John Miele
Reged: 05/29/05
Loc: North Alabama
Problem using Bhatinov Mask with Orion ST-80 new
      #3377564 - 10/07/09 11:28 PM
I use a Bhatinov mask with my SV102 scope and it works great. So I decided to buy another one from a vendor to use with my Orion ST-80. But when I tried the new one out tonight on the 80mm, I could not see the diffraction pattern at all It simply did not work. Is anyone else using a bhatinov mask with your 80 mm scope and is it working ok for you? Homebuilt or vendor bought? Thanks -- John
C11/Atlas Mount/Denk II BV
SV102ED/AT Voyager
DSI IIc, DSI II Pro
ST-80, Mallincam Hyper Plus B/W Video Camera
John Wunderlin
Reged: 10/01/04
Loc: Mineral Point, Wi
Re: Problem using Bhatinov Mask with Orion ST-80 new [Re: John Miele]
      #3377684 - 10/08/09 01:06 AM
I used mine on my ED80 tonight. Were you on a bright star? You may need to increase your exposure time and/or adjust the stretch in the preview window to see it properly, but it should definitely work.
John Wunderlin
Vendor - Spike-a Bahtinov Focusing Mask
Empire Ranch Observatory
Iowa County Astronomers
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: Problem using Bhatinov Mask with Orion ST-80 new [Re: John Wunderlin]
      #3378246 - 10/08/09 12:26 PM
I was on Scheat (mag 2.44) in Pegasus. I varied the exposure times from 0.5sec to 1 sec which is what I use on my SV102. And I fiddled with the preview image trying to stretch it out but I could not ever clearly see the X shaped diffraction pattern with the central line in it like I can on my SV102...I'll give it another shot. I may have had something else out of whack...
SV102ED/AT Voyager
DSI IIc, DSI II Pro
John Wunderlin
Reged: 10/01/04
      #3378279 - 10/08/09 12:38 PM
If you're tracking is good, try doing a longer exposure like 10 seconds to see if it shows up then. Also, make sure your gain is turned up to full if you have a setting for that.
John Wunderlin
Spacewalker
Reged: 10/05/07
Loc: Scottsbluff, Nebraska
      #3378500 - 10/08/09 02:29 PM
You may need to add an extention to reach focus!
www.panhandleastronomyclub.com/StarGaze.htm
John Wunderlin
Reged: 10/01/04
Re: Problem using Bhatinov Mask with Orion ST-80 new [Re: Spacewalker]
      #3378505 - 10/08/09 02:30 PM
Wow- didn't even think of that. That's probably the issue.
John Wunderlin
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
      #3378566 - 10/08/09 03:07 PM
did you remove the diagonal? to get focus with a camera I have to remove it. also a 10 sec exposure will help
WarrenS
Reged: 03/04/08
Loc: Orange County New York
      #3378926 - 10/08/09 06:47 PM
I myself have trouble with anything fainter than a first magnitude star. The brighter the star the better.
Warren
Astro-Tech 127EDT
Celestron Onyx 80ED
Astro-Tech Field Flattener
C8 (circa 1983 Orange Tube)
Atlas EQ-G, Orion SSAG
Canon 135mm F2.8
Canon 40D, Astronomik CLS clip filter
Leica, Minolta binos
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: Problem using Bhatinov Mask with Orion ST-80 new [Re: WarrenS]
      #3379163 - 10/08/09 08:55 PM
Thanks everyone. I'll try some of these ideas out but of course it's clouds and rain for the next few days...
SV102ED/AT Voyager
DSI IIc, DSI II Pro
John Wunderlin
Reged: 10/01/04
      #3379239 - 10/08/09 09:41 PM
We've had a rough several weeks here too. I snuck in some imaging last night, cloudy tonight for the LCROSS impact
John Wunderlin
Alex McConahay
Reged: 08/11/08
      #3386316 - 10/12/09 10:55 PM
You did not say what kind of setup you habve, but could I suggest you try it out during the day, and focus on a distant mountain or telephone pole just to be sure your scope can reach focus with your setup. Then mark your tube, or better yet, get an eyepiece and parfocalize it.
Then, at night, turn up your ISO, or gain, depeinding on what you are using, point to Vega, or Betelgeuse or something bright, and you should get something.
I use a BMask on my TV 85 all the time without problem. I even use it on my camera lenses (58mm opening!). So, the problem is not the size of the aperture.
Alex
Galaxyhunter
Reged: 01/02/06
Re: Problem using Bhatinov Mask with Orion ST-80 new [Re: Alex McConahay]
      #3386681 - 10/13/09 06:51 AM
Last Saturday night I used one at a friends house (on a ST80). We had it set for a 2 second exposure and on the Stars Altair & Vega, the defraction spikes where there. We had to adjust the Black & White slideres to display the spikes, but it does work.
Carl
My lousy skies at Hawkeye Observatory
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: Problem using Bhatinov Mask with Orion ST-80 [Re: Galaxyhunter]
      #3388196 - 10/13/09 10:18 PM
OK. It sounds like I just need to try it again. But it has been raining like you would not believe here for days! So much for the cool and dry Octobers of yesteryear! And I was supposed to leave for the Peach State Star Gaze tomorrow, but the forecast for there is also heavy rain
SV102ED/AT Voyager
DSI IIc, DSI II Pro
6 registered and 6 anonymous users are browsing this forum.
