RoundStars
Reged: 07/09/08
Loc: Hutchinson, KS
Re: Image drift? new [Re: Hermit]
      #3390601 - 10/15/09 03:04 AM
Hermit: My initial question inquired about the reason for the target drifting across the imaging camera's FOV. Slight star trailing is a secondary issue that I suspect is related to the drift. No, my star trailing is a little less pronounced than your example: more just slightly egg-shaped stars. I do loop the camera wiring gently back to the mount, enough to allow the mount to rotate without binding. Thanks for posting the image.
Ask your doctor if astrophotography is right for you. Seek medical attention if you experience a sub-exposure lasting more than four hours.
RoundStars
Reged: 07/09/08
Loc: Hutchinson, KS
Re: Image drift? [Re: RoundStars]
      #3394195 - 10/17/09 08:34 AM
Followup: I did a drift alignment, found I was slightly off, and corrected it. I did a few quick images with my 66ED and found little or no image drift, and improved star shape. I think now that flex with my rail-mounted C8 is the biggest culprit: the moment with the rail-mounted OTA, camera, guidescope and guide camera must be large, and is probably causing the rail to twist slightly. I think that mounting the OTA with rings would help here. Needs more experimenting. Thanks to everyone for your comments.
-Joe
6 registered and 3 anonymous users are browsing this forum.
