Privacy Policy |
Please read our Terms
of Service | Signup and
BKBrown
Reged: 08/23/09
Loc: Ashburn, VA USA
Can anyone recommend an outfit offering heavier replacement CW shafts for the Atlas? I am interested in replacing the stock shaft. Thanks...BB
-------------------- Skywatcher 100ED-5QP 100mm f/9 APO, Synscan & GPS
C8N f/5 Newt, WO 66SD ZenithStar APO
Atlas EQ-G w/ Synscan & GPS
Baader Hyperion 8-24 zoom; 31mm, 36mm ASP
TV 19, 24 Pan; Nag 9T6,13T6
Siebert 1.5/2.0/2.5/3.0/3.5 Barlow,
Celestron 2x Ultima Barlow, TV 3x Barlow
Celestron 15x70 Skymaster
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Not sure how large of a diameter your looking for, but there are several companies just making longer replacement shafts and maybe a sleeve to fit over the stock one. I made mine from 1.244" so if I needed more CW's and didn't want to make them, I could just buy new or used on the market. Because of the high cost of stainless and shipping weight, I'm not doing anymore, but will be glad to send you the specs on mine and you can have a local machine shop do it for you. If stainless is out of the budget, you can always have them made out of steel and then use gun blueing for an inexpensive coating...looks great, i've done it myself to other projects.
-------------------- Equipment Overload!
Kerry
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
The shaft and pin I designed doesn't alter the mount in any way. You can stick the stock shaft back in if your going to resell in the future.
Kerry
Nils_Lars
Reged: 01/04/08
I contacted Astro-Rubylith and I was told they had 1 left and they werent going to do anymore after that , I have decided to have a friend who does machining do it instead.
-------------------- Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
ssatko
Reged: 03/05/05
Loc: NC
Hope this isn't considered hijacking the thread, but I'm considering getting a GEM at some point in the future, and the Atlas is on my short list. Sorry if this is a silly question, but why would one consider upgrading the counterweight shaft?
-------------------- Scott
SV80/9D
SV102ABV
Orion 4.5" Starblast
Meade LX90 8" UHTC
Orion XT12i
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Scott
If you are going to run a heavy load (above 40 lbs) the stock shaft can be a little short with the need for so many CW's needed.(it can flex) It is also smaller in diameter than a CG5 mount at 18mm verses 20mm for the CG5 types. A larger CW shaft also adds weight so less CW may be needed.
Kerry
ssatko
Reged: 03/05/05
Loc: NC
Ah...that makes sense. Thanks for the education, Kerry!
SV80/9D
SV102ABV
Meade LX90 8" UHTC
Orion XT12i
BKBrown
Reged: 08/23/09
Thanks for the advice, I'll let ya'll know what I end up doing. Clear Skies...BB
Harold925
Reged: 07/11/09
Loc: Near Charleston, S.C. Cluster
* Here you go: Mr Deven Matlick of Criterion Machine Co., (CriterionMachine.com) can help you.
http://www.criterionmachine.com/Extended%20Counterweight%20Shaft%20for%20Atlas%20Mount.html
Take care,
-------------------- Harold
Celestron CGEM, C-9.25 XLT
Orion XT8i
Celestron SkyMaster 9x63
Many Accessories
10 registered and 8 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
