek filter wheel
DSI Pro II
Maxim DL/Maxpoint/PEMPro/CCDAP4/Sky6Pro/AdobePS3E
http://www.pbase.com/njh542/images2009
Smo
Reged: 01/19/09
Loc: North Vancouver, BC, Canada
Re: Takahashi Mounts new [Re: nik hodges]
      #3361880 - 09/28/09 02:35 PM
I am actually waffling back to the 900.
After thought the 70 pounds I am hearing is a legit 70 pounds that you can image at. You don't need to follow the ultra conservative 50% of the weight capacity.
So even a new Edge HD C14 at what 45lbs with camera and mounting gear you are maybe 55 lbs and from what I am hearing you will still track perfectly fine.
Which also means 12 inch RC's are possible maybe even 14 RC's so yah I think I should be fine.
Does anyone object with this, regarding putting 50, 60 or even up to the 70 lbs on this mount for imaging? if so what % of the 70 lbs do you feel is the max to image well.
Russ
20" Obsession F5 with Argo Navis and Servo Cat.
Televue NP127is
Astro-Physics 1200GTO on an AP Portable 10x48 Pier
Astro-Physics 900GTO on an AP Portable 8x42 Pier
SBIG STL-11000 Mono/2" Astrodon LRGB and Ha
DMK 21AU04/OFW/1.25" Astronomik LRGB
DeanS
Reged: 07/12/05
Loc: Nicholasville, Kentucky
Re: Takahashi Mounts new [Re: Smo]
      #3361913 - 09/28/09 02:51 PM
I don't think you will regret the AP900, particularly if you need to set it up nightly. I was on the list for the 900 a couple years ago, then jumped up to the 1200 because it was available, and only $1k more. Love the mount but even the half's get heavy when I take it to star parties.
I just upgraded my Mach1 to the 900 for the little extra capacity in case I don't want to lug out the 1200.
Dean
AP1200GTO AP900GTO
TOA-150 Tak E160
C9.25 Tak FS60C
SXV-H9 ST2000XM STV
8" LX200GPS
Meade 12" Lightbridge
Moonlite Focusers
www.doghouseastronomy.com
Smo
Reged: 01/19/09
Re: Takahashi Mounts new [Re: DeanS]
      #3362128 - 09/28/09 04:46 PM
Thanks for the input.
Any opinion on the weight question I posed above?
Russ
Televue NP127is
Smo
Reged: 01/19/09
      #3362355 - 09/28/09 07:06 PM
Well here is how I solved the problem. I ordered the 900 which should ship in October and put my name on the list for the 1200. So when the 1200 comes available I could sell my 900 etc etc.
Now I must practice increasing my patience as I wait.
Thanks to everyone for the input.
Russ
Televue NP127is
shadowdoc31
Reged: 11/27/08
Re: Takahashi Mounts new [Re: Ken Sturrock]
      #3370530 - 10/04/09 12:01 PM
Awesome thread guys-- I think I'm almost sold on
buying the Tak EM200. My imaging experience is quite
limited, but the integrated polar alignment scope seems
like a "must have"...
Any specific recs on the best way to power this thing?
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.22 X 90....
Re: Takahashi Mounts new [Re: shadowdoc31]
      #3371601 - 10/04/09 10:03 PM
I've not owned one, but most of the guys that I've spoken to about the Tak mounts use 24 volts to get the quicker slew rates.
David
Proud Member; PAS NOLA,
"If we knew what we were doing, it wouldn't be called research..."
A. Einstein
gnowellsct
Reged: 06/24/09
Re: Takahashi Mounts [Re: Rusty]
      #3373585 - 10/05/09 11:16 PM
Oh gosh, I don't wish I'd gotten an AP1200, and I use a C14 with a top mounted 4" refractor. I'm happier with the AP900. I don't do imaging, but I think I could with this rig, but the main point is, I always drive to a club site, and I really don't want the extra weight and bulk of the AP1200. If I ever get into photography that may change, but I don't seem to have strong pulls in that direction.
regards,
Greg n
"Aperture will get you through times of no money better than money will get you through times of no aperture."
featuring selected astrojunk:
bunch o' widefield eyepieces
bunch o' narrowfield eyepieces
couple o' Barlows
couple o' scopes
couple o' mounts
couple o' tripods
and a pier 'n' stuff
12 registered and 11 anonymous users are browsing this forum.
