Equipment Discussions >> Classic Telescopes
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
Cave or Criterion??
      #3382557 - 10/10/09 05:57 PM Attachment (36 downloads)
Can anyone tell me who the manufacturer of this 8 inch scope is? I was told it was a Cave, but it came with a Criterion eyepiece and an Optica 25X60 finder. It also came with an Comstar 4.25 scope bungees corded to an old Edmund GEM mount. I am hoping I can use the mount for the 8 inch scope.
Tasco 15TE
Mizar 80mmX1200mm
8 Inch reflector awaiting for me to figure out what to do with it..
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
Re: Cave or Criterion?? new [Re: Ham Radio]
      #3382710 - 10/10/09 07:32 PM
It looks to be assembled from parts and not 100% from one manufacture vs the other. The tube looks to be made by Parks and Cave used them but one could also buy them directly from Parks to build you own 'scope. Add to that the finder is non standard for either company and while the focusers looks to be Criterion, they used a different type of tube and most didn't have end rings.
The mirror will be key. Cave mirrors are usually fine ground flat on the back and somewhere on the back scripted as being made by Cave.
- Dave
Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
teast
Reged: 11/10/07
Loc: Kentucky
Re: Cave or Criterion?? new [Re: DAVIDG]
      #3382852 - 10/10/09 09:28 PM
I doesn't look like any Criterion I've ever seen. Some Criterions came with tube end rings but most didn't, and the focuser and spider are usually much closer to the end of the tube on Criterions.
Also, Criterion mounted the focuser with the knobs in line with the scope tube, not from the side as in the photo. The base of the focuser was curved to fit the curve of the tube and would only go on that way. Of course, someone could have swapped it out, but my guess is that Dave is right and it's got bits and pieces from several different makes.
-Tom
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
      #3382881 - 10/10/09 09:45 PM Attachment (14 downloads)
Thanks for the info.. Here are a couple of pictures of the back of the mirror. There is an edge around the outside and the letter "P" or "d" depending on how you look at it on the back.
Tasco 15TE
Mizar 80mmX1200mm
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
      #3382884 - 10/10/09 09:46 PM Attachment (16 downloads)
Here is a picture of the mirror cell if that would help.
Tasco 15TE
Mizar 80mmX1200mm
actionhac
Reged: 08/09/08
Loc: WA
      #3382974 - 10/10/09 10:54 PM
Edmund cell. Never seen a Criterion 8" cell so not sure if they could be the same.
Could we see a picture of the mount?
Robert
albert1
Reged: 01/01/07
Loc: Northern New Jersey
Re: Cave or Criterion?? new [Re: actionhac]
      #3383064 - 10/11/09 12:29 AM
Edmund cell were my thoughts too.
Let's see a closeup of the focuser?
Albert
1 Great 'ole Newt
6 Good 'ole Newts
3 Great 'ole Cats
1 Lousy 'ole Newt
One of these days I'll try a Refractor better than my 90mm finderscope
mustgobigger
Reged: 06/12/07
Re: Cave or Criterion?? new [Re: albert1]
      #3383112 - 10/11/09 01:21 AM Attachment (10 downloads)
i had a Edmund mirror that i picked up at a estate sale
and it looked like that mirror back.
Brian
RV-6
Meade 826
Meade 880 Deluxe
Unitron's 114,128,140,142,150,152,155,160
4" Jaegertron
4.5" A.E f/14 Refractor
4" f/15 Edmund's Refractor
deSitter
Reged: 12/09/04
Re: Cave or Criterion?? new [Re: mustgobigger]
      #3383212 - 10/11/09 05:11 AM
Definitely Edmund cell and mirror. Looks like it could be a Criterion focuser - not a Jaegers, not Optica, not Telescopics, not Edmund. Criterion also had tubes with end rings but they tended to put the focuser way up the tube. Optica sold a 25x50mm guider/finder but not a 25x60mm in the catalog I know.
-drl
clintwhitman
Caveman
Reged: 01/01/07
Loc: ValVerde CA(SoEasyaCavemanCanD...
      #3383297 - 10/11/09 08:19 AM Attachment (6 downloads)
It isnt Cave stuff, I would have to agree with the Edmunds guess. Criterion focusers are easy to spot. I have very little Edmunds stuff but there old optics have always impressed me, I have a very old 50s prizum Diag. That is one of the best I own, Sharp as a tack and is always out of the box when I am using old scopes.
Clint
Clint&Debbie Whitman (aveman
1960s 6"F15 Jaegers-Unipons by John Pons on a Byers 812, 1947 4" F15 TINSLEY, 1965 10" F8 CAVE, 1950 5CM & 6.5CM Nippon Kogakus (the twins), 1960s UNITRONS a 152 restored a 160 numbered green lens original mint a 114 original 50s mint, 1950s UNITRON M100 100mm F15 OTA, WO 80mm Florite, ASTROPHYSICS 155 EDFS on LOSMANDY G11, a bunch of Tascos,Sears Mayflowers The list goes on Add infinitum.
