ScottS
Reged: 04/01/05
Loc: Central Ohio
Modified my CGE stock tripod/mount...
      #3374946 - 10/06/09 04:34 PM Attachment (34 downloads)
Here are the results of my welding from the other evening. The casters are galvanized and the extension tubes are stainless steal. I will add lengths of straight from leg to leg to increase over all strength and stability and to get all the force off the stock center hub. This is my progress so far. Overall it added 4" to he overall height... not so bad.
ScottS
Celestron CGE1100 XLT w/Celestron C80 ED APO Piggy back
Celestron NexStar 11 GPS XLT
ST-2000XM w/CFW8A Filter Wheel
Celestron F/6.3 & F/3.3 Focal Reducer
Meade Zero Shift Micro Focuser
DSI Pro w/Filter & DSI Color
Canon 5D MarkII un-modified
Kendrick 2081 Power Pack 12v 18aH
Kendrick Premier Dew Controller
Telrad Reflex Sight Finder
MaxIm DL, Starry Night Pro Plus
HP G70-460US Laptop
http://www.teamastro.com
ScottS
Reged: 04/01/05
Loc: Central Ohio
Re: Modified my CGE stock tripod/mount... new [Re: ScottS]
      #3374949 - 10/06/09 04:35 PM Attachment (25 downloads)
photo #2
ScottS
HP G70-460US Laptop
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
      #3375149 - 10/06/09 06:19 PM
Scott,
Nice work.
Do you move the whole unit around with the scope(s) mounted? If so it looks like that you'll be getting close to the top (bottom) of the garage door when it's open (he says from experience ).
Any plans for some threaded rods to lift the wheels off of the ground when everything is in position? It looks like it would be a piece of cake to build a plate with a nice threaded nut that would bolt up to the existing mounting plate for each caster. I was just thinking because you'll remove any potential play from the wheel bearings with the wheels off the ground.
Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
ScottS
Reged: 04/01/05
Loc: Central Ohio
Re: Modified my CGE stock tripod/mount... new [Re: mclewis1]
      #3375227 - 10/06/09 06:50 PM
THAT IS A GREAT IDEA (leveling rods)!!! I will do that for sure!!!! That can even help with level too and as you mentioned the bit of play that might be there!!!! !!!
When moving , yes all is moved together as the photo shows, but I move it from the switch position to a home position to get it's center of gravity as low as possible.
But what an idea you gave with the leveling rods!!!! WOOT WOOT!!!! I will post photos after the new idea is implemented!!!!!!
ScottS
HP G70-460US Laptop
jason_milani
Reged: 09/03/04
Loc: Northeast Ohio
      #3375436 - 10/06/09 08:52 PM
Very cool modifications!
Celestron C-14
Celestron C-8
Celestron C-5
Orion/Vixen ED114SS APO
William Optics Megrez 72mm ED
Celestron CGE mount
Discmount DM-4
Mallincam Hyper Color Plus
Baader UV/IR Modded Canon 40D
mclewis1
Thread Killer
Reged: 02/25/06
Re: Modified my CGE stock tripod/mount... new [Re: jason_milani]
      #3376352 - 10/07/09 11:05 AM
Scott,
I posted some modifications to a Scopebuggy a while ago. I think you might find the threaded rods used for leveling interesting - link. I got them at McMaster-Carr. The rods are stainless steel and the handles are simply epoxied onto the ends. Those larger handles really make a big difference with a heavy setup, I find smaller knobs just annoying, especially in the cold.
Threaded rods - link
Handles - link
If I was in a position to do some welding I would have also removed the basic 3/8" nuts that came on the Scopebuggy and used a larger threaded nut or coupler like this. As it stands now the wing nuts you see in the picture do a very good job of locking down the leveling rods. The wing nuts with a big washer on the top side and the welded nuts are on the bottom of that black bar.
Mark
ScottS
Reged: 04/01/05
Loc: Central Ohio
      #3376588 - 10/07/09 01:28 PM
mc Thanks. That was a great idea you had on the SB. I like the handles; I was wonder how/where to get them. I'll be ordering so parts shortly once I get the actual design drawn up. Thanks again!
ScottS
HP G70-460US Laptop
15 registered and 14 anonymous users are browsing this forum.
