Rich Strassberg
Reged: 07/30/09
Loc: Los Angeles, CA
Contact lenses for short eye relief?
      #3390479 - 10/15/09 12:33 AM
Greetings! It occurred to me that after all of the information I've read about problems wearing glasses, with binos with short eye relief, there has never the mention of wearing contact lenses. Is there a problem wearing contacts while looking through EPs? I wear progressive lenses that are antireflective. If I could use the contacts for viewing should the corrective lenses be for farsightedness or nearsightedness? Also, should they have an antireflective coating? I didn't ask about if that's an option.
I would only wear them for viewing!
Thanks again for all of the advice. I decided on getting the Fujinon 16X70's.
hallelujah
Reged: 07/14/06
Loc: Rocky Mt. High Colorado
Re: Contact lenses for short eye relief? new [Re: Rich Strassberg]
      #3390521 - 10/15/09 01:12 AM
I asked one eye doctor about contact lenses and she told me that they would NOT be as sharp as my progressive eyeglasses, so I never tried them.
Celestron Traveler 8x25 & B. & H. 8x40 FC JAPAN & Revue 10x50 CF Porro FC JAPAN &
Pentax 12x50 PCF WP II FMC & Pentax 16x60 PCF WP FMC &
Pentax 20x60 PCF WP II FMC & Orion 12x63 Mini Giant FMC JAPAN &
SPECTRUM I 20x65 FC JAPAN &
Orion 15x70 Little Giant II FMC JAPAN & Orion 20x70 Little Giant II FMC JAPAN
Orion 16x80 Giant FMC JAPAN & Orion 30x80 MEGAView FMC JAPAN
Barska 30x80 X-Trail LW FC & Burgess Optical Series II 20x90 FMC
Hallelujah! For the LORD God Omnipotent Reigneth
wojo
Reged: 09/28/07
      #3390524 - 10/15/09 01:14 AM
Hi
I wear contacts (bifocal no less) all the time for regular viewing and observing and find that they work well for me. I also have regular glasses , but just can stand the on off on off all the time. As far as near or farsightedness I don't know. some one mentioned TORIX contact lenses for astigmatizm, and I will try them after my next eye test, as I get a little flaring naked eye in the stars.
I wear contacts all the time, and they are so comfortable I don't realize they are in, maybe you could give them a try?
Rich V.
Reged: 01/02/05
Loc: Carson Valley, Nevada, USA
      #3390537 - 10/15/09 01:26 AM
No, not at all. I've used contact lenses with my optics for 45 years; no problems yet!
I don't understand the question; are you farsighted or nearsighted? You get contact lenses made with the same basic correction that you need for infinity vision with your current eyeglasses.
I use contact lenses with my 16x70s most all the time; if you are less than 6-7 diopters nearsighted or farsighted there is probably enough focus range to use them without glasses or contacts. You'll have to put your glasses on to aim them though! Astigmatism is another matter, though, and contacts become more problematic.
Enjoy your new binoculars!
Rich V
Binoculars:
33/50/75/150x100 Saturn III, 16x70 FMT-SX, 10x50 PCF-V, 10x43 DCF-SP, 10x35 E2, 7x35 E, 8x30 E2, 7x26 Custom, 8x23AS Diplomat, 8x23 Travelite
Scopes:
C9.25, 6" f8 reflector, SV80S
Luigi
Reged: 07/03/07
Loc: MA
Re: Contact lenses for short eye relief? new [Re: Rich V.]
      #3390698 - 10/15/09 07:24 AM
I'm nearsighted, ~2.75 diopters, with no astigmatism, and used to wear soft contact lenses. I found extended astro-viewing without contacts to be superior; sharper, less scatter, and more comfortable. Binoculars and eyepieces are optimized for infinity focus, so ideally it is best to be corrected for distant vision, though the difference in view when corrected for near vision is very small.
17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
Jeronimo Cruz
Reged: 09/01/08
Loc: Tucson, AZ
Re: Contact lenses for short eye relief? new [Re: Luigi]
      #3390983 - 10/15/09 11:09 AM
I used to wear soft disposable contact lenses while observing all the time. Then I started to see the detrimental effects of prolonged observing while wearing contacts. My contacts would slide around my eye slightly and cause stars to distort severly even on axis. I also noted that as I observed for longer periods, my contacts would dry and yield a fogged over effect on the image. This happened consistantly even after using eye drops and frequent blinking. I like to observe as long as possible with my eyes open. It is an unconcious habit of mine. A couple of times my eye dried to the point of a lens falling out! I slowly realized that contact lenses were NOT conducive to a pleasurable viewing experience, even though I really wanted them to work. Some of my binos don't have enough eyerelief to work with glasses.
Also, does anyone know if wearing contacts dims the image slightly? I suspect this to be the case but as I have no method to measure this...
I now use binos with very long eye relief and with glasses on perhaps everything except for the most critical binocular observations.
I tried combining contact lenses and binos w/short eye relief and it didn't work for me.
Just a reminder, critical observing should never be done wearing contact lenses or eyeglasses (except astigmatism + widefield observing)!
Jeronimo
TeleVue 101 + Gibralter
Celestron NS11 GPS/wedge + Hyperstar
Photon Instruments 127mm + SV F50W2
Lunt Solar Systems LS60DS Ha + Celestron CG-5
Naglers, Panoptics, Radians, Nikon binoviewer
Fujinon 10x70 FMT-SX, 7x42 CD; Canon 15x50IS;
Pentax 7x50 PCF WP, 10x50 PCF WPII, 10x50 DCF SP
Work
20" R/C RCOS on Paramount + Tak FSQ
16" R/C RCOS on Paramount + TEC 140
16" Meade LX200 SCT + TV 76
Ethos, Naglers, Panoptics
Coronado Solarmax 90mm Ha
Coronado Solarmax 70mm Ca
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
Re: Contact lenses for short eye relief? new [Re: Jeronimo Cruz]
      #3393545 - 10/16/09 07:09 PM
I’ve had similar experiences. I would love to wear contacts, but the drying, moving and bluring is tiresome.
Brian S. Johnson
________________
Zhumell Z10D, Orion ST80, 114mm Meade Telestar (Re-hab'd)
8-24mm Hyperion Zoom
8mm, 17mm, 21mm Baader Hyperion 14mm & 28mm Fine Tune Rings
OPT OIII, Baader Fringe killer, Baader Moon & Sky Glow
Nikon 10x50 Action Extreme
StarDust Observing Chair
Astro-Tech Voyager Mount
13 registered and 29 anonymous users are browsing this forum.
Moderator:  EdZ