Reged: 07/06/07
      #3383300 - 10/11/09 08:23 AM
Definitely not a Criterion. My diagnosis? Home built from parts (Parks, Edmund, etc.)...which ain't a bad thing if it was inexpensive enough.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
Re: Cave or Criterion?? new [Re: rmollise]
      #3383325 - 10/11/09 08:49 AM
Sounds good folks, thanks for the input. Unfortunately there isn't a mount yet. It didn't come with one. I do know the mount the guy had under the 4.25 scope is an Edmund and the scope was mounted on it at one time. The mount is pretty heavy and if I can figure out how to put this scope on it I might try it and see if it works ok. The mount is way overkill for the 4.25 scope. Just have top figure out how to make some rings or something..
Tasco 15TE
Mizar 80mmX1200mm
actionhac
Reged: 08/09/08
Loc: WA
Re: Cave or Criterion?? new [Re: clintwhitman]
      #3383529 - 10/11/09 11:31 AM
The old Edmund diagonals like that one are superb, and that Edmund 1" Kellner in lower right.
The 8" mirror could be a f8, if Edmund or Criterion it will be a UPCO and also superb.
If the mount is too heavy to pick up may be a Edmund 1.5" and also excellent, will handle that 8" OTA like it was a cracker jack's pirate scope.
Robert
actionhac
Reged: 08/09/08
Loc: WA
      #3383601 - 10/11/09 12:01 PM Attachment (11 downloads)
Here is my well used Edmund 1.5" with a 10" OTA. This is all cast iron castings, very heavy. But you can see the distinct style and the way you would attach the OTA with straps.
Robert
CHASLX200
Reged: 09/29/07
Loc: Tampa area Florida
      #3383609 - 10/11/09 12:05 PM
I never saw a finder and rimg mounts like i see on the above pic.
Chas
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3383644 - 10/11/09 12:16 PM
Clint....I have an old Jaegers prism diagonal. They look very similar and it is flawless. What is that old Jaegers eyepiece? Mine is an "extremely" wide field 15mm Erfle. Mike
7x35 and 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957), 4.25" f/14.8 tasco 20te.
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
Re: Cave or Criterion?? new [Re: mikey cee]
      #3383656 - 10/11/09 12:25 PM
Well the shafts are 1 inch. Would that be ok or should I try to figure out something else? Also are those just banding straps or something like that?
Tasco 15TE
Mizar 80mmX1200mm
Telescopeman54
Vendor - Trapezium Telescopes & Services, LLC.
Reged: 08/17/07
Loc: New Hampshire
Re: Cave or Criterion?? [Re: Ham Radio]
      #3383722 - 10/11/09 12:55 PM
A close up of the focuser would help.
The mirror cell is definitely Edmund. I suspect the mirror is also Edmund. It is a match for my 6" f/8 Edmund mirrors.
The tube is probably a Parks.
The finder rings are most likely from Jeagers.
The finder is a small scope that was probably marketed as a table top scope, orignally and was adapted as a focuser.
The GEM with 1" axles was for the 6" reflectors and 4" refractors. ALL of the Edmund 8" OTAs were supported by a GEM with 1-1/2" axles.
This seems to be a home brew.
CS
Steve
Stephen Forbes - President
61 Valhalla Farm Road
Hillsboro, NH 03244
Web: http://TrapeziumTelescopes.com
Email: Stephen.Forbes@TrapeziumTelescopes.com
Phone: 1.603.325.0619
6" f/15 Jaegers refractor on GOTO GEM
5.1" f/8 Burgess on CG-5 w/ iOptron GOTONOVA
102mm f/7 refractor on iOptron Mini Tower
1975 Celestron Orange Tube C8 on Equatorial Mini Tower
1978 RV-6 on iOptron Mini Tower
actionhac
Reged: 08/09/08
Loc: WA
      #3383775 - 10/11/09 01:40 PM
The straps are generic hardware stainless straps with 1/4" swiveling studs on the ends. They come in a bunch of sizes. This is what was stock for this mount saddle. The 1" mount does not have the holes like this, for the strap studs.
The Edmund 1" shaft mount will be too small for that tube. It can be done but it will be under sized.
Robert
clintwhitman
Caveman
Reged: 01/01/07
      #3383860 - 10/11/09 02:45 PM
Mike I think Robert nailed it with the 1" erf. By the way the weird eyepieces is the Perterson Volcano top lower left. Never seen another one of those
10 registered and 5 anonymous users are browsing this forum.
Moderator:  RLTYS, Glassthrower, Clive Gibbons
