Observing >> Solar
Junn Chavez
Reged: 02/24/09
Loc: Sands of Arabia
Zeiss "Sonnenglas" Filter new
      #3384969 - 10/12/09 08:49 AM
How safe is this filter for solar observing? It screws on 0.965 Zeiss Orthos. Anyone tried this filter before?
I assume that it is safe because it's made by Zeiss.
Thanks for your input.
stephenramsden
Reged: 08/17/07
Loc: Atlanta, GA--USA
Re: Zeiss "Sonnenglas" Filter new [Re: Junn Chavez]
      #3384981 - 10/12/09 09:04 AM
Well, I have never used it but I did search CLoudy nights and found this article at:
http://www.cloudynights.com/item.php?item_id=113
which stated this:
Sonnenglas
This filter is reminiscent of those endlessly supplied with cheap (and nasty) department store type telescopes. I recall receiving one with my first scope, and I still have it, unused. While the Zeiss equivalent undoubtedly will be better, by far, I am still hesitant to use it, much preferring the filter material at the objective end of the scope. (I have self made Baader filters for most of my scopes). In a moment of bravery, or is that stupidity, I tried this Zeiss sun filter, and the image was a beautiful orange colour, with a lot of detail visible. Telescope used was the Telementor, and another interesting point to consider that as the filtering is done after the eyepiece a non cemented ocular is handy, almost mandatory. The reason is that in today’s modern cemented designs the fierce heat from the unfiltered sun can melt the compounds used in this cementing process. The Zeiss Huygens are especially good from this respect, being two single and non-cemented lenses. Little information is available other than a statement in an old Zeiss booklet that simply states “it possesses an absorption of about 11 orders of magnitude”. I understand it was designed to be used with an aperture stop over the objective as well. Self preservation makes me look at this filter as a lovely collection piece only.
So, I would have to say that if you like being blind or you enjoy watching your telescope melt, this is the filter for you!
Stephen W. Ramsden
Atlanta, GA--USA
NASA SOLAR SYSTEM AMBASSADOR
www.solarastrophotography.com
www.SolarScopeReviews.com
www.stephenramsden.com
Alan Friedman
Reged: 08/30/07
Loc: Buffalo, NY
Re: Zeiss "Sonnenglas" Filter new [Re: stephenramsden]
      #3385043 - 10/12/09 09:54 AM
To shorten Stephen's important message... it is NOT safe to use a solar filter at the eyepiece. The sun's light MUST be filtered at the objective end of the telescope.
Alan
Alan Friedman
www.avertedimagination.com
stephenramsden
Reged: 08/17/07
Re: Zeiss "Sonnenglas" Filter new [Re: Alan Friedman]
      #3385050 - 10/12/09 09:57 AM
Yeah, that's what I meant to say...:)
Stephen W. Ramsden
Atlanta, GA--USA
Ralph Marantino
Reged: 05/01/05
Loc: Old Bridge, New Jersey
      #3385213 - 10/12/09 12:04 PM
VERY unsafe do not use/.
Lunt H-alpha LS100THa/B3400
Rockland Astronomy Club
Member BAA Solar Section
Central Appalachian Astronomy Club
Astronomical League
DSPST,PST & 70mm Coronado Cal K telescope.2.2A
Zeiss 2 inch prism diagonal&Zeiss Zoom EP
2inch APM Herschel Wedge in a 94mm F7 Brandon
14.5 inch f4.2 Starmaster Dob(Zambuto mirror)
TeleView Genisis SDF with 1000 Oaks Glass filter
Zeiss 63mm f13.5 refractor 1000 Oaks Glass filter
Itty Bitty Solar Radio Telescope.
LHRIES Lite Solar Spectrometer
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
      #3385778 - 10/12/09 05:42 PM
Filters that screw onto the eyepiece tend to be frowned upon (regardless of who makes it). It isn't that they can't filter out the light properly (many can). It is just that the light energy concentrated to a small region on the filter by the telescope may eventually cause the filter to crack or shatter without warning. If that happens while you are looking into the eyepiece, you will very probably suffer permanent eye damage. A friend of mine had his vision saved by the UPS man one day. He was viewing the sun in his 2.4 inch refractor using one of those little screw-on SUN filters when the doorbell rang. He had taken the eyepiece out to answer the door and tend to the delivery, but then, he heard a "CRACK" sound. When he got back to the telescope, he could see sunlight streaming out of the star diagonal and onto the ceiling, where, he noted to his dismay, a small piece of that solar filter was embedded into the plaster! It is best to avoid the use of such "screw-on" single unit eyepiece filters and go with a good white-light filter that covers the objective. Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
BYoesle
Reged: 06/12/04
Loc: Goldendale, WA USA
Re: Zeiss "Sonnenglas" Filter new [Re: David Knisely]
      #3386307 - 10/12/09 10:49 PM Attachment (2 downloads)
I had the exact experience David describes in his post above with my 60 mm refractor telescope and a eyepiece mounted sun filter -- it dangerously cracked -- fourtunately while I was not looking through it...
However, I would sincerely have to disagree with the above in that a Herschel wedge, which is used at the eyepiece end of a refractor, is a safe solar filtering device (when used as directed with the appropriate filters), and is in fact a superior device to any objective mounted filter I have used -- including a 100 mm Zeiss SFO, and the full-aperture Questar filter, which I both own, and are among the highest optical quality available.
Criterion also made a unique eyepiece solar filter in the late sixties and early seveties (with a mirrored barlow lens and internal filter ahead of the eyepiece), which is also quite safe and a bit of a collectors item.
Bob Yoesle
You are a child of the universe,
no less than the trees and the stars...
And whether or not it is clear to you,
no doubt the universe is unfolding as it should.
Desiderata
David Knisely
Reged: 04/19/04
Re: Zeiss "Sonnenglas" Filter new [Re: BYoesle]
      #3386587 - 10/13/09 03:51 AM
The above unit shown in the image is a sort of low-power "aluminized barlow". The unit required an additional filter, but the combination worked pretty well. As for the Herschel wedge, I don't put that in the same league as the simple screw-on "SUN" cap filters that some of us old-timers got with our little 2.4 inch refractors. I consider them "time bombs" waiting to steal our vision, so they can be rejected outright. The Herschel wedge is a nice safe and effective way to view the sun in white light, although the cost of the wedge approaches that of some low-end H-alpha systems like the PST. It also is not used in many reflectors due to the internal heating issue, which again is where the front objective-covering solar filter is a very good and economical choice for white light solar viewing. Clear skies to you.
David W. Knisely
Junn Chavez
Reged: 02/24/09
Re: Zeiss "Sonnenglas" Filter [Re: David Knisely]
      #3388644 - 10/14/09 07:13 AM
Thank you all for the input. My hands were sweating while reading some of the post, thank God I asked before using the said filter!
8 registered and 4 anonymous users are browsing this forum.
Moderator:  Don W, spaceydee
