Privacy Policy |
Please read our Terms
of Service | Signup and
thisgaard
Reged: 10/20/06
I currently have a CGE with a C14 on it and I'm thinking of buying an FSQ106 for wide-field imaging.
Do you think it will be too much for the CGE mount to handle if I put the FSQ on the mount together with the C14 and then use the FSQ for imaging and the C14 as guidescope? I will be using a QHY8 for imaging through the FSQ.
Kind regards,
Helge
-------------------- CGE14XLT, Vixen R200SS, Orion ED80, Orion 102mm, Canon 40D, QHY8, DSI, QHY5
Phil Cowell
Reged: 05/24/07
Loc: Southern Tier NY
It wouldn't work well for imaging. I'd look to the CGE Pro for that amount of load.
-------------------- If it'll fit on a sig you don't have enough
TxStars
Reged: 10/01/05
Loc: Lost In Space
I would get a plate to use the FSQ with the 102mm you have as a guidescope. Then it would be great for widefield and easier to transport and set-up.
-------------------- http://txstars.org/
Tak FC-50 / Tak FCT-65 / Tak FC-100
Celestron 8" Schmidt camera
Clasic Sand Cast C-8 & C-5
"SCUZZO" 300/f 1.1
Cameras: Nikon F2/Mamiya 645, press 6x7 ,6x9/ Hasselblad 6x6 / Lenses Yes Many - Yay Film
Mount - GoTo by hand and eye
thisgaard
Reged: 10/20/06
Ok - thanks. I guess I will just have to continue switching between the scopes then.
Frank
Reged: 01/18/09
Loc: Netherlands
I do have a C14 together (side-by-side) with a WO80FD, on CGE. Great for visual observing (REALLY great), but not for imaging. Vibration stops after 2 sec, but this is not good enough for imaging.
Consider flexing as well - the C14 OTA is quit heavy, and this may result in flexing of mounting parts.
-------------------- Celestron CGE1400 XLT
C6 XLT
Vixen 6" F5.0 Newton
WO Zenithstar 80 FD
Smo
Reged: 01/19/09
Loc: North Vancouver, BC, Canada
Yes I think there are quite a few people that have a C14 on a CGE for imaging but that scope alone is probably pushing it for the CGE for Astro Photography.
I think the CGE has a capacity of 60 pounds? Even the AP 900 with a capacity of 70 lbs is not recommended for AstroPhotography with the C14 on top of it.
-------------------- Russ
20" Obsession F5 with Argo Navis and Servo Cat.
Televue NP127is
Astro-Physics 1200GTO on an AP Portable 10x48 Pier
Astro-Physics 900GTO on an AP Portable 8x42 Pier
SBIG STL-11000 Mono/2" Astrodon LRGB and Ha
DMK 21AU04/OFW/1.25" Astronomik LRGB
Edited by Smo (10/20/09 01:45 PM)
Mobius1
Reged: 08/28/05
Loc: Madison, WI / Gurnee, IL
Ugh... I keep wanting to buy a C14, and I actually have the opportunity to do so, but the CGE seems to be the weak link. Vibration nonwithstanding, even the PEC is terrible with the C11... I'm sure the C14 would introduce more problems. I still want one though, wish I'd had gotten the G11 (heard the gears were better, less vibrations).
-------------------- Martin
William Optics 66SD
Orion 100ED
Orion 120-ST EQ
PST-Ha
Celestron CGE 1100
Canon Rebel XSI with Astronomik filters
DSI-IIC
Homemade spectroscope in progress...
Yerkes Observatory Volunteer
(24" Cass on weekends)
LarsZ
Reged: 01/12/08
Loc: Sweden
Well, I may be one of the few that don't agree that the CGE14 can't be used for imaging, at least with a FR, but maybe my standards are low.
Anyway, I used this combo for more than half a year without using it for imaging since I read everywhere that it was pushing it for visual use only . Then I decided to try it with my Canon EOS 450, and surely it's no Paramount or AP, but I wouldn't say that it's useless.
Here are my 2 attempts at NGC4565 amd M64 with a CGE14 with a 0.63 focal reducer, haven't tried at full focal length yet:
http://farm4.static.flickr.com/3386/3576012307_a3077395d2_o.jpg
http://farm4.static.flickr.com/3622/3553167519_5e0fe892b1_o.jpg
These pictures won't win any prices, but I think they show that the CGE is usable for imaging if you don't request Paramount pictures.
/Lars
-------------------- Rebel XSi, IDAS LPS, CGE 9.25, Orion SSAG, Starblast 4.5
Edited by LarsZ (10/23/09 04:06 PM)
jason_milani
Reged: 09/03/04
Loc: Northeast Ohio
OOH, that's encouraging.
-------------------- Celestron C-14
Celestron C-8
Celestron C-5
Orion/Vixen ED114SS APO
William Optics Megrez 72mm ED
Celestron CGE mount
Discmount DM-4
Mallincam Hyper Color Plus
Baader UV/IR Modded Canon 40D
jrcrilly
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
I'm working on a swap for a CGE. When the smoke settles, I'll stick the C14 and FSQ on it just to see how it feels. I've been hesitant to try that combo at F/11 even on the NJP so I'm not optimistic about the CGE. I don't think I'd be afraid to try to try it with the C14 alone (or perhaps with a lighter second telescope) at F/7 or less, though.
-------------------- John C
Urban Observatory
A&M/Astreya 76mm F/6 APO
TMB/LOMO 80mm F/7.5 APO
Tak FSQ-106N F/5 APO
Meade 178ED F/9 "APO"
Meade ETX-125AT
C14
Teeter 20" F/3.8 truss Newt w/ServoCat
CI-700, NJP, GPDX/SS2KPC, CG5-GT
ST-10XME, DSI Pro
LarsZ
Reged: 01/12/08
Loc: Sweden
Reading the question a little more carefully (should have done that from the start), I realize that it's quite a heavy scope that you would like to use with the C14.
I use a light 4.5" Starblast reflector as a guidescope and the FSQ106 is a lot heavier. Still, if you buy it, I think you should try it, at least with a focal reducer. What makes me optimistic is that I don't find my CGE14 to be very sensitive to balance when I image, so there should be room for some more weight on the mount.
As I can see in your signature line that you have a couple of other refractors, you could try one of these with the C14 first to see how it performs. What has kept me from trying the full focal length is that my guidescope has a very short focal length, in the same region as the FSQ106. I have tried imaging with a guidescope that had a focal length about 1/8 of the main scope, but I had to throw away some pictures. By just going to 1/6 in focal ratio it worked a lot better. Maybe a barlow can be useful though.
/Lars
15 registered and 17 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
