Privacy Policy |
Please read our Terms
of Service | Signup and
Karl_Bonner_1982
Reged: 05/13/09
Loc: Springfield, Oregon (4.5ish ma...
What's the minimum aperture that can resolve the arm structure on any spiral galaxy? Assume dark skies, no moon, and quality optics of course.
-------------------- A lot of signatures are just there because people think they are "supposed" to have a signature.
acey
Reged: 01/09/09
I've seen the spiral arms of M51 using an 8-inch. But it's a case of knowing what you're looking for, and taking time to spot the details. With a 12-inch it's easy.
It's possible to see the dust lane in M31 using binoculars, again if you know what to look for.
The key thing isn't aperture, it's practice.
Hrundi
Reged: 02/06/08
Loc: Estonia
It's also a difference in clearly resolving spiral arms, as opposed to seeing something that's probably spiral arms, but is helped along by our expectations.
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland
I've also seen the spiral arms of M51 in my 8" Newt. That was right beside my house in the middle of a red zone. It wasn't a matter of fulfilling expectations or averted imagination. The spiral arms were definitely there. M51 looked like one of those sweet pecan rolls. (I don't know why some DSOs look like food to me. M11, the Wild Duck, looks like a plate of hominey. ) I could also see the bridge to M51's companion. So it can be done. It is a matter of technique, practice, making sure your eyes are dark-adapted, and getting lucky with a transparent sky.
Clear Skies, Mike
-------------------- Celestron 10" f5 Newt on 1stBase (DSO)
Zhumell 8" f6 Newt, Bosma 6" f12 MCT (NSO)
6" f5 Newt, 130ST, 4.5" f4.4 Ball w/GLP, ST80 w/Crayford (RFTs)
C4-R (NSO/DS)
90mm f13 MCT (Luna/DS)
SkyMaster 25x100, 15x70
Zhumell 20x80
Barska XWA 10x50, 8x40
OptiView LPR 10x50
Const View 2.3x40
BV-125C
CG5, 2 drv / CG4, 2 drv, wood legs, ScopeStuff saddle / CG3, 1 drv
SV AZ / 501HDV on Bogen 055XB / P+ on Oberwerk
QuikFinder, Telrad
Orion Dynamo Pro 12, Dew-Not
Have GLP and not afraid to use it!
Sarkikos
Reged: 12/18/07
I'm not sure, though, what would be the minimum aperture to see spiral arms in a moonless dark site. Probably at least 50mm binoculars. I think the most likely galaxies would be M31, M51 and M33.
Clear Skies, Mike
C4-R (NSO/DS)
Zhumell 20x80
OptiView LPR 10x50
Const View 2.3x40
BV-125C
QuikFinder, Telrad
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
You'll need at least 8 or 10-inches to start seeing hints of spiral arms on brighter galaxies. While a 6-inch can show the dust lanes in M-31 and hints of the spiral arms in M-51, a 10-inch is much better. Larger telescopes show spiral arms in more galaxies of course, but in most cases they will be subtle because most galaxies are dim. Through a 20-inch telescope however, the spiral arms in bright galaxies does start to resemble photographs from a dark site.
Taras
-------------------- 15-inch F/4.5 Dob under construction
10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
A whole bunch of eyepieces, filters and other accessories....
Two curious cats
Doug Brown
Reged: 02/24/06
Loc: Fort Worth
I have seen arms in M51 with a 6” under very dark skies, so I think it is not so much the size as how dark it is. I bet you can see some using smaller scopes under the same skies. Experience will help as well. The trained eye sees more.
-------------------- Doug Brown
Though my soul may set in darkness, it will rise in perfect light;
I have loved the stars too truly to be fearfull of the night. ---Sarah Williams, 1868
10” Mead converted to Dob
Broken 20 x 70’s
7 x 50’s
JayKSC
Reged: 01/01/05
Loc: Florida
I've been able to detect spiral arms in several galaxies with a 6-inch refractor and have strongly suspected arm structure in bright targets with a 4-inch apo. As Doug mentioned, experience and knowing how your averted vision works will help. Also, patient, long-sustained observing will be beneficial, too. With the telescopes I've mentioned, I've never seen spiral structure with a quick glance or even a couple of minutes of observing. But with an hour or so of patient observing (broken-up with short stretches and breaks), I've been able to catch incredible detail from modest aperture instruments.
