CosmoQ
Reged: 08/26/06
Loc: NH
Mount recommendation new
      #3385830 - 10/12/09 06:12 PM
I'd like some suggestions for an EQ mount for my ZS110 in the $500.00 (or less) range. I enjoy doing "Star Parties" and don't mind "Star Hopping" to various objects to show the attendees and would like to track the object. I don't think I need a two drive mount so an RA drive would work well. I don't need a Go-To mount (I use my LX90 for that).
Currently, I use an "E-Z Touch" Alt-Az mount for the ZS110.
Dave
Meade LX90, Fujinon FMT-SX 16X70 Binos, and WO ZS 110 TMB/EZTouch Mount
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.22 X 90....
Re: Mount recommendation new [Re: CosmoQ]
      #3386212 - 10/12/09 10:01 PM
Hey Dave... Here's an ad for a Meade LXD75 which would work well with your scope. I have a WO Megrez 110 on an LXD75. It's my grab'ngo scope and my outreach scope.
David
Proud Member; PAS NOLA,
"If we knew what we were doing, it wouldn't be called research..."
A. Einstein
gnowellsct
Reged: 06/24/09
Re: Mount recommendation new [Re: David Pavlich]
      #3386298 - 10/12/09 10:46 PM
Super Polaris. $500 can sometimes get you not only a mount but a c8 to go with it. Greg N
"Aperture will get you through times of no money better than money will get you through times of no aperture."
featuring selected astrojunk:
bunch o' widefield eyepieces
bunch o' narrowfield eyepieces
couple o' Barlows
couple o' scopes
couple o' mounts
couple o' tripods
and a pier 'n' stuff
Luigi
Reged: 07/03/07
Loc: MA
Re: Mount recommendation new [Re: gnowellsct]
      #3386706 - 10/13/09 07:29 AM
CG5ASGT is one of the best values out there and available for under $600 new if you shop around.
17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
CosmoQ
Reged: 08/26/06
Loc: NH
Re: Mount recommendation new [Re: Luigi]
      #3387235 - 10/13/09 01:51 PM
Good info, I'll be checking them out.
Dave
Steve Fisher
"Curmudgeon in Training"
Reged: 08/12/06
Loc: Utah
      #3387773 - 10/13/09 06:35 PM Attachment (11 downloads)
Either the LXD75 or the CG5 are GREAT mounts for the ZS110. I had mine on the LXD75 and it was a perfect fit. Gads, I miss that scope.
Steve
8" f/12 D&G Achromat Refractor Delivered 08/27/09
6" D&G f/12 Achromat Refractor
66mm f/6.1 William Optics Petzval
6" f/8 Celestron Starhopper
"Never try to teach a pig to sing, It wastes your time and it annoys the pig". (Robert Heinlein)
CosmoQ
Reged: 08/26/06
Loc: NH
Re: Mount recommendation new [Re: Steve Fisher]
      #3392857 - 10/16/09 11:59 AM
That is a pretty set up!
Dave
Eddgie
Reged: 02/01/06
      #3392922 - 10/16/09 12:40 PM
For that scope, the most economical choice would be a used LXD-55.
The aluminum legged tripod is much lighter than the tripod on the newer CG5 and LXD-75, but is more than rigid enough for the intended applicaiton.
And while you might not NEED Go-To, it doesn't hurt anything, and you get electronic slow motion in both axises.
All for $300 or less.
You can't get a better deal in mounts than this, and it might be perfect for your needs.
Another excellent choice would be an older Polaris. These sell used for well under $200 (though finding one with a motor is not always easy). The other drawback is the rings need to be bolted to the tabs on the mount.
Still, this is a really high quality little mount that is very compact and has the added utility of being a fine teresstial Alt-as mount. Be aware that they come in three different versions: Fixed short legs intended for reflectors, adjustable short legs, and refractor legs. I would advise the last of course. But you can also easily bold on a set of aluminum legs from any CG5 type mount (pre-tube leg).
Good luck.
Celestron C14, CGE (Big Al)
Astro-Physics 6" f/8 (Buffy)
Televue 101 (No name, but I call it my Widescreen HD Space TV)
The night sky is my mistress. She seduces me away from all other lovers.
Doug76
Reged: 12/05/07
Loc: SE Louisiana, future Texan
Re: Mount recommendation new [Re: Eddgie]
      #3393744 - 10/16/09 09:55 PM Attachment (10 downloads)
Another vote for the CG-5ASGT. I use mine to carry all my scopes, and the nearest scope I have to yours is the AT90EDT, an oversized 90mm weighing in about 13lbs without accessories. It carries it just fine, for visual or AP.
Doug
Truckstop Astronomer
The Universe, the light of God, in all it's majesty
6 achro refractors, 50mm-150mm
1 apo refractor, 90mm
1 SCT, 8 inch
UO Abbe Volcano Tops
Faworski Ortho's
Panoptic 24mm
Carton 100mm f/13 under construction
Bill Cowles
Reged: 04/16/06
Loc: Utah
Re: Mount recommendation [Re: Steve Fisher]
      #3393822 - 10/16/09 10:48 PM
Love the color.
Bill
Lunt LS60TS50DS/B1200/FT (on order)
TV Gensis/Solarmax 60 filter
PST DS/Herschel Wedge/C4-R
C6-R /Atlas Goto/Moonlite CF2
12" LightBridge/Round Table
MCHP/8" Orion OTA/Ultima 2000
10" Discovery /Celestron SE-4
7 registered and 8 anonymous users are browsing this forum.
