Privacy Policy |
Please read our Terms
of Service | Signup and
Ian Robinson
Reged: 01/29/09
Loc: Gateshead.NSW Nth Coast,Austra...
If you have used aluminium sheet rolled to a "big" tube .... for a newtonian (ie bigger than 6" which I think is as big as you can buy as a extruded aluminium tube)
What were your tube dimensions (Length, diameter and aluminium sheet thickness) ?
Are you happy with it's strength , stiffness and ability to hold collimation ?
Bird
Reged: 08/07/03
Loc: Canberra, Australia
Ian, I have 3 of them - a 12" tube for a 10" mirror, a 15" tube for a 13.1" mirror and most recently a 20" tube for a 16" mirror.
All rolled from thin aluminium - 0.9mm thickness - and with internal steel strengthening rings to give extra support. Also the top and bottom ends of the tubes have extra strengthening rings as well.
There's been no problem with any of these in tube flexure, although I have had some mirror and mirror cell flop that was a problem in the earlier versions, but that's fixed in the latest version (the 20" tube) with a much stronger mirror cell than before, so now the scope holds collimation right across it's range of motion.
cheers, Bird
-------------------- Deep Sky Optics 13.1" f/5.5 newtonian,
PGR Dragonfly Express, PGR Dragonfly 2
RedHat Linux + Coriander
http://www.acquerra.com.au/astro/
17 registered and 6 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