- Jay
South Florida
-------------------- Refractor manic.
My Sketches
Edited by JayKSC (10/12/09 10:03 AM)
E_Look
Reged: 03/06/08
Loc: near New York
Jay, I wonder if this might be due to getting your eyes "experienced" so as to detect subtle detail, or is it some of these elusive and fleeting but incredibly good moments of seeing?
-------------------- Ed
Doug Brown
Reged: 02/24/06
Loc: Fort Worth
I am not Jay but both I think play large parts.
Broken 20 x 70’s
7 x 50’s
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
I'm not Jay either, but his post strongly suggests the need for patience. It takes a very patient person to sit there and observe a single object for that length of time.
Ron
-------------------- Time spent looking at the stars is added to your life.
Tak FS-128, C925-CF, C6SE, other stray cats and refractors.
A-P Mach1 GTO
Zeiss orthos to Ethos - and some stuff in between.
Sarkikos
Reged: 12/18/07
Also not Jay, but I think "the hour or so of patient observing" allows the eyes to adapt more thoroughly to the dark, so that is probably part of the equation.
Clear Skies, Mike
C4-R (NSO/DS)
Zhumell 20x80
OptiView LPR 10x50
Const View 2.3x40
BV-125C
QuikFinder, Telrad
ebusinesstutor
Reged: 07/01/09
Loc: Nanaimo, BC, Canada
Clear Skies, Mike
So if Mike had been the original person naming the constellations, we wouldn't have gods and animals, we would have a star "menu".
-------------------- Garland Coulson
Orion XT8i Dob & Celestron 80 ED on a Vixen Porta Mount Mini
Baader Hyperion 8-24mm Click Zoom & Siebert Observatory 36mm
Siebert Black Knight Binoviewers
SkyWatcher Observing Chair
Celestron Skymaster 15x70mm binos
starrancher
Reged: 06/09/09
Loc: Northern Arizona
One thing that has yet to be mentioned is the sky position of the object being attempted . While faint detail may be a tough nut to crack at 30 degrees off horizon , it may be downright easy when the object is at zenith . Take into consideration the amount of atmosphere that you are trying to peer through . Of course everything else mentioned still comes into play such as transparency , atmospheric stability , a little patience at the eyepiece , etc. Another consideration would be the proper magnification used . (Too little or too much) There is a "Goldylocks" or "fine line" area here that can make or break the view . I've seen fine structural detail in objects through my 8" that are said to be impossible without 10 to 12 to 16 inches in aperture . Go figure ?
-------------------- LXD75 AR5
LXD75 SN8
Series 4000 Plossls
Misc. other stuff
Fort Rock , Az .
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
I think that authors or people who say some things are "impossible without 10 to 12 to 16 inches" are perhaps working from less than great sites (or don't get out nearly as much as they need to ). An 8 inch will show the spiral form of M51 at the proper magnification. Indeed, I have seen at least an indication of spiral structure in a six inch Newtonian, and in a four inch, the darn thing looks quite mottled, being perhaps on the verge of showing the spiral arms. M31 is a particularly teasing beast for an 8 inch, as you can see the dust lanes and one of the star clouds (NGC 206) at moderate power, but the rest of the spiral structure remains somewhat vague (unless you are using a Rich-field telescope and can see the whole thing). I actually like it better in my 100mm f/6 at around 17x to 25x. M33 shows weak but visible mottled spiral patchyness in an 8 inch, as do a few other galaxies. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
Sarkikos
Reged: 12/18/07
ebusinesstutor,
Well, we can do without the gods, but you can eat some of the animals. We have Cygnus the Swan: a lot of neck meat there. Cancer the Crab is especially popular here in Maryland. Pisces (two Northern fish and one from down South) make it a seafood platter. The Japanese like Cetus the Whale, but I'll pass. The Chinese could probably make a nice Dragon soup out of Draco. Taurus the Bull makes a great burger. If you don't mind horse meat, there's Pegasus and Equuleus, who's young and tender. If you like Southern cuisine, Pavo the Peacock's tongue is considered a delicacy. M11 the Wild Duck is a little gamey, and it's not a constellation, but hey, I'm hungry!
