kfrederick
Reged: 02/01/08
Re: Roughness and its complement new [Re: kfrederick]
      #3388711 - 10/14/09 08:36 AM
The 26.25 inch mirror needs more correction in the center and the bad edge.
Feidb
Reged: 10/09/09
Loc: Nevada
      #3388714 - 10/14/09 08:37 AM
My 16" was 1 1/4" thick and I had trouble with astigamtism. I used a full-sized tool for all grinding then switched to I think it was 10" and a 6" tools for polishing. I had to go back to fine grinding three times because of the astigmatism and never did get it all out, but I got it minimized. It probably would not pass muster with you masters, but it sure made me happy when I finally got a look at Jupiter!
My tool was 1/4" plate glass epoxied to two round pieces of 3/4" plywood. My polishing tools were plywood sealed at the edges. I never had a problem with sleeks.
During the first go when I put a Ronchi strip on it, the patterns looked like a butterfly. If not for that Ronchi strip, I might never have got it down to where my Focault readings would make sense. At that time I was a bit rusty!
I worried about smoothness and in the final figuring I switched from Cereum Oxide and Barnesite to rouge. The slower bite made for a smoother surface.
Whatever the case, I'm happy with it even now, 22 years later.
Present gear:
16" Meade LightBridge
Meade 50mm straight through-finder
Lumicon green laser pointer
Orion Q-70 26mm, 32mm, and 38mm
Parks 2X 2" Barlow
Hyperion 17mm, 8mm
1 1/4" 18mm Russell Optics Bertele
1 1/4" 12.5mm and 6mm Coulter Optical Orthoscopics
1 1/4" X 2" 32mm Edmund Scientific war surplus Erfle
Tirion star atlas (white stars, black background) hand-laminated
Megastar
And a partridge in a pear tree
To nudge or not to nudge, that is the question
rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Bremerton Washington
      #3388938 - 10/14/09 11:26 AM Attachment (11 downloads)
Rough surfaces can be quite eye catching. Here is the initial surface of a 13"f/5 I'm currently working on. Pushing back the central sphere to join with the outer zones.
quick work leaves quite a bit of roughness......I'll smooth it all out when I get the right shape.
Rob
www.goldmtobservingcenter.com
A great place for amateur astronomers, and ATM's to come and enjoy their hobby.
http://tech.groups.yahoo.com/group/HomemadeRefractorTelescopes/ My homemade refractor group.
www.vimeo.com/6014031
mark cowan
Vendor (Obsidian Optics)
Reged: 06/03/05
Loc: salem, OR
Re: Roughness and its complement new [Re: neo]
      #3389446 - 10/14/09 03:49 PM
Talking about strokes and smooth mirrors...I hope I'm not to off topic with this, but just a question....what is the best approach for a 16", 1.18" thick mirror?
Depends - what f/ratio do you expect this mirror to be?
Best,
Mark
mark cowan
Reged: 06/03/05
Loc: salem, OR
Re: Roughness and its complement new [Re: mark cowan]
      #3389478 - 10/14/09 04:01 PM Attachment (1 downloads)
Worked my last mirror a 20 f 8 with a full sized polisher/ tool on top / long stroke all on one side /manual overarm on a tub grinder/last time i polished it, I polihed for 2 hrS continus very thin ceo /tested with a ronchi and knife edge THEN EDS ZYGO .No small polihers needed on that one .With a f 8 you can do that . Knife edge very strong at 27 ft away /
Say Kevin, have you experimented at all with masking that edge?
Best,
Mark
BluewaterObserva
Reged: 05/18/04
Loc: Zuni Mtns, NM
      #3389512 - 10/14/09 04:22 PM
I have to say.. Some of the foucault and/or interference photos on here look pretty much Ok to me and I am sure would produce decent images. But I no longer desire to make mirrors, many on this site that are posted as having issues look much better than my best attempt.
Saves me money in the end that I am not so picky.
kfrederick
Reged: 02/01/08
      #3389547 - 10/14/09 04:41 PM
looks better
neo
Reged: 02/12/08
Loc: Iasi, Romania
      #3389588 - 10/14/09 04:59 PM
Best,
Mark
Well..I guess F/5 would be nice...otherwise it gets way to long for 16".
Russian 15x50 binos
Home made 8" f/5 Newton on eq mount
Home made 70mm f/6 (Rodenstock Rotelar lens) Apo refractor
www.astronomy.ro
Feidb
Reged: 10/09/09
Loc: Nevada
      #3389601 - 10/14/09 05:03 PM
I specifically went for f/6.5 or f/7 just because of the thickness of my mirror (1 1/4"). I ended up with f/6.4 and the beast is 9 feet long. That is one reason I'm now using a commercial f/4.5.
Present gear:
Parks 2X 2" Barlow
Hyperion 17mm, 8mm
Megastar
mark cowan
Reged: 06/03/05
Loc: salem, OR
Re: Roughness and its complement [Re: Feidb]
      #3389642 - 10/14/09 05:16 PM
You mean the sag? I consider a 16x1.25" mirror on the thick side.
Best,
Mark
8 registered and 8 anonymous users are browsing this forum.