Clear Skies and a Full Plate! Mike
C4-R (NSO/DS)
Zhumell 20x80
OptiView LPR 10x50
Const View 2.3x40
BV-125C
QuikFinder, Telrad
Dain
Reged: 03/24/05
Loc: N.Y. Adirondack Mnts. NGC 4565...
I love M51 in dark skies with my 8-inch dob. A post I posted the beginning of this year mentioned how I had one of the best views of it on that particular night. I had the complete spiral structure and bridge to its companion. I was floored at the view. One of my favorite galaxies, NGC 4565, was also ridiculously good in the eypiece this year. But there are sooo many great galaxies that are all different sizes and shapes that offer many excellent views. I never get bored on my hunt for galaxies which are my top favorite objects.
Clear Skies to All!
-------------------- Best,
Dain
Adirondack Mountains (my true dark sky site)
@ Cedar River Flow
Local Site
Clear Skies?
Sarkikos
Reged: 12/18/07
Dain,
Your view of M51 in your 8" sounds like how it looked in mine from here in the red zone. I think that night must have been especially transparent or maybe my eyes were very well dark-adapted, because I have not seen as much detail in M51 since then, not even in my 10" at a dark site. But M51 may have been closer to zenith when I saw it in my 8" and it was later at night when the sky was darker and steadier. There are so many factors to consider when comparing observations.
C4-R (NSO/DS)
Zhumell 20x80
OptiView LPR 10x50
Const View 2.3x40
BV-125C
QuikFinder, Telrad
Hrundi
Reged: 02/06/08
Loc: Estonia
Is it also possible that seeing the arms of M51 isn't linearly helped by darker skies, but is similar to how the ring in M57 is perceived. I've found that these low contrast features can, sometimes, get a little bit swamped out by the brightness of everything else in dark skies. At my usual observation location, m57 is a bright disk, with only a slightly dim middle. M51, while featured and all, is an very bright disc. There are no dark gaps whatsoever anywhere, and so, at times, I feel that the detail gets swamped out. It's also at times like these that I play with averted vision, going from full averted, to somewhere inbetween, to direct, to better notice contrast trends.
JayKSC
Reged: 01/01/05
Loc: Florida
Whew, I've been working 10-hours today - too tired to go out and observe.
I won't claim that it's entirely "eye training" alone to allow one to pull out surprising amounts of detail from deep sky objects with modest apertures. Instead, I think it's really a combination of many factors as you and others have suggested, Ed.
Spending only a brief moment or two on an object doesn't allow the eyes to adjust as fully to the unique light patterns present through the eyepiece. I don't know about anyone else, but I find that during the first several minutes of observing a given object, my eyes readjust focus quite a bit as they dart about trying to form a coherent image.
A guess as to what's going on, from my cognitive neuroscience background, I'd expect that the effect is partially a result of eye saccads that are involuntarily made as the rods and cones work to form a good image which is made difficult by a low signal to higher noise ratio, at least when dealing with a target (e.g. dim galaxy) on the verge of perception. We know through psychology experiments that an image that is sustained for a longer duration can overcome signal noise enough to be registered as a "hit" (i.e., "seeing the galaxy"). I'm not sure, though, if there might be some sort of a saturation or limiting effect.
Eye technicality aside, I definitely think that atmospheric conditions play a big role. By observing an object for a long duration, you have a much greater chance of catching a brief moment of excellent seeing and/or improved sky clarity. Such moments can help faint details flicker into view. These brief image improvements can work with the whole eye-brain system to build a coherent, more stable image with faint - barely perceptible - details.
Jay South Florida
My Sketches
3 registered and 0 anonymous users are browsing this forum.
Moderator: Olivier Biot
